WiFi Extender Antenna - do they work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-23-2012, 06:48 AM - Thread Starter
RNaval's Avatar
Anyone have any experience with WiFi Extender Antennas? I replaced my router's antennas with two 9db Extender antennas and found no improvement in performance, in fact the distance / wifi range was actually reduced.
I wonder if any config / setup was required besides a reboot of the router after installing the antennas. I have a Dlink DIR-628 router, any comments or suggestions?
RNaval is offline
post #2 of 5 Old 12-24-2012, 06:30 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
I have seen mixed results with extender antenna's, I bought a second router on black friday for 10 bucks from Tiger direct and setup it up with DD-WRT as a repeater bridge. This would probably serve you better, it is a fairly simple process.
oman321 is offline
post #3 of 5 Old 12-26-2012, 12:34 PM - Thread Starter
RNaval's Avatar
Thanks for your response, tell me more about the DD-WRT repeater bridge setup, are all routers capable of this setup? How is this setup?
RNaval is offline
post #4 of 5 Old 12-26-2012, 04:28 PM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
I am not sure why you replaced your router's antennas. confused.gif I got a refurbished Cisco refurbished range extender for 39.99 and placed it around the center of the house. Now with the wireless router at one end the other end of the house has coverage as well. It seems I periodically have to unplug/plug it to reconnect bit not now I have coverage for using iPads in the bedroom. Pretty much plug and play for setup.
Gary J is offline
post #5 of 5 Old 01-03-2013, 07:41 AM
jimbo75's Avatar
Range extenders can help, but it depends on where your router is and where you are trying to get coverage. Stock antennas will tend to be more omni directional. High gain antennas work by focusing/directing the energy in a new pattern. (so you are sacrificing coverage in some directions to make it better in others) Ideally, you'd need to see the antenna patterns to know if it will help you.
jimbo75 is offline
