Sharing Wireless Connection Between TV and Blu-Ray player with ethernet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-04-2013, 01:25 PM - Thread Starter
jonwilliams88's Avatar
My smart TV is wireless connected to my home internet network. Is it possible for my Blu-ray player to access the same network if it is plugged into the TV with an ethernet cable?
I am using a Samsung BD-E5500 blu-ray player with a Samsung PN51E550D1F TV.
jonwilliams88 is offline
post #2 of 4 Old 01-04-2013, 03:17 PM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3975
I dont believe any TV allows sharing of its Internet capabilites like that.....
kryzchek likes this.
Ph8te is offline
post #3 of 4 Old 01-05-2013, 12:16 AM
kryzchek's Avatar
Quoted: 14 Post(s)
No, TVs don't have network hub abilities built-in. I'd suggest that you instead hard wire both the TV and BluRay player.
kryzchek is offline
post #4 of 4 Old 01-05-2013, 05:49 AM
theslydog's Avatar
Buy a cheap GB switch with 5 or 8 ports and sit it behind the tv. Run one cable from you router to the switch. That way you can hardwire every internet device in you lounge room to you home network. This will give you much better quality over all and wont clog you wifi for really portable things like phones and tablets.
theslydog is offline
