How can compressed Blu-ray rips be better quality than original? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 35 Old 01-09-2013, 07:44 AM - Thread Starter
Emmetpunk's Avatar
I have started to rip my entire Blu-ray collection to a personal library on my media player so the discs won't be damaged or torn by usage, and i was adviced to rip my Blu-ray discs with MakeMKV and not use any compression to get the highest quality.
These files end up being between 25-40GB big, but i have noticed that others have managed to get their Blu-ray rips looking better when compressed to around 10GB.
For example, the movie Downfall from 2004 is quite grainy in its original state on the Blu-ray disc and also grainy when ripped with MakeMKV with a size around 30GB, but i've seen HD screenshots of this movie that has been compressed down to 10GB and looks ten times better than the original.
What is the secret to this? How can a compressed rip look better in quality than a 1:1 rip? How much of a Handbrake-pro do you have to be to be able to achieve this?
Emmetpunk is offline
post #2 of 35 Old 01-09-2013, 08:08 AM
bluechunks's Avatar
Quoted: 144 Post(s)
Liked: 186
Short answer: unfortunately screen shots are not reliable at all when trying to determine quality--there are too many variables when a camera is pointed at a TV that it becomes difficult to distinguish between the quality of the video image (or lack thereof) and the quality of the photography (or lack thereof.)
In addition, there is no such thing as a free lunch so if you re-encode a file from 30GB to 10GB using the same codec you are going to lose....something. It might be texture detail. It might be smooth color gradients. But something will be lost. It's all a cost/benefit ratio and determining if the loss of the quality is acceptable (or even perceptible) in relation to the reduction in file size.
Often a noise reduction filter can be applied that will significantly reduce the "graininess" that also helps make the file more compressible. Of course, this can also have unintended consequences that are often noticeable as unnatural skin tones and textures.
IMHO, given the low cost of storage in 2013 I think you are following the correct path by using MakeMKV to keep the original encoding intact.
__________
Visio P65-C1 / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ / Speakercraft (Ceiling) / Hsu sub / Celerity 50' Fiber HDMI
bluechunks is offline
post #3 of 35 Old 01-09-2013, 09:36 AM
Kelson's Avatar
Quoted: 1976 Post(s)
Liked: 1164
Read the last 200 posts in this thread:
http://www.avsforum.com/t/1336046/ripping-blu-rays-ii/0_100#post_20457745
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #4 of 35 Old 01-10-2013, 04:14 AM
BSpielbauer's Avatar
I agree with BlueChunks 100%, above. As you know, the Blu-Ray is already compressed. Your goal should be not to do anything which might cause any further compression whatsoever. If you compress it further, I can promise it will not look "better" - it will only degrade. It will only appear worse.
And, one should never use a screenshot for picture quality comparison purposes, since there are way too many variables that have nothing to do with what is being viewed. You might use them for demonstration purposes ("look at how this shot was framed") but they are useless for trying to compare a quality of image.
BSpielbauer is offline
post #5 of 35 Old 01-10-2013, 05:42 AM
marcusj0015's Avatar
I've used MakeMKV extensively in fact, hell I've even created my own profile for ripping!
MakeMKV can't reencode video, therefore the video ripping is lossless, but it can (losslessly) compress the subtitles and audio, same quality as before, less space used. so no, not compressing your rips is a stupid idea, if your media will play from some sort of PC, then you can reencode to FLAC. here's a link to my MakeMKV profile incase you're interested.
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=5749
marcusj0015 is offline
post #6 of 35 Old 01-10-2013, 08:50 AM
jvarisco's Avatar
Literally impossible. Anytime you re-encode media in a lossy format you will degrade the image vs. the encoding source. Often the quality loss can be imperceptible though.
From a clinical perspective, this is also impossible. However, what you might be seeing is somebody who applied noise reduction to their re-encode. Despite what lots of people think, graininess in film is not an encoding artifact or error, it's part of the original image. Noise reductions will smooth out that graininess but also washes out a ton of detail. Some people prefer this look, although it's generally regarded as a bad thing by most "videophiles".
Here's a very common example:
The image on the left is far more accurate to what the original film looked like. The image on the right is after heavy noise reduction was done. Most people here would say the right side looks horrible, but there's a lot of people that prefer that look.
SuperFist and Majd Asi like this.
jvarisco is offline
post #7 of 35 Old 01-10-2013, 10:08 AM
Kelson's Avatar
Liked: 1164
Absolutely agree -- spectacular example images. Grain is a tool of the cinematographer and director, as much as is lighting and shading, and is used to convey the feeling and mood of the work that the director wishes to impart and draw you into.
But as you note, many people will look at those two images and think the one on the right must be the BluRay and the one on the left must be DVD (or even VCR). That's why they sell so many of those god-awful LED/LCD's with that eye-popping over-processed unnatural super-realism -- called the soap-opera effect -- that makes people stop and stare in the store at the cartoonish image and go ooooooooh, like Homer Simpson.
- kelson h
Kelson is offline
post #8 of 35 Old 01-10-2013, 03:14 PM
I prefer the right side. :O
SuperFist likes this.
post #9 of 35 Old 01-11-2013, 07:05 AM
Otter0911's Avatar
Quoted: 71 Post(s)
So on Handbrake if you set the RF to 0, your BD rip that was around 40gb is now 80gb. So what happens there? Is Handbrake removing compression?
Otter0911 is offline
post #10 of 35 Old 01-11-2013, 07:25 AM
olyteddy's Avatar
Quoted: 526 Post(s)
Liked: 926
No. Simply making a bigger file. Stuff that was taken away by 'lossy compression' (most video codecs) can never be restored. If you re-encoded it to uncompressed video (24 bit RGB) you'd use 49,766,400 bits per frame. At 60 FPS that's 2,985,984,000 bits per second. Even at those rates the PQ can be no better than the original. RF0 is simply lossless AVC (and being AVC will be smaller than un-compressed), but what you've already lost cannot be regained.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #11 of 35 Old 01-11-2013, 08:04 AM
Kelson's Avatar
Liked: 1164
I am not positive on this for Handbrake (but pretty sure) -- the mode of action is to take the file you give it and decompress it, frame-by-frame, to the fully rendered images in RAM then re-compress the rendered images using the settings you give it. So when you get a bigger file than the original it is because the compression algorithm/settings is "less efficient" or higher bitrate than the original compression scheme.
- kelson h
Kelson is offline
post #12 of 35 Old 01-17-2013, 03:44 AM
Yes, it's using more bits to represent each frame, BUT you cannot undo lossy compression (which every video format you'll run into is lossy) You're merely wasting space at best, and at worst, losing quality while taking up more space.
post #13 of 35 Old 01-17-2013, 09:11 AM
Kelson's Avatar
Liked: 1164
No matter how you slice or spin it, it is like making a photo-copy of a photo-copy.
- kelson h
Kelson is offline
post #14 of 35 Old 01-18-2013, 10:55 AM
Mark_Venture's Avatar
Quoted: 70 Post(s)
I wouldn't call myself (or my wife or son) a videophile, and I do use BD-Rebuilder to rip/convert my Blurays to 8-10 gig MKV files. When playing back the MKV's using our LG BD390 or BD570 players to my Sony 46" XBR6 it looks pretty good. In many cases our eyes can't tell the difference from the original bluray. But there are a few movies I can tell. And I would say that over all the quality looks no worse than watching the movies on HBO HD vs the original Bluray, but without some of the blockyness we see on fast motion scenes from Comcast compressing HBO HD.
The entire reason for ripping them to smaller MKV files? To getting more to fit on our home movie/media server. We can be in any room and watch any disc without having to run to the room where the DVD cabinet is and actually finding the disc.
I use BD-Rebuilder because it gives me a better image output than using something like Handbrake.
Mark_Venture is offline
post #15 of 35 Old 01-18-2013, 01:02 PM
Which is what I just said, in fewer details...
post #16 of 35 Old 01-18-2013, 01:03 PM
... They both use same rendering engine...
post #17 of 35 Old 01-20-2013, 08:36 PM
Quoted: 70 Post(s)
Thanks. While they may use the same engine, the output from BD-Rebuilder always seem to look better than what Handbrake gives me. Colors when using handbrake seem to get washed out, not as vivid. I'm not sure why, and since BD-Rebuilder works and looks great, I keep with it.
post #18 of 35 Old 01-24-2013, 10:23 AM
BD-rebuilder must use different options then, I've noticed something similar, i tried compressing 2012 from BD copy, to about 7GB and it looked great on my macbook, but on my TV you could see all of the banding in the colors, pretty badly especially in the opening Sun gradients.
post #19 of 35 Old 01-24-2013, 10:27 AM
GusGus748s's Avatar
Quoted: 417 Post(s)
Liked: 701
I re-encoded a BD movie that was 33 GB to 956 MB, and it looks just like 1080p on my iPhone biggrin.gif
GusGus748s is offline
post #20 of 35 Old 01-24-2013, 07:08 PM
olyteddy's Avatar
Quoted: 526 Post(s)
Liked: 926
If you stuck a piece of duct tape across half the screen you could probably have encoded it to 500 MB. tongue.gif
marcusj0015 likes this.
post #21 of 35 Old 01-25-2013, 02:47 PM
That's like saying you can enjoy watching CAMs if you removed your eyes and replaced them with a low-res black and white camera...
post #22 of 35 Old 01-25-2013, 05:32 PM
GusGus748s's Avatar
Quoted: 417 Post(s)
Liked: 701
I was being sarcastic!
post #23 of 35 Old 01-27-2013, 06:46 PM
Ooooh, Sorry, I was in an overly srs mood then. :c
post #24 of 35 Old 01-29-2013, 12:52 AM
Av8tr's Avatar
I use Bdrebuilder and often compress down to 4.3gb. The significant others don't noitice at all. I really can't tell much difference either. For my really favorite movies I compress to 23gb. I use iso btw and stream with the Netgear 550. Terrible machine but does one thing flawlessly; streami iso's.
Av8tr is offline
post #25 of 35 Old 01-29-2013, 03:04 AM
dmusoke's Avatar
Quoted: 351 Post(s)
Liked: 179
So MakeMKV will make files with identical audio/video quality as the original bluray, even those encoded at more than 40Mbps?
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #26 of 35 Old 01-29-2013, 03:08 AM
dmusoke's Avatar
Quoted: 351 Post(s)
Liked: 179
So MakeMKV will create bit-for-bit identical audio/video files to the original bluray, right? No loss when making MKV files?
dmusoke is offline
post #27 of 35 Old 01-29-2013, 08:00 AM
elario's Avatar
Quoted: 43 Post(s)
Liked: 66
Correct. It takes the selected video, audio and subtitle streams and remuxes them into a MKV container. It doesn't change or re-encode them.
elario is offline
post #28 of 35 Old 01-29-2013, 11:21 AM
dmusoke's Avatar
Quoted: 351 Post(s)
Liked: 179
Thanks elario ...what a relief indeedsmile.gif!
dmusoke is offline
post #29 of 35 Old 05-30-2017, 01:51 PM
SuperFist's Avatar
Quote:For example, the movie Downfall from 2004 is quite grainy in its original state on the Blu-ray disc and also grainy when ripped with MakeMKV with a size around 30GB, but i've seen HD screenshots of this movie that has been compressed down to 10GB and looks ten times better than the original.
According to the website at the link below, the version on the right IS an image of the Blu-ray with the left being the DVD! Something smells fishy in this old thread!
https://ryesofthegeek.wordpress.com/...perils-of-dnr/
SuperFist is online now
post #30 of 35 Old 05-31-2017, 04:15 PM
Jon S's Avatar
Quoted: 870 Post(s)
Liked: 277
for some reason, the image above seems to be in reverse order from the original site... see below
Regarding the use of Handbrake... If you use the Super HQ encode, you can get darn good image quality at about 4-5 GB in file size, very little loss but at the expense of time to encode... It can take 2-3 hours on a i7 running at 4 GHz. It would be interesting to see how fast the encode will be on the new $2000 Intel Core i9 18-core CPU compared to my 4-core CPU...
If it's not a BIG screen, it's not a theater...
Jon S is offline
