cant install xtreamering xtreamer live on xtreamer pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-18-2013, 03:08 AM - Thread Starter
Oren Gozlan's Avatar
Hi
when trying to install xtreamer live! project on my xtreamer pro (2.7.1) - the device always boot's after "installation" (after downloding 1.3.3) from the www.
after reboot - again it says that project is not installed and going all over again from start...
any ideas?
Oren
Oren Gozlan is offline
post #2 of 14 Old 01-29-2013, 10:00 PM
Peter Renaud's Avatar
I have the same problem on 2.7.0. I agree to the download, click on install then I get the same message that repeats.
Peter Renaud is offline
post #3 of 14 Old 02-02-2013, 01:26 AM
Oren Sasson's Avatar
I have the same Issue with 2.7.0
Streamer Pro stuck and require unplugging from power in order to work again .
Oren Sasson is offline
post #4 of 14 Old 03-23-2013, 08:20 AM
luca morelli's Avatar
Anybody managed to get this working?
I am on the same firmware version and get the same result
Cheers
Luca
luca morelli is offline
post #5 of 14 Old 03-31-2013, 08:48 AM
Rich Wilson's Avatar
Has anyone had any success with this? I've been to loads of forums and everyone is having the same problem, but I see no solutions. You are forced to update to 1.3.3 in order to use Xtreaming. It doesn't work, and so you end up not able to use the Xtreaming on the Xtreamer Pro. Defeats the object of having an Xtreamer Pro.
I've been in touch with Xtreamer, and as yet had no reply. Has anyone? This is crazy that so many people are having this problem, and Xtreamer are doing nothing about it.
Rich Wilson is offline
post #6 of 14 Old 04-04-2013, 09:07 AM
joekom's Avatar
finally worked it out you need to turn on ftp then using a computer copy the script and perl sub folders from the script folder directly onto your main hdd ,it will ask if you want to replace the srcipt folder say yes. xtreamering now working.biggrin.gif:D:D:D
7reales likes this.
joekom is offline
post #7 of 14 Old 06-18-2013, 11:16 AM
7reales's Avatar
Hello Joekom!
I'm a noob here and i'm having a hard time updating my xtreamering. I hope you can explain more on how to fix it. I got lost in the "using a computer". do I have to connect my xtreamer to my laptop? how? I'm really sorry but I hope you can help me out. I only use my sidewinder for watching HD movies.
Thank you very much!
7reales is offline
post #8 of 14 Old 08-14-2013, 01:56 PM
MX5GT's Avatar
Umm what were the steps you did you get it to work? I have the latest firmware.
1) I Downloaded the current Xtreaming zip file and unzipped it [Xtreamering_1.3.4]
2) I enabled the Http login and setup the userid and password
3) I enabled FTP server
4) I connected with Ftp client from my home pc to the Xtreamer Pro.
5) I deleted all existing files below the scripts folder on the xtreamer pro.
6) I ftp'd the local files from the folder [Xtreamering_1.3.4] to the xtreamer pro under Scripts folder.
7) I rebooted xtreamer pro.
8) Still the same says I do not have a current version installed. It downloads and tries to install V1.3.3 but it does not work.
HELP!
MX5GT is offline
post #9 of 14 Old 09-30-2013, 02:42 AM
MechWolf's Avatar
Yes!
Joekom was right; this is THE way.
Just download
http://forum.xtreamer.net/topic/34113-xtreamer-xlive/page__p__262523__hl__xtreamering__fromsearch__1#entry262523
Then copy the script map to the ROOT of your HD in your Xtreamer (in my case there were two scipts directories and I merged them on the root of my HD)
It should look like this; MYXTREAMER/SDA1/SCRIPTS/Xlive
not like this; MYXTREAMER/SDA1/SCRIPTS/SCRIPTS/Xlive
Then open the install.php in the Xlive directory using Iexplorer. Reboot the Xtreamer and then it should be working (took me 4 hours, so don't shout if it doens't work on your first try ;)
Ik hope this helps!
MechWolf is offline
post #10 of 14 Old 09-30-2013, 10:50 AM
MX5GT's Avatar
Thanks a lot! That worked. I guess there is a problem with the directories during the install somewhere.
And as I expected, the apps in the Xtreaming seem to be very unfinished. I was hoping just to get the YouTube player working with by youtube account.
I'll try it again...
Thanks again for helping me....It was bugging me that I could not it installed.
MX5GT is offline
post #11 of 14 Old 09-30-2013, 12:03 PM
MechWolf's Avatar
Glad I could help!
I signed up to this forum just to post this. There are lots op people with this issue and no where seems the answer; untill now! It took me a while to get it working but I was not sure if my solution would provide help to others. Thnx for the reply and have fun!
Any idea how to get other skins? There should be a skin tool out there but a lot of threads are aclready closed or unavailable.
MechWolf is offline
post #12 of 14 Old 11-07-2013, 05:21 PM
cadu1981's Avatar
Hello. I am trying to do all the steps, but when i go to
(5) For xLive: run from the web browser from Mozilla, Opera, Internet Explorer (hxxp = http) this url: hxxp://xtreamer_ip_adress/media/sda1/scripts/xLive/install.php
it opens a blank page. its it normal?
cadu1981 is offline
post #13 of 14 Old 11-07-2013, 05:33 PM
MX5GT's Avatar
Yes. That is what happened for me too. There is no response after executing that URL.
MX5GT is offline
post #14 of 14 Old 11-08-2013, 04:00 AM
cadu1981's Avatar
so can you do it another way?
I have in my xtreamer sidewinder 1 one HDD. It should be there yes? Because when i bought it dont have anything.
This should be place here?
cadu1981 is offline
