Basic kbps/compression question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-22-2013, 10:35 AM - Thread Starter
Electricide's Avatar
I am converting a screen capture video to wmv. There are two options, Video 9 and Video 9 Screen.
now, each resulting wmv video is the same frame size, same fps, and same kbps, but the resulting files are of a vastly different size; the "screen" wmv is like a third of the size.
My understanding was that the kbps, multiplied by the duration, gave you total file size, and that the visual quality really depends on how many fps and how much motion you tried to cram into each second.
but here I have same video, length, and kbps and the file sizes are different. I can only assume that the "screen" version actually dips far below the target kbps when it can. right? and that the kbps I selected is only a "maximum" threshold?
Electricide is offline
post #2 of 7 Old 01-22-2013, 01:07 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Electricide,
It is actually much more complicated than that. I don't know too much about WMV, but MPEG uses over a dozen algorithms to compress video. Besides the items you mentioned, the final size would depend on the complexity of the image, the desired "quality" of the final video, the amount of motion in the video, and the number of "reference" frames included, among other factors.
The difference in size that you are seeing could be due to attributes that may or may not be visible in the video, like reference frames or motion encoding.
MarkHotchkiss is offline
post #3 of 7 Old 01-23-2013, 10:51 AM - Thread Starter
The complexity of the image would only affect file size if you have a VBR setup, right? Now, if the resulting video is unwatchable, I might decide to go back and re-encode at a higher rate (use a different motion factor in the Kush gauge calculations) or change the key frame frequency. Different codecs would manage compressing motion better than others, sure.
Here are two network impact graphs for the two different videos during streaming viewing.
Video 9
Video 9 Screen
That sure looks like CBR and VBR respectively.
But, Mediainfo shows the video 9 as
File size : 4.65 MiB
Duration : 1mn 16s
Overall bit rate mode : Constant
Overall bit rate : 511 Kbps
Maximum Overall bit rate : 514 Kbps
and the Video 9 screen as
File size : 2.08 MiB
Duration : 1mn 16s
Overall bit rate : 230 Kbps
not sure how you have a CBR with such a different between overall and maximum bit rate....
post #4 of 7 Old 01-23-2013, 01:28 PM
Liked: 85
Hi Electricide,
Right.
However, I have never heard of a constant bit-rate video compressor before, but as I said, I am not very familiar with WMV. CBR doesn't make sense to me for video, as the amount of image data is never constant. Probably the point of CBR video is to vary the quality of the compression in order to limit the bit-rate to some selectable maximum rate.
So VBR might give you constant quality with a varying rate, while CBR would give you constant rate with varying quality. I'm just speculating now . . .
post #5 of 7 Old 01-23-2013, 02:14 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
How do you figure that? From your post #3
Duration : 1mn 16s
Duration : 1mn 16s
The Video9-screen has less than half the bitrate of the Video9.
If you multiply out the average bitrate times the duration and appropriately divide by 1024, you get the file sizes that are listed. That may be how MediaInfo calculates an average bitrate in the first place.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #6 of 7 Old 01-24-2013, 03:40 PM - Thread Starter
If the video portion was indeed encoded at 230 then that's a flaw in the software. I selected 500 kbps as the output quality. and if I right-click/properties the wmv file, the details show 500kbps as the data rate. Maybe windows media player is just going by the intial lump of data (reflected in that graph).
FYI this is the export functionality from the WebEx Recording editor, for editing and converting desktop recordings made with webEx Recorder. There's a kbps drop down selector, and identical settings were selected for each export.
And from what i've read CBR is preferred if you are concerned about predicatable network impact, not varying content quailty, motion, and spikes in kbps that affect buffering or QoS. I'm working in a govt facility so this is important.
thanks for your input everyone.
post #7 of 7 Old 01-24-2013, 04:36 PM
Kelson's Avatar
Liked: 1147
If the video portion was indeed encoded at 230 then that's a flaw in the software. I selected 500 kbps as the output quality. and if I right-click/properties the wmv file, the details show 500kbps as the data rate. Maybe windows media player is just going by the intial lump of data (reflected in that graph)..
The overall bitrate from MediaInfo includes all the streams. You can select a display that will show you the avg bitrate for just the video stream and for just the audio stream.
- kelson h
Kelson is offline
