Connecting ROKU LT to DVI-D TV Input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2013, 09:58 AM - Thread Starter
Zman10101's Avatar
I am searching for an adapter or cable to connect the HDMI output of a ROKU LT to a Magnavox 26MF605W TV with a DVD-D input. The image below shows the configuration of the DVD-D input on the TV. My problem is that I can not find a male DVI-D connector that matches.
In the TV User Guide the diagram of the DVI connector shows a horizontal flat pin while on the TV it is vertical. Any help with this is greatly appreciated. Thanks.
Zman10101 is offline
post #2 of 2 Old 01-23-2013, 12:55 PM - Thread Starter
Zman10101's Avatar
I got this reply from John in the HDTV forum:
Originally Posted by ctdish
The large pin is the analog ground used when the connector has a VGA signal on it. The Roku or any HDMI source doesn't have use the analog pins so you should be OK by just cutting the large pin off and use the cable or adapter without it. Here is a link to an HDMI to DVI wiring pinout: http://pinouts.ru/VideoCables/hdmi_dvi_cable_pinout.shtml
John
