Dune 301W, Windows Server 2012 Essentials, FLAC/MKV how to get to work? Other choices? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-27-2013, 11:08 AM - Thread Starter
Eric_Connelly's Avatar
Quoted: 96 Post(s)
Liked: 35
I bought a Dune 301 for the bedroom last night.
Apparently Dune does not support SMB Authentication so it requires anonymous access. I tried setting it up but no luck. I'm not really crazy about that anyways since we run a domain environment here at home.
So I installed Server 2012 Essentials in a VM and for the Media Server working. However it will not play FLAC/MKV which is 99 percent of our stuff.
I've ready about the Windows Media packs and that but they seem to be for Win8, not for Server 2012.
Is there a solution? Does it require transcoding? Is there another UPNP Media Server out there that does not require transcoding, will run as a service, and not utilize Java?
I tried Plex but had a lot of problems with IE10 on 2012 even with IESC turned off. I do not have the CPU for transcoding, its running on an ESXI 5.1 server and I'd be running this strictly for media sharing.
Eric_Connelly is offline
post #2 of 3 Old 01-28-2013, 02:01 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Here is a review done by dbone1026 / Damian.
http://www.mediasmartserver.net/2012/08/02/review-dune-hd-tv-301/
May be he can help you out. I know that the 301 unit has some audio bugs and that there is a patch for it, but I am not sure if this works or not. Apparently, the patch isn't very helpful in certain situations according to the review.
GusGus748s is offline
post #3 of 3 Old 01-28-2013, 04:15 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
Mezzmo, Twonky, TVMobili are UPnP/DLNA servers that do not require Java and run under Windows at least the desktop versions.
Do you mean flac/mka audio files or video/mkv with flac audio tracks, I thought the Dune would support videos with flac audio.
Alx330 is offline
