CONCEPT: Foxconn nT-A4000 Media System - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Would you consider buying the barebone unit for $289.00?
YES 1 100.00%
NO 0 0%
Voters: 1. You may not vote on this poll
Old 02-13-2013, 10:08 PM - Thread Starter
octogonpc's Avatar
Greetings,
I recently submitted a feature request to FOXCONN in reference to their line of NanoPC Book-sized Units. I love the size of these units and they have all the connections you need, however one type is missing, a version with a bay for a slim optical drive (and potentially an external hot-swappable 2.5" drive). I provided them the proposed specs, however I'm posting the concept image of the proposed device here to get feedback to direct to Foxconn (especially IF it is positive). So without further ado, I present the CONCEPT NanoPC nT-A4000:
PROPOSED SPECIFICATIONS:
Series: Brazos
Dimension: 190(W) x 135(D) x 40(H)mm
Processors Supported: AMD Dual Core E2-2000 1.75GHz APU
Chipset: AMD A45 FCH
Memory Supported: One SO-DIMM Socket support DDR3-1333 up to 8GB
VGA Graphics: AMD Radeon HD 7340 support DX11
Storage Interface: Three SATA III connectors for 2.5"HDD or SSD and one Optical Drive
LAN: 802.11n Wi-Fi wireless networking
Front I/O: Two USB 3.0 ports
SD/SDHC/MS/MS Pro/MMC 5 in 1 Card Reader
Audio line in 3.5mm jack (digital/analog)
Headphone 3.5mm jack
Back I/O: Gigabit LAN port
Four USB 2.0 ports
Audio line out 3.5mm jack (digital/analog)
HDMI port support up to 1920x1080 resolution
DVI port (support VGA out via DVI to VGA Adapter)
octogonpc is offline
