*Official* Dune HD TV303D/ Base 3D Streamer Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #361 of 1610 Old 06-14-2013, 09:44 PM
apw2607's Avatar
Quoted: 305 Post(s)
Liked: 339
Originally Posted by dbone1026 View Post
So it only happens when you switch audio tracks while watching a movie?
I know there was a nasty DTS bug when the TV303D first came out that I experienced (movies like Star Wars where I seriously thought my speakers were going to blow out) but with teh updates it got fixed for me
No. Not exactly. Consider a bunch of video files that are played in a playlist. Some of the vidoes may have different audio formats ... PCM, DD 5.1, DD 2.0, etc ... It just seems like pot luck what you get. In some instances all plays fine... On other occasions you get white noise when the new file begins playing.
And that's my problem. Bunch of music vidoes In a playlist being played in shuffle. At some point the dune starts playing white noise. Makes the dune unusable in this use case.
apw2607 is offline
post #362 of 1610 Old 06-16-2013, 09:50 AM
L33TX43RT's Avatar
Just received my unit, yesterday evening - I love it. However, the only concern right now, is why yaDIS takes "watch paint dry" FOREVER to export the data, unless there's something I'm doing wrong? At first, I had the unit connected to the slave 3.0 port to my notebook to transfer the data, unless there's a quicker way? I figured this would be quicker than sending it over WiFi, while the unit is in my living room connected locally to the hard drive.
L33TX43RT is offline
post #363 of 1610 Old 06-16-2013, 11:06 AM
jconjason's Avatar
Quoted: 756 Post(s)
Liked: 1362
yaDIS is fine for me when exporting. Maybe a few minutes tops for all my movies(4tb's worth). Not sure what's going on with your settings/connections. I have my Dune hard wired to router, my NAS as well.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is offline
post #364 of 1610 Old 06-16-2013, 11:37 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
I use Zappiti. If I do a full export (11 TB) it will take about 10 min. the most. If I only do 5 or 10 movies at once it only takes about 30 sec. to export.
GusGus748s is offline
post #365 of 1610 Old 06-16-2013, 03:48 PM
L33TX43RT's Avatar
That's impressive. I only have about 2.5 of a 3TB drive full, and it's taking forever. Would it be because I don't have a gigabit router? I'm currently using a WiFi-n router.
post #366 of 1610 Old 06-16-2013, 04:04 PM
iamloco724's Avatar
Quoted: 16 Post(s)
i just got the base 3d to test out along side the d1 a few questions
withing the source list where it list my drives can i change the view of that i cant seem to find out how i want it as a list if possible, i have the folders within the drives as list but can figure out if i can set the drives them selves to show as a list
when i hit info when playing a file i get all the video states how do i get the audio i accidentally did it once and cant figure out how i did i mean the audio type/bit rate etc like the video info
if anyone is familar with the 3tb issues ive been having the d1 i can confirm that the 3tb external works fine with the based 3d
are they working on the following bugs currently that ive noticed just from playing with it for a few min, i wont be testing files really till later this week but ive noticed
when put in standby i cant get it back up i have to flip the switch on the back to restart
and the mkv micro stutters
are they working on fixes for those?
iamloco724 is offline
post #367 of 1610 Old 06-16-2013, 04:54 PM
altcool's Avatar
Are you storing the meta data on the Dune or on your nas. With my dune smart I export the meta data to the dune USB drive and it also takes hours. My media is stored in my NAS ~5tb all hard wire Gbit.
SR6010; DHC-80.2; SR8500; TX-SR606; BDP-51FD; DVP-CX995V; PS3; JBLStudio7.1; SmartH1; OuyaKodi; NUCKodi; HC800; (3)HC300; HC250; (4)SR260; SlingBoxProHD; HLP-5685w; TC-P50S60; HLS-4676S; SK-32H240S; LTV-32w6; GW2750; FP222WH; LTV-19w6; UnRaid; DS411+; XT1095; XT1034; Nexus7
altcool is offline
post #368 of 1610 Old 06-16-2013, 08:24 PM
jconjason's Avatar
Quoted: 756 Post(s)
Liked: 1362
You could try removing the usb drive and plug into pc for exporting, then plug back into the dune.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
post #369 of 1610 Old 06-17-2013, 02:25 AM
twa00's Avatar
I have the 303D (but it,s the same hardware) - I constantly put t in standby (and back) with no problems.
My MKV,s don,t stutter.
What firmware are you on? B6 130515 is latest.
twa00 is offline
post #370 of 1610 Old 06-17-2013, 04:06 AM
merc10's Avatar
My base 3d does the same thing with the power off.If i set power off to full off,have to switch it off and on from back.If set to standby soft off,you can here the thing humming.
Latest firmware being used.Some MKVs stutter.Not many.
merc10 is offline
post #371 of 1610 Old 06-17-2013, 07:47 AM
Mr Eric's Avatar
Quoted: 305 Post(s)
Liked: 145
do you have it set up to boot to a jukebox folder which is on a NAS ?
Mr Eric is offline
post #372 of 1610 Old 06-17-2013, 11:32 AM
iamloco724's Avatar
Quoted: 16 Post(s)
im on the latest non beta
the stutters dont happen in every mkv and sometimes people can miss them but they are there
there having the same issues on the popcorn hour players the 300/400
post #373 of 1610 Old 06-17-2013, 12:37 PM
Mr Eric's Avatar
Quoted: 305 Post(s)
Liked: 145
Latest non beta ? So you are using the original firmware ?
You should update to the latest b6. It won't correct the mkv problems but might correct others.
Mr Eric is offline
post #374 of 1610 Old 06-17-2013, 12:43 PM
iamloco724's Avatar
Quoted: 16 Post(s)
i will confirm my firmware in a bit
anyone help with this
within the source list where it list my drives can i change the view of that i cant seem to find out how i want it as a list if possible, i have the folders within the drives as list but cant figure out if i can set the drives them selves to show as a list
when i hit info when playing a file i get all the video stats how do i get the audio i accidentally did it once and cant figure out how i did i mean the audio type/bit rate etc like the video info
post #375 of 1610 Old 06-17-2013, 01:02 PM
Skylinestar's Avatar
Quoted: 1214 Post(s)
Liked: 227
I don't think that's possible. The info button on the remote control only shows the video stats.
I think you must have hit the info/status button on your AVR instead.
Skylinestar is offline
post #376 of 1610 Old 06-17-2013, 01:04 PM
iamloco724's Avatar
Quoted: 16 Post(s)
nope it definitely was through the dune was in the same type of box as the video stats just came up under it on screen
post #377 of 1610 Old 06-17-2013, 02:49 PM
merc10's Avatar
No boots to jukebox on an internal hdd
merc10 is offline
post #378 of 1610 Old 06-19-2013, 03:25 PM
mrkeeling's Avatar
Will TV303d work with Mediasonic pro 4-bay enclosure and recognize all 4 discs if attached to one of USB ports on 303d?
Anybody successfully using it?
mrkeeling is offline
post #379 of 1610 Old 06-20-2013, 01:24 AM
Mr Eric's Avatar
Quoted: 305 Post(s)
Liked: 145
I know may people using this enclosure (even the 8-bay) without any problem with mixed size HDD (2 or 3TB). You can go for it wink.gif
Mr Eric is offline
post #380 of 1610 Old 06-20-2013, 05:59 AM
mabuk's Avatar
Quoted: 12 Post(s)
I had stutters with a few MKV's, I fixed it by re-muxing them using mkvmerge and put the FPS as 24000/1001 or 24fps (depending whether mediainfo said 23.976 or 24fps) in the 'format specific options' for the video. This same problem occurred with my other Sigma based player (WD TVsmp). It might be worth a try.
mabuk is offline
post #381 of 1610 Old 06-20-2013, 08:38 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Lately a few of my MKVs have been stuttering, which they never had before. I'll play them again and if they stutter I'll try it out.
post #382 of 1610 Old 06-20-2013, 10:30 AM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
Ye seems all sigma players are effected by micro stutter and only way to fix it is to 24000/1001 the fps. hopefully they start fixing it.
halfelite is offline
post #383 of 1610 Old 06-20-2013, 01:34 PM
L33TX43RT's Avatar
Having issues connecting Dune to a shared folder, via SMB. Please help! MY Windows 7 Home Premium does not support NFS. mad.gif
The drive works fine connected directly to the Dune, but I prefer the drive connected to my laptop, transmitting the data to the Dune wireless. The drive is a Seagate USB 3.0 3TB Expansion Drive. I can get the Multimedia Devices tab to work when the Dune is connected through Wired Ethernet, yet I prefer not to work through Windows Media Player's Library.
post #384 of 1610 Old 06-20-2013, 01:41 PM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
I use Hanewin NFS server. Hanewin is cheap, runs on Windows 7, and works very well.
Looky here!
robnix is offline
post #385 of 1610 Old 06-20-2013, 05:52 PM
L33TX43RT's Avatar
I've tried this program, and all the options are gray'd out - I can't change anything.
post #386 of 1610 Old 06-20-2013, 06:14 PM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
0
The service probably isn't started.
Try this:
http://mrlazy.wordpress.com/2009/08/04/how-to-setup-nfs-shares-on-wd-tv-using-hanewin/
Looky here!
robnix is offline
post #387 of 1610 Old 06-20-2013, 09:53 PM
dfriend's Avatar
I had trouble with Win 7 too. What tripped me up was getting the sharing permissions right.
All my stuff is under C:\Video so I had to right click on that folder in explorer, select "Share With" and then "Specific people..." Then in the pop-up window there's an empty pulldown next to a greyed out "Add" button. Click the pulldown and select Everyone, then hit Add.
There were at least 2 other places I think were I was trying different things regarding sharing that had nothing to do with the permissions for that folder. Very annoying.
And after all that I ended up putting a 3TB external USB drive on the Dune anyway. I don't have ethernet between Dune and the PC and my wireless isn't fast enough for streaming blu-ray.
dfriend is offline
post #388 of 1610 Old 06-21-2013, 01:20 AM
bjoroy's Avatar
NFS is in fact included in Windows 7, it's just not installed by default.
Copy/paste from answers.microsoft.com:
In order to activate the Client for NFS, go into the Control Panel, and go to "Programs and Features". In the left hand column, you'll see a link for "Turn Windows features on or off".
Select that, and it will open a list box that shows all of the optional components built in to Windows 7. Some are already activated. Expand the entry for "Services for NFS". There are two check boxes under that. Check them and hit OK. Windows will install those components and ask to reboot your system. Once you have rebooted, Client for NFS will be installed.
To use it, go to Administrative Tools->Services for NFS to configure it. Alternatively, you can use the command line program 'nfsadmin' to configure.
Philips 21:9 Cinema 58PFL9956T | Dune HD Base 3D | Yamaha RX-V465 | Audio Pro PM-09S 5.0 | Dali Concept SUB
bjoroy is offline
post #389 of 1610 Old 06-21-2013, 05:12 AM
L33TX43RT's Avatar
Client for NFS is not included with Windows Home Premium.
post #390 of 1610 Old 06-21-2013, 05:45 AM
Mr Eric's Avatar
Quoted: 305 Post(s)
Liked: 145
NFS is absolutely not needed...and effectively only present in WinPro, not winHome.
@L33TX43RT : check your windows sharing setup and be sure that you use 40/56bits encryption and not 128bits (default). Then share only folders and not your complete drive (right click on folder to share/share with/advanced share/share with everybody). Once done go back to your dune and try through smb browsing. If it's still empty (high chances it's empty...), then you will need to create a network shorcut to your newly shared folder. Press popup menu on your remote/create network shortcut, fill in all details and it should work (login and password if you use one, or "guest" as login and password empty).
Network shortcuts are the only way to be sure 100% that you can see you shared folders on your PC. Browsing is most of the time not working.
Mr Eric is offline
Dune Hd Tv303d Wifi 3d Streamer
