*Official* Dune HD TV303D/ Base 3D Streamer Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1081 of 1603 Old 03-01-2014, 04:23 PM
ddiehl's Avatar
Quoted: 18 Post(s)
Originally Posted by dbone1026 View Post
PLay with full menus
What if it contains no menus- just the title? Probably a dumb question, but just want to be sure..
ddiehl is offline
post #1082 of 1603 Old 03-01-2014, 06:18 PM
Skylinestar's Avatar
Quoted: 1046 Post(s)
Liked: 182
Anyone has problem playing BD folder structure on the TV303D? On lite-playback, when a track is playing, I can't jump to the next track. frown.gif
Skylinestar is online now
post #1083 of 1603 Old 03-02-2014, 08:29 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Correct
As in you can't go to the next chapter, or are you trying to go to a different title on the disc?
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #1084 of 1603 Old 03-02-2014, 06:31 PM
Liked: 182
Correct
Each track has its own m2ts file.
In this case, I want it to play the next track automatically, ie the next m2ts file.
post #1085 of 1603 Old 03-03-2014, 03:39 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I believe for that you need to pull up the BD Lite menu and manually select the next title/track, it is not like skipping chapters in a movie
Cheers,
Damian
post #1086 of 1603 Old 03-08-2014, 07:59 AM
jr0dd's Avatar
Quoted: 29 Post(s)
Woke up to a new firmware being available date 140223 b6 it reboots to install but never installs. The lcd screen just keeps saying "wait" and never begins the update process. After a few minutes of nothing I shut it down with the switch in back and turn it back on. Came back up fine thankfully. I dunno what's up with this update though it won't install for me. Gonna do a factory reset first and see if it will install then.
So there are 2 updates available. The beta B8 and B6 which looks like it's supposed to be the stable version. B8 is installing just fine.
jr0dd is offline
post #1087 of 1603 Old 03-08-2014, 08:22 AM
SJSJ's Avatar
B8 Installed ok for me as well.
Pressing the INFO button while some media file is playing now gives you the filename of the source across the top of the screen.
That's a start, since my ancient TViX 6500 does that and gives audio/video info as well, where the Dune only provides video info.
SJSJ is offline
post #1088 of 1603 Old 03-18-2014, 07:52 PM
MagicMan3's Avatar
I'm thinking of picking up the Base 3d player and have a couple questions.
1) can someone please give me the physical size of the unit?
2) All my media is from network share on my 30+ TB of storage, in Xbmc I can have separate tabs on the main screen for 3d, 2d and tv shows which are all in different network folders, can I do the same with the Dune HD Base 3d?
3) Will it scrape cover art like Xbmc does or do I have to do it manually like I did with my old wdtv's?
Thanks for any info.
MagicMan3 is offline
post #1089 of 1603 Old 03-18-2014, 08:59 PM
leo5111's Avatar
Product Dimensions: 5.5 x 14.2 x 5.5 inches ; 5.1 pounds
leo5111 is offline
post #1090 of 1603 Old 03-18-2014, 09:10 PM
MagicMan3's Avatar
Yeah, I googled those dimensions as well, don't get the impression that its 5.5" tall
Found these dimensions 430 x 252 x 49mm (2.2"tall) at http://dunehd.co.za/files/2011/11/DUne-Product-Comparisons.pdf
Can someone confirm the height?
post #1091 of 1603 Old 03-18-2014, 09:16 PM
leo5111's Avatar
leo5111 is offline
post #1092 of 1603 Old 03-18-2014, 09:27 PM
MagicMan3's Avatar
I got those as well... from the link I provided it shows different. rolleyes.gif I'd like someone that has the unit to confirm the size as height is a limit I have.
A lot of vendors had the size of the box of the speakers I bought, not the actual speaker size
post #1093 of 1603 Old 03-18-2014, 09:27 PM
SJSJ's Avatar
1) Approx 2" tall, 16 3/4 wide, 10 deep
2) Probably if you learn the "media_url" concept.
3) It doesn't scrap squat, but you can get programs like Zappitt,TViXiE, Dune Explorer, Yadis, Dune Flash Interface, ... that do scrap. Zappitti is the most inflexible pile, IMO.
My 2 cents, I don't recommend Dune Base 3D (and never will). It's a poorly engineered. You'd be lucky to get one that doesn't have the dreaded restart problem.
SJSJ is offline
post #1094 of 1603 Old 03-18-2014, 09:43 PM
MagicMan3's Avatar
1) Meets my needs.
2) For the rumored video quality increase, not worth the loss of functionality/customization from xbmc
3) Auto scraping is nice, but not a must have.
Thanks for the info, this isn't the product for me. I'm sticking with the xbmc platform for now
post #1095 of 1603 Old 03-18-2014, 09:45 PM
SJSJ's Avatar
That Amazon measurement is pure rubbish.. I physically went to my box and measured it.
SJSJ is offline
post #1096 of 1603 Old 03-18-2014, 09:47 PM
leo5111's Avatar
figures...tongue.gif well im eyeballing a streamer what do you recomend? i was looking at a popcorn a410 BUT at moment only dealer to get 1 in usa Cloud Media is having issues sending em to usa apparently
leo5111 is offline
post #1097 of 1603 Old 03-19-2014, 02:27 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
2. yes you can do so with yadis at least (i think you can do it with other jukeboxes by using some kind of personal category)
3. no autoscrap for dune players, you need to use a third party jukebox that will scrape your movies/tv series like you used to do it with your wdtv. Biggest players for jukebox are yadis, zappiti (only if you by a zappiti player, won't work on a Dune even if it's exactly the same product), mymovies, dune explorer, DFI. yadis is the most customizable one IMO and should give you the look and feel of xbmc (but don't dream, you will never find something really close to xbmc on a dune).
Mr Eric is offline
post #1098 of 1603 Old 03-19-2014, 04:57 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
My understanding the restart problem has been fixed
Cheers,
Damian
post #1099 of 1603 Old 03-19-2014, 08:04 AM
MagicMan3's Avatar
This does peak my interest again. I just wish there were places around that had them setup so I could go in and play with it.
I have my Nuc sold if I decide to so the cost difference is minimal, but if I hate the interface that wouldn't be worth the money.
post #1100 of 1603 Old 03-19-2014, 09:00 AM
SJSJ's Avatar
After the last firmware upgrade b8, my unit is working worse (more restart errors and more freezes with mkv movies requiring reboots) then any prior firmware.
SJSJ is offline
post #1101 of 1603 Old 03-19-2014, 09:06 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
This yadis running on a dune
Everything on the menu first raw after Films/Series Tv are personal shortcuts created by the user. You can use it to add your own personal categories like 2D, 3D, Mom's fav', for kids or whatever you want.
Of course this is just one layout and you can find many different templates here : http://www.mpcclub.com/forum/showthread.php?t=28388
Mr Eric is offline
post #1102 of 1603 Old 03-19-2014, 10:17 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
That layout looks pretty nice.
GusGus748s is offline
post #1103 of 1603 Old 03-19-2014, 10:19 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
the handling of tv series has always kept me from yaDIS, although that could have very well changed by now since it has been a while since I looked at
Cheers,
Damian
post #1104 of 1603 Old 03-19-2014, 10:24 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I agree. Lately, I've been using 10Muse + iPad app, and my kids and wife like it as well. I still update the yadis and Zappiti as well....I'm not sure why I do it since I haven't used them in a long time.
post #1105 of 1603 Old 03-19-2014, 10:49 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I actually hadn't used 10Muse in a while, went to set it back up and the movies was pretty much a breeze. I forgot though how much I hate the TV show setup initially where you have to copy the tvdb url for each show, so I just stopped there. I should get the iPad app back up and running though as now my boys have been operating the Dune more of late
Cheers,
Damian
post #1106 of 1603 Old 03-19-2014, 12:34 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I got used to it so now it doesn't really bother me.
post #1107 of 1603 Old 03-19-2014, 12:43 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Yeah, just sucks when you have 40+ tv series that you have to set up at first. Got through about 5 and got tired of having to go to tvdb, search for TV show, copy url, paste in 10Muse, wait for it to scrape all data, and then move on to the next show...
Cheers,
Damian
post #1108 of 1603 Old 03-19-2014, 12:53 PM
MagicMan3's Avatar
Thank you, that does give the functionality that I'm looking for. Now if the reboot issue mentioned earlier can get resolved...
post #1109 of 1603 Old 03-19-2014, 12:58 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
As I mentioned, I thought it was resolved and not present in the new stock of players (I could be incorrect, this is just from talking to one of the distributors)
Cheers,
Damian
post #1110 of 1603 Old 03-19-2014, 01:16 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
That sucks. I only got 5 TV shows. This is probably something you could request and the next 10Muse update.
Dune Hd Tv303d Wifi 3d Streamer
