*Official* Dune HD TV303D/ Base 3D Streamer Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #91 of 1607 Old 03-21-2013, 12:45 PM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
Originally Posted by BIGBERTHA View Post
Where's best place to buy? Anywhere in Canada?
One of the Canadian guys I talk to I believe got it through duneplayer.com (not sure what the shipping/custom fees were since it gets shipped from the states)
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #92 of 1607 Old 03-21-2013, 12:50 PM
muad'dib's Avatar
Quoted: 172 Post(s)
Liked: 55
I got from duneplayer.
Great guys.
I live in Canada
muad'dib is online now
post #93 of 1607 Old 03-23-2013, 08:14 AM
baxyp's Avatar
Bought TV303d few days ago, not impressed so far...
1. m4v format (mp4 with Apple metadata) support is minimal. No chapters, does not detect 5.1 audio track correctly, shows DD stereo. No subs, etc...
2. Switching audio tracks while bitstreaming very flaky. A lot of times I get digital noise, seems like it is having trouble telling the receiver, which audio format it is outputting. My amp is Yamaha RX-V3800. Never had such problems before. Sometimes there is digital noise even while it is sending PCM and decoding audio itself. Especially AAC tracks.
3. IPTV support absolutely minimal. Just a stream player - supports DVB subs though, which is nice. Can only record what is currently displayed.
4. DVD menu support has bugs. Sometimes it hangs with flashing picture. Might be a ripping issue, I don't know. Tested with "Play" in main movie and then "Top menu". Sometimes it works sometimes not.
My overall impression is that this box is unreliable. The hardware is all there, to make it an excellent player, but...
On a brighter note: the NFS performance is really good. I'm getting 38MB/s which is enough for streaming anything. The UI is nice and picture quality is good. There could be more deinterlace modes though: I have only "Bob" and "Motion adaptive". In some situations neither are the best.
baxyp is offline
post #94 of 1607 Old 03-23-2013, 09:34 AM
Opentoe's Avatar
Quoted: 87 Post(s)
Where can I download the B5 beta firmware? I've been trying over and over using the automatic download but it keeps failing giving me a read file error and then just restarts.
The firmware download page does not have this available for download.
I'm also experiencing audio drop outs. While watching Zero Dark Thirty bluray (just ripped to an ISO) playing lite of course there are sound drop outs when the bomb goes off in the restaurant. I switched over to my Dune Prime 3.0 and watched the same ISO file (using lite) and no sound problem at all. So this little player does need some work.
Opentoe is offline
post #95 of 1607 Old 03-23-2013, 09:44 AM - Thread Starter
blackssr's Avatar
Quoted: 1175 Post(s)
Liked: 587
Zero Dark Thirty.zip 1k .zip file
I see that.
b5 corrects drop outs.
Have you contacted MIke at Dune Player?
Also did you get b4 first and then try b5?
Forced sub track on Zero Dark Thirty will not play automatically with BD lite, ISO on the 303D. I have created an .srt file (Forced Only) if you need it (see attached zip file). Drop it the folder with the ISO and it will play if you enable "external subs" always on in the player setup. Normal subs can still be toggled on and off like usual with the remote. This is an easy workaround until (if ever) a firmware fix is released.
File Type: zip Zero Dark Thirty.zip (631 Bytes, 75 views)
I've paid for my sins. We're even!
blackssr is offline
post #96 of 1607 Old 03-23-2013, 09:56 AM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
Do you have system storage installed (i.e. SD card)? If so you need to leave out for the B4 firmware to install. I couldn't get it to install until I did this (Mike @ duneplayer had the same issue). Once the b4 installs then the b5 will install after. Without the b5 you will get audio dropouts
Cheers,
Damian
post #97 of 1607 Old 03-23-2013, 10:44 AM
twa00's Avatar
With Dune turn on ß firmware as they rarely show "stable" releases .... ß is usually pretty good... When it comes
twa00 is offline
post #98 of 1607 Old 03-23-2013, 08:53 PM
apw2607's Avatar
Quoted: 275 Post(s)
Liked: 332
Yes. I've ran into the same issue with "digital noise" too.. I just thought it might be my files but perhaps not.
I don't get it just changing audio tracks but sometimes when the file first starts playing. Sometimes I get no audio. It's all very flakey.
apw2607 is offline
post #99 of 1607 Old 03-24-2013, 11:34 AM
Opentoe's Avatar
Quoted: 87 Post(s)
I have no system storage installed. Right now I have B4 installed, that installed online fine. That downloaded in a few minutes with no problem with the automated firmware upgrade. When I try to install the B5 firmware it cannot download the file properly. It takes hours just to download 1/3 of the file and continues to time out on the download. This is why I asked where I can download the file. If the B5 helps with the audio drop outs then I'm heading in to the right direction...just trying to get there is the problem.
Opentoe is offline
post #100 of 1607 Old 03-25-2013, 06:36 PM
mjt5282's Avatar
Quoted: 16 Post(s)
does the Base 3D streamer decode TrueHD and DTS HD Master Audio to LPCM like it says on their "Key Features" of the Dune HD Base 3D web page? My audio processor doesn't handle the HD audio codecs (yet, if ever).
Does the beta 5 firmware play 3D MKV's yet ? (my preferred BD format) . I use makeMKV to rip my BD's .
I only use Dune's to playback MKV's (mostly BD's and a few DVD's) and TV shows (in MKV format mostly, a few M4V's)
I own a Smart D1 and B1 and would like to buy one that handles 3D. I also use Zappiti to create the film chooser. I have about 200 films and 700 TV episodes.
mjt5282 is offline
post #101 of 1607 Old 03-26-2013, 09:37 AM
twa00's Avatar
ß5 does not play MVC MKV
twa00 is offline
post #102 of 1607 Old 03-26-2013, 09:44 AM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
I only reviewed the TV303D but my understanding the Base3D is the same, which means:
1) HD Audio is decoded to 2ch stereo
2) If you have a TrueHD track in mkv you will get no audio if looking to decode/downmix
Cheers,
Damian
post #103 of 1607 Old 03-26-2013, 10:33 AM
Mr Eric's Avatar
Quoted: 303 Post(s)
Liked: 144
I thought that the PCM patch was also working on the 3d models to have multichannel PCM down mix ?
Mr Eric is offline
post #104 of 1607 Old 03-26-2013, 10:38 AM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
For DTS(MA) yes but not TrueHD
Cheers,
Damian
post #105 of 1607 Old 03-27-2013, 06:59 PM
SlickVik's Avatar
Quoted: 13 Post(s)
The other problem I'm facing, aside from MVC MKV, is for Prometheus and Life of Pi, the left-eye and right-eye seem to be reversed, so you actually have to hold your glasses upside down to see it correctly - is there a fix for this on the way?
SlickVik is offline
post #106 of 1607 Old 03-27-2013, 08:38 PM
rjyap's Avatar
Quoted: 28 Post(s)
Just go into the menu to swap L/R image. Some 3D TV and Projector had the ability to swap the L/R image too. There is a discussion using the naming to reverse the L/R image.
rjyap is offline
post #107 of 1607 Old 04-02-2013, 06:46 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Any word on if/when the Dune players will be implementing USB 3.0?
David
crussader is offline
post #108 of 1607 Old 04-02-2013, 06:49 AM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
The new Dunes have USB 3.0 on the slave connection (so if you were to connect the Dune directly to a PC). The other USB ports are 2.0. Anything in particular you are looking for with 3.0?
Cheers,
Damian
post #109 of 1607 Old 04-02-2013, 07:09 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Not planning on connecting to a pc. Most of the new external hard drives have USB3.0 connections, so I expect 3.0 showing up on the other end of the connection soon. Looking for faster transfer speed (i.e. more bandwidth). Is that not beneficial?
David
post #110 of 1607 Old 04-02-2013, 07:12 AM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
If you are talking about transfer speeds as far as playback it will make zero difference, USB 2.0 is perfectly fine for even the highest bitrate stuff such as Blu ray 3D
Cheers,
Damian
post #111 of 1607 Old 04-02-2013, 07:13 AM
Mr Eric's Avatar
Quoted: 303 Post(s)
Liked: 144
USB2.0 is already over powerful for content streaming. USB3.0 only interest is for file transfer from/to a PC.
edit : beaten ! biggrin.gif
Mr Eric is offline
post #112 of 1607 Old 04-02-2013, 09:30 AM
hoops10's Avatar
Any word on a new firmware update? Just curious as I have some Disney blu rays that I would like to stream but from what I have read they are seemless branched and therefore the 303D can't play them correctly. Or does that depend on the container? For example, if I rip them to iso instead of mkv (or vice versa) would they play ok? Thanks.
hoops10 is offline
post #113 of 1607 Old 04-02-2013, 09:33 AM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
If you rip to mkv or do a main movie rip with Clown_BD you are fine (assuming we are talking 2D Blu rays, 3D blu rays is different). If you do a full disc rip (or even a main movie rip with DVDFab) you are stuck with the seamless branch and will have the issue.
I am not entirely confident the seamless branch issue will get resolved any time soon
Cheers,
Damian
post #114 of 1607 Old 04-02-2013, 09:33 AM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
Beat you by a minute. This is the only time I don't mind being called the minute man redface.gif
Cheers,
Damian
post #115 of 1607 Old 04-02-2013, 12:05 PM - Thread Starter
blackssr's Avatar
Liked: 587
Most are not effected by the seamless branch issue. Most users in the know create a single .m2ts in the container of choice and be done with it. The forced sub issue needs addressing quicker than not.
jconjason likes this.
blackssr is offline
post #116 of 1607 Old 04-02-2013, 12:13 PM
hoops10's Avatar
I am trying to rip the Pirates of the Caribbean movies. I know they are Disney but are not animated ones. Do they still suffer from the seamless branch problems? Also, what about using Makemkv to rip to mkv for these? Will they still have the seamless branch problems?
hoops10 is offline
post #117 of 1607 Old 04-02-2013, 12:21 PM - Thread Starter
blackssr's Avatar
Liked: 587
Makemkv and Clown_BD both create a single file thus making the seamless branching issue a non issue.
blackssr is offline
post #118 of 1607 Old 04-02-2013, 12:29 PM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
Cheers,
Damian
post #119 of 1607 Old 04-02-2013, 12:48 PM
halfelite's Avatar
Quoted: 442 Post(s)
Liked: 233
The TV303 honors mkv forced sub flag now?
halfelite is online now
post #120 of 1607 Old 04-02-2013, 01:34 PM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
All Dunes do as long as you apply the patch
Cheers,
Damian
Dune Hd Tv303d Wifi 3d Streamer
