*Official* Dune HD TV303D/ Base 3D Streamer Thread - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1201 of 1603 Old 05-20-2014, 01:54 PM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
Dune Browser stinks. What you need to do is set up a shortcut to your network drive and then you can naviagte (IIRC you hit the popup button when you are in your favorites section and you shoudl see an option to create a new Network shortcut)
As far as Zappiti, can you confirm what your media paths in your settings look like. Also can you confirm your media folder structure on your network
gimmesomemore likes this.
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #1202 of 1603 Old 05-20-2014, 03:13 PM
gimmesomemore's Avatar
There are 2 folders that hold the large bulk of files, one is \TV shows the other is \movies. The problem is there are +1000 files that are using the wrong cover art and info and have been given the wrong label. It is seeing them, but due to the imdb scraper error, they are mislabeled. The only way I have been able to correct it is by editing into each title in zappiti media centre, and also manually changing the scrape info for each title. As u can imaging with so many mislabelled titles, this is a monumental task. Is there any way to reset my list someone and rescan from scratch? Or another solution? Thanks!
gimmesomemore is offline
post #1203 of 1603 Old 05-20-2014, 03:18 PM
image.jpg 102k .jpg file
post #1204 of 1603 Old 05-21-2014, 02:25 AM
Mr Eric's Avatar
Quoted: 293 Post(s)
Liked: 141
the problems might come from TMDB...
Concerts/documentaries (and obviously your home video category) are poorly added to tmdb database which has a high focus on movies only. For example documentaries can be found somtimes in TMDB (scan as movie) but also in TVDB (scan as Tv series) and there's no rules about that because both databases are managed by the community without any clear rule about what should be considered as Movie or TV Serie... Same for concerts. So this could easily explain why the auto scraping doesn't give correct results. regarding your file/folder naming, can you give an example ? The naming should only contain the official movie/tv serie name, nothing else. If you have things like avatar.1080p.hdtv.dts.mkv, then it won't scrape correctly.
Mr Eric is offline
post #1205 of 1603 Old 05-21-2014, 10:56 AM
Would that cause 1,000+ different movies to be applied all the same title and cover art? I have read (and now experienced) that there is a bug in the v2.8.14.0. firmware causing this if you use IMBD as the scraper in the settings. The solution is to change the scraper to TMDB in the settings. That seems to resolve the issue for any new items, but now i have +1,000 different movies with all the same title and cover art in Zappiti Media Centre. Is there a way to reset or force it ro re-scan? I have tried to analyse/scan but it maybe only looking for new items. Not sure if deleting the items from my movie section in Zappiti M.C. will force it to rescan it correctly.
post #1206 of 1603 Old 05-21-2014, 11:01 AM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
Remove the file locations (i.e. from your pic that you attached), scan (which Zappiti should then remove all associated movies), re-add and then rescan. That should work.
Otherwise you could try deleting the Zappiti DB for 2.8.14.0 (which Zappiti closed). Reopen Zappiti and it will be like starting over fresh (You can just backup or rename the current DB so you have a copy)
Cheers,
Damian
post #1207 of 1603 Old 05-21-2014, 02:01 PM
Thanks bud, I will grudgingly try this over the weekend :-( I was hoping for a more targeted approach, as I have manually corrected maybe a couple of hundred titles. Although, there are around 1,200-1,300 titles that are still incorrect. At least 1,000 have the cover art for "Cinema Paradiso", and several hundred more movies are showing up as "Lion King". Don't judge me! ;-)
I am completely stunned by how little 'jukeboxing' progress has been made since Boxee Box hit the market lo these many years past! Both of my 2 boxees scraped and jukeboxed +90% of my collection with little effort on my part, and with a far nicer and more useful interface. I will miss the superior layout/navigation, online subtitle retreival (if movie file does not have one), Rotten Tomato & IMDB ratings, and trailers. Zappiti is like going back to DOS prompts in comparison. On the positive side, if I ever manage to jukebox my entire array, the Dune 303d PQ is noticeably better.
post #1208 of 1603 Old 05-21-2014, 03:35 PM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
I would make a copy of the current db first in case you want to revert to. Remember as well, if Zappiti scrapes correctly the next time then you should have very few movies to edit manually
Cheers,
Damian
post #1209 of 1603 Old 05-28-2014, 08:40 PM
Thx for your suggestions. It all worked out well. I ended up deleting just the movies from zappiti's collection that had the incorrect label and cover art. Then I rescanned and sure enough it removed the incorrect cover art and labels. I did have to manually scrape a great number of them, because my movie file names have a lot of other info that confuses zappiti, but at least they had the right names to make the process easier. I still have issues with some tv shows missing seasons, but the weather is too damn nice in Toronto to waste more time on this...save it for a rainy day. It most definitely is a lot harder than it has to be, and I wish zappiti was smart enough to scrape with less manual intervention. I'm very pleased with the performance of the dune player, but the zappiti lacks features like trailers, music support, and more reliable reviews (ie imdb, rotten tom.). The pic & audio quality are great from the dune, and it has snappy performance. There is no perfect player out there, so it's a decent compromise. Dune hardware with boxee box ui would be my dream machine!
post #1210 of 1603 Old 06-06-2014, 09:14 AM
elche99's Avatar
Originally Posted by Mr Eric View Post
there's no consensus on jukeboxes. All have their pros and cons. Just test them all and pick the one you like wink.gif .....
My collection is 100% movies and no Tv serial... add that my language is italian: this can influence the jukebox choice?
Here i see people mainly speak about Yadis and Zappiti: there are other suitable alternatives?
elche99 is offline
post #1211 of 1603 Old 06-06-2014, 10:09 AM
Mr Eric's Avatar
Quoted: 293 Post(s)
Liked: 141
zappiti will only work on zappiti players. The you can use yadis, mymovies or DuneX. Easiest to use is still yadis (and it's also in Italian).
Mr Eric is offline
post #1212 of 1603 Old 06-06-2014, 10:29 AM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
New users cant use Zappiti any longer for a non Zappiti player? I still use Zappiti on my Dune but granted I have had it for a while
Cheers,
Damian
post #1213 of 1603 Old 06-06-2014, 01:42 PM
robnix's Avatar
Quoted: 653 Post(s)
Liked: 492
You can still get a Zappiti license for Dune.
Looky here!
robnix is offline
post #1214 of 1603 Old 06-06-2014, 02:26 PM
Mr Eric's Avatar
Quoted: 293 Post(s)
Liked: 141
You can't use the latest zappiti 3.0...
Mr Eric is offline
post #1215 of 1603 Old 06-08-2014, 09:08 AM
elche99's Avatar
Thanks, then i wil go for Yadis.
elche99 is offline
post #1216 of 1603 Old 06-08-2014, 06:03 PM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
No desire to because of being forced to the cloud. The 2.0 versions still work perfectly fine, no reason to dissuade people from.
Cheers,
Damian
post #1217 of 1603 Old 06-09-2014, 07:35 AM
elche99's Avatar
Then if i want to give a try to Zappiti i must dl 2.8.14 version? (it is the latest 2.xx version)
elche99 is offline
post #1218 of 1603 Old 06-09-2014, 07:39 AM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
Yes, I believe that is the version I am using.
Cheers,
Damian
post #1219 of 1603 Old 06-09-2014, 07:59 AM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
What's the force to the cloud all about? I just downloaded the zappiti iPad app and all of a sudden had the cloud option available in the pc app.
What other bonuses or pitfalls are in 3.0?
pdxrealtor is offline
post #1220 of 1603 Old 06-09-2014, 08:12 AM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
The Zappiti developers have decided that starting with 3.0 you are forced to use the cloud to export your jukebox. That is fine to add as an option, but it makes no sense whatsoever to remove the local export that most people have/had been doing. This basically means you need to have an active internet connection the entire time
Cheers,
Damian
post #1221 of 1603 Old 06-09-2014, 11:02 AM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
Interesting. I wonder if because I'm using cloud for the iPad app I'm now not exporting locally at all. ??
post #1222 of 1603 Old 06-12-2014, 07:49 AM
mabuk's Avatar
I have a 303D and have been having a few dropouts with TrueHD. I've used internal and external drives, the audio is bitstreamed to a TrueHD receiver (Yamaha RX-v373). Could someone with a 303d please play this 60 second clip (below) to see if the gunshot cuts out. If I play the clip 5 times then I might hear the gunshot once. I just want to confirm whether it's my receiver at fault or the player. I contacted Dune and they said Dune HD don't support TrueHD.
http://www.mediafire.com/download/pz...0s_sample.m2ts
(Maximum bitrate for audio reported by tsmxer is 4825kbps)
I asked over at AVForum if someone could test the clip on a Base 3d, but there seems to be a more active 303d discussion over here. It would be interesting to know if any player with this same Sigma chipset can stream TrueHD fully. Any help greatly appreciated.
mabuk is offline
post #1223 of 1603 Old 06-12-2014, 10:47 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
FYI there are several movies that I know of that have audio drop out with TrueHD. You have to remux them to PCM or Flac.
GusGus748s is offline
post #1224 of 1603 Old 06-13-2014, 06:33 AM
mabuk's Avatar
Thank you for the reply. I thought it might be a cable or my receiver. Looks like I just need to remux to mkv and then use the 'popcorn mkv audioconverter' to convert to flac, for the few films I have with this problem.
mabuk is offline
post #1225 of 1603 Old 06-13-2014, 11:39 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
No problem. I know the ones I've had audio drops are Monsters University, Brave, Total Recall, Finding Nemo, etc. pretty much all of the Disney Movies using TrueHD.
post #1226 of 1603 Old 06-13-2014, 04:28 PM
cornemuse's Avatar
I recently got a 303d player. There seems to be a lack of support for this unit. I quite like it, (I have a wdlive smp which I do NOT like). I am on a learning curve still.
A few issues:
How to play all mp3's / music in a folder. (I cant find a setting for this)
When a movie (dvd iso) is paused then restarted, it restarts for a fraction of a second, freezes, & then runs FAST! for another fraction of a second, then all is ok.
Some movies when already viewed, (I click chapters to see whats what) will only start at some point in the movie, to view from begining, must go back by chapter to begining of flick.
Dont get me wrong, I like it, I had an Argosy player, (HV359) but am not able to find one of them anywhere in the world now.
thanks for info -c-
cornemuse is offline
post #1227 of 1603 Old 06-13-2014, 05:14 PM
ScottJ's Avatar
Quoted: 276 Post(s)
Liked: 147
I've seen the freeze-after-unpause when my file server HDD spins down for power savings. When the Dune tries to resume, the file server takes a few seconds to come to life, and the Dune is stuck trying to play the movie without any data. Once the data arrives, it tries to "catch up" by playing fast.
Press 0 on the remote to jump back to the beginning of the movie.
ScottJ is online now
post #1228 of 1603 Old 06-16-2014, 01:03 PM
dbone1026's Avatar
Quoted: 215 Post(s)
Liked: 107
I know for tv episodes if I press the play button on the top level folder (for example Season 1) the Dune will generate a playlist and play all tv shows in that folder. Guessing the same would happen with music
Cheers,
Damian
post #1229 of 1603 Old 06-19-2014, 12:29 PM
thetoad's Avatar
also happens if your hard drive is busy (i.e. extracting something large at the same time you're playing a video at a high bitrate so it can't feed the dune data fast enough (or in reality more so that the dune has a small readahead cache)
thetoad is offline
post #1230 of 1603 Old 06-19-2014, 01:16 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I've got an UnRaid server, which spins down the drives when not in use. If I push play it takes a few seconds to start the movie, and I don't have any issues with it.
Dune Hd Tv303d Wifi 3d Streamer
