*Official* Roku 3 Streaming Player Thread - Page 69 - AVS Forum | Home Theater Discussions And Reviews
 148Likes
post #2041 of 3221 Old 08-13-2014, 06:16 PM
HD-Master's Avatar
Quoted: 24 Post(s)
Liked: 83
Originally Posted by reddice View Post
All TV's today should be 1080p or 4K. This day and age I still don't understand why they make 720p TV's and yes I even seen 39" and bigger in 720p. My uncle and my mother which know nothing about flat screens were suckered into buying a 720p TV because it was very cheap but for only about $50 to $100 more depending on the maker you can get a better 1080p TV.
I hope when the prices of 4K go down to what 1080p TV's are today 720p TV's will go the way of the CRT and EDTV 480p TV's.
If the TV isn't large enough, the benefits of 1080p over 720p evaporate.
HD-Master is offline
post #2042 of 3221 Old 08-13-2014, 07:26 PM
rdgcss's Avatar
Quoted: 83 Post(s)
Liked: 36
The main reason for 720p sets is to be able to sell a set for a cheap price. To me cheap=substandard components=low quality everything
rdgcss is online now
post #2043 of 3221 Old 08-13-2014, 08:27 PM
michaeltscott's Avatar
Quoted: 2559 Post(s)
Liked: 1355
There are those who question whether 4K will ever become the norm; the screen has to be very large for the difference between it and 1080p to become apparent at typical viewing distances. I plan to buy a Vizio P-Series 4K television when the 55" or 60" model becomes available, but resolution is not a motivator in that decision. (It's a full-array-local-dimming monitor with the largest number of dimming zones that I can afford, being 64 in those sizes. It also features HDMI 2.0, fast processors and HEVC video decoding). At those sizes optimal viewing distance is between 5 and 6 feet.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is online now
post #2044 of 3221 Old 08-13-2014, 08:37 PM
HD-Master's Avatar
Quoted: 24 Post(s)
Liked: 83
1080p displays under a certain size, from a reasonable home seating distance, have no benefits over 720p displays. It has to be big enough, and your seating distance close enough, for the difference to be discernable. Spending more for a small 1080p display that you sit 8-10 feet away from...is a waste of money.
HDMI Guy likes this.
post #2045 of 3221 Old 08-14-2014, 06:36 AM
pbarach's Avatar
Quoted: 280 Post(s)
Liked: 175
If it's a very small screen, there is no visible difference between 720p and 1080p at normal viewing distances.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #2046 of 3221 Old 08-14-2014, 09:01 AM
UHD Addict
aaronwt's Avatar
Quoted: 4783 Post(s)
Liked: 2822
Then by using that reasoning the same thing can be said for Ultra HD(UHD). 1080P sets would be the "cheap=substandard components=low quality everything". While the UHD sets would be higher quality. But just like 720P sets, this is not the case. You can find low quality UHD, 1080P and 720P sets. And you can find higher quality UHD, 1080P, and 720P sets.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #2047 of 3221 Old 08-14-2014, 11:48 AM
Mark12547's Avatar
Quoted: 686 Post(s)
Liked: 463
I seem to have created quite a tangent with mention of my "720p class" bedroom TV that has a native resolution of 768p and thinking next time I should go with either a real 720p or a 1080p TV.
Many "720p" TVs are really 768p, including the one I had purchased three years ago. The TV can accept 480, 720p, 1080i & 1080p, but there is no HDMI standard resolution of 768p, so every signal fed the 768p TV will be rescaled.
My thinking is this: every resolution I can feed the 768p TV requires the TV to rescale, so if I am feeding the TV from a source that will rescale the image (such as a Roku digital video player, which takes whatever resolution it receives and scales it to the resolution it is configured to output, or a Blu-ray player with its factory defaults if used to play a DVD), then the image will suffer from double-rescaling, which tends to reduce the sharpness of the image.
At the time the 32-in 768p TV was a decent tradeoff between costs, resolution and size, and right now the only inputs to it aren't doing any rescaling (the DVR is set to "NATIVE" to feed the TV the same video resolution as the channel it is receiving, but with the advanced setting to deinterlace 480; and the VCR/DVD combo unit feeds the TV either composite 480i or component 480i, the native resolution of VHS tapes or DVDs), so only the TV is rescaling what is thrown at it to the screen's 768p.
But if I were to add a Roku 3 to the 768p TV, there would be potential double-rescaling, especially for 480p content (such as many older TV shows) that would lose some of its sharpness.
And, likewise, a Blu-ray player with its factory settings will generally rescale a DVD (480i) to 1080p unless the player has an advanced setting that allows me to tell it to pass either 480p or 480i to the TV when playing a 480 source and I make that adjustment.
On the other hand, if I had a real 720p or a real 1080p native resolution TV, then I could configure a Roku 3 to match the TV's native resolution and then the only rescaling would be the Roku rescaling to the TV's native resolution where needed, and a Blu-ray player could likewise be configured to output the TV's native resolution so DVDs from Netflix or pre-Blu-ray titles I own would likewise be rescaled to the TV's native resolution.
Generally, though, when I want to watch Netflix streams or Netflix discs, I do it on the other TV that is native 1080p and has overscan turned off, and I can feed that TV at the TV's native resolution.
If I were in the market for a 32-in TV today, I would be much more inclined to look for a native 1080p TV.
My very humble setup:
Spoiler!
Mark12547 is online now
post #2048 of 3221 Old 08-14-2014, 02:58 PM
Liked: 1355
I just bought a 32 inch television for my brother as a gift, and though it probably didn't matter much at that size, I felt better buying a 1080p one. The price difference for major brands wasn't much (I bought an LG), though the very cheapest models were, of course, off-brand 720p ones.
reddice likes this.
post #2049 of 3221 Old 08-17-2014, 01:07 AM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Is it possible to connect a USB external HD to the Roku 3 and have it serve as a network drive, as one would with the USB drive connected to a wireless router?
Our "new" wireless router is not compatible with either our USB external drives, so we don't have a network drive now. So, that is why I'm wondering if the Roku can accomplish this for us too...
TonyB1966 is offline
post #2050 of 3221 Old 08-17-2014, 05:08 AM
Gary J's Avatar
Quoted: 391 Post(s)
Liked: 198
Gary J is offline
post #2051 of 3221 Old 08-17-2014, 09:47 AM
HD-Master's Avatar
Quoted: 24 Post(s)
Liked: 83
Originally Posted by Gary J View Post
That isn't even what he asked...
post #2052 of 3221 Old 08-17-2014, 10:27 AM
Gary J's Avatar
Quoted: 391 Post(s)
Liked: 198
It is actually a direct quote, rook!
Gary J is offline
post #2053 of 3221 Old 08-17-2014, 10:39 AM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Thanks, sort of...
I spent a fair amount of time searching the web before asking here, and since I didn't find what seemed to answer the question, I felt it a good idea to ask here. I believe I found an appropriate discussion, but it was a few years ago, and the conclusion then was that it was not possible as Roku needed to do something to make that an option...
I've had the Roku not even a week, so my knowledge is minimal. With a connected USB external HD to the Roku 3, is it possible to see and access that drive over the network?
post #2054 of 3221 Old 08-17-2014, 10:00 PM
mayzilla's Avatar
Originally Posted by TonyB1966 View Post
Thanks, sort of...
I can answer this without sending you a LMGTFY link: No.
While you CAN connect an external drive to the Roku 3, all that will let you do is view whatever media is on it. Roku is not a NAS. But you can get a 2TB WD NAS for around $150.
TonyB1966 likes this.
mayzilla is offline
post #2055 of 3221 Old 08-17-2014, 10:48 PM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Thank you mayzilla. That is actually good to know.
As it turns-out, I was finally able to get one of our USB external hard drives to work with our wireless router (Netgear R6300) such that we now have a network drive at our new home. The Roku inquiry was me scrambling to find another possible solution as my wife has photos and videos seemingly every day to archive...
That said, it would be nice to be able to access a network drive on the Roku. Thanks again for the thoughtful reply.
post #2056 of 3221 Old 08-21-2014, 04:22 PM
HD-Master's Avatar
Quoted: 24 Post(s)
Liked: 83
...except the relevant bit about it being networked that you left out, which rendered your comment useless.
post #2057 of 3221 Old 08-21-2014, 04:24 PM
HD-Master's Avatar
Quoted: 24 Post(s)
Liked: 83
post #2058 of 3221 Old 08-29-2014, 06:00 PM
cornemuse's Avatar
I got a 'Roku 3' today. Sorry, but the included instructions are for idiots 'and' a perfect world. Online support seems to be similar to 'Dune's' online support, ie lacking. After an hour on their site, I find(?), one does not turn this thing on & off? right? (other than plugging/unplugging) The list of supported files does NOT include iso's & vob type files? I might/prolly missed something there.
I am trying to find something to replace my Argosy player & they have not been available for several years. Thw wd live smp is somewhat of a joke, the Dune a bit better, but lacking somewhat over wd's.
All gripes, mods, etc. for WD & Dune (on their respctive web sites, a LOT of gripes, years worth!) are simply NOT issues with the Argosy. If I could buy another Argosy, I'd buy 3!!
Hope the ranting does not piss off any constructive helpers out there.
-corne-
cornemuse is offline
post #2059 of 3221 Old 08-29-2014, 06:01 PM
gonzlobo's Avatar
Quoted: 32 Post(s)
Liked: 30
Excellent way to ask for help.
wkearney99 and calculon68 like this.
Denon AVR-X3200W
B&W 683s1/685s1/HTM61s1 (FL/FR/SL/SR/C), Klipsch RP-140SA (Atmos)
Paradigm DSP-3100 v2 (Sub)
Oppo 103 / Roku3
Panasonic TC-P60ST50
gonzlobo is offline
post #2060 of 3221 Old 08-29-2014, 07:04 PM
Audio Geek's Avatar
Quoted: 87 Post(s)
Liked: 41
Correct, it doesn't have an on/off switch. It's designed to be always on.
Audio Geek is offline
post #2061 of 3221 Old 08-30-2014, 05:37 AM
pbarach's Avatar
Quoted: 280 Post(s)
Liked: 175
This must be a change from the Roku 2, which uses HDMI-CEC to switch on whenever the device on the other end of the HDMI cable goes on. Then there is about a 30-sec boot time.
pbarach is offline
post #2062 of 3221 Old 08-30-2014, 09:29 AM
Liked: 1355
What do you mean by "Roku 2"? The latest model with that designation (2700)? That would be completely new behavior; most Roku users would hate it. I know that I wouldn't buy any model with that "feature".
From Roku's support page:
How do I turn off the Roku player?
The Roku player was designed to remain plugged in so it can download the latest Roku software and channel updates automatically. It draws less power than a night light. So, there is no power button. If you need to turn it off, simply unplug the power cable from the back of the player.
post #2063 of 3221 Old 08-30-2014, 09:31 AM
pbarach's Avatar
Quoted: 280 Post(s)
Liked: 175
Roku 2 XS (model 3100X). I don't care what they show on their support page.
pbarach is offline
post #2064 of 3221 Old 08-30-2014, 09:35 AM
Liked: 1355
I own a 2XS--mine does not do that and it's definitely not supposed to.
post #2065 of 3221 Old 08-30-2014, 09:39 AM
cornemuse's Avatar
Thanx,
In my search, the only page I could find listed about 8 different file types total listed that roku supports. Gotta be more than this, Yes?
post #2066 of 3221 Old 08-30-2014, 10:42 AM - Thread Starter
Aero 1's Avatar
Quoted: 323 Post(s)
Liked: 165
Thanx,
Nope, that's it. You got the wrong box if your looking for every file type under the sun.
Aero 1 is online now
post #2067 of 3221 Old 08-30-2014, 02:57 PM
UHD Addict
aaronwt's Avatar
Liked: 2822
-corne-
Try a Popcorn Hour media player. I always liked them better than the Dune media players I tried.
post #2068 of 3221 Old 09-01-2014, 07:29 PM
rjhseven's Avatar
Quoted: 182 Post(s)
Liked: 27
Does anyone know how to get the PAC 12 Sports network or just one game on a Roku channel? I have a Roku 3 and it is not
In channel store. Do not have Dish or UVerse which are major carriers of this network. Thanks in advance for help.
Memphis Tiger Fan-Sports enthusiast
rjhseven is online now
post #2069 of 3221 Old 09-01-2014, 07:35 PM
archer75's Avatar
Quoted: 125 Post(s)
Liked: 56
It's not possible at the moment. There's no channel and you need a pay tv account. I have emailed them and asked if they would support Chromecast and they said maybe.
Nvidia Shield Android TV, 2x Roku 3's, 1st and 2nd gen chromecast, Amazon Fire TV stick 2nd gen, Apple TV 4, Vizio M602i-B3, LG OLED65B6
Retired - HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver, Yamaha RX-V663 receiver via HDMI, panasonic ax100u, 145" S-I-L-V-E-R painted screen,
archer75 is offline
post #2070 of 3221 Old 09-01-2014, 07:36 PM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
If you don't get a Roku solution, YouTube will carry the Pac-12 Network/s for international viewers. I know of a few who are setting-up VPN's in Canada, Mexico and elsewhere to view the games on YouTube...
http://pac-12.com/content/pac-12-net...tional-youtube
