*Official* Roku 3 Streaming Player Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 150Likes
post #2521 of 3252 Old 03-30-2015, 11:19 AM
mdavej's Avatar
Quoted: 2213 Post(s)
Liked: 969
Originally Posted by Gary J View Post
repeat
Not interested in the other two suggestions? Otherwise, call Roku for a warranty replacement of remote and/or main unit. Nothing else you can do.
mdavej is offline
post #2522 of 3252 Old 03-30-2015, 11:28 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
I may go with another remote but sometimes wi-fi seems to have a mind of it's own so I will give it time to see if it decides to start working again. Maybe I have one with pollen allergies.
Gary J is offline
post #2523 of 3252 Old 03-30-2015, 11:40 AM
mdavej's Avatar
Liked: 969
Is your reset/pairing procedure like this:
http://rokuhowto.blogspot.com/2013/0...king-easy.html
In any case, a universal is really the way to go. After using universals for the past 20 years, I could never go back to juggling remotes. My JP1 upgrade for Roku is killer and has a lot more commands than any Roku remote. Can easily be converted to pronto hex if needed or taught to any other remote from a cheap JP1 remote.
http://www.hifi-remote.com/forums/dl...&file_id=12733
mdavej is offline
post #2524 of 3252 Old 03-30-2015, 12:00 PM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
Yes that came up first for me in Google.
I have a couple of Harmony set ups but this is for a small system in a vacay home -
old Denon receiver
Panasonic LCD TV (cable input)
Apple TV
Roku 3
I'm thinking something like this might do -
http://www.amazon.com/RCA-RCRP05BR-D...ds=jp1+remotes
Gary J is offline
post #2525 of 3252 Old 03-30-2015, 12:18 PM
mdavej's Avatar
Liked: 969
old Denon receiver
Apple TV
Roku 3
No Roku codes built into that one, but you could certainly load mine into it with a JP1 cable or simply learn the codes from one of your Harmonys.
These JP1 remotes DO have Roku codes (or it can be loaded via included cable):
http://www.amazon.com/Inteset-Univer.../dp/B00M4I1BAY
http://www.ebay.com/itm/Genuine-NEVO...-/191535345422
http://www.walmart.com/ip/One-For-Al...emote/35275383
If you get a JP1 cable, this is currently the cheapest remote you can load the codes into:
http://www.ebay.com/itm/TESTED-WORKI...e/181631605544
EDIT: Roku code on JP1 remotes that have the code, like the Inteset INT-422 above, is 03061 (or CBL 3061)
mdavej is offline
post #2526 of 3252 Old 03-30-2015, 12:25 PM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
Good stuff. Looks like that one on Amazon will do me - thanks!
Gary J is offline
post #2527 of 3252 Old 03-30-2015, 12:31 PM
Quoted: 373 Post(s)
Liked: 153
Had an issue with my remote on roku 3. The OK button got stuck. Roku sent me the new Enhanced Remote for Roku 3 w/ the netflix, amazon, and hulu buttons for free.
BroadwayBlues is offline
post #2528 of 3252 Old 03-31-2015, 12:36 PM
Steelman99's Avatar
Quoted: 183 Post(s)
Liked: 57
Does anyone know if the Spotify app is different on the Roku 3 vrs the Roku 2 xs? I know the Netflix app on the Roku 3 is like the PS3's.
Steelman99 is offline
post #2529 of 3252 Old 03-31-2015, 12:52 PM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
I doubt it. Netflix would like for all Roku-2XS-and-later boxes to have the UI on the Roku 3 and Roku has stated that they and Netflix worked very hard to make that happen but failed. That UI is implemented in highly portable but resource-intensive web technology (JavaScript, etc) and they could not get it to work acceptably on the earlier Roku platforms. The fact that the Roku 3 has twice as much memory as Roku 2XS is no doubt a significant factor. I personally think that they could get it to work on the recent Roku 1 and Roku 2 (no XS or XD, etc) and I suspect that it will work on the updated Roku 2 that's supposed to release soon. It works on the Roku HDMI Stick and Roku TV and will work on all models in the future.
I don't think that any of the other channels is different from Roku model to model.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #2530 of 3252 Old 03-31-2015, 02:56 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
Therefore, no profiles on the 2 XS...
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #2531 of 3252 Old 03-31-2015, 04:05 PM
Liked: 1516
Yes, though it seems to me as though they could add support for profiles to to Roku native Netflix UI. I can't imagine what would prevent it and they've added support to other devices with non-standard Netflix UIs, like ATV.
post #2532 of 3252 Old 04-05-2015, 03:45 AM
Liked: 0
Audio Issues
I've been hearing 'chirps' - quick, high-pitched digital sounds - when using the Roku. I've checked the videos on different devices and noticed audio flaws in the same spots, but they are much more apparent and unpleasant when using the Roku 3 with my TV. I'm assuming this is due to the crummy speakers in the TV (unfortunately I don't have anything else to hook the Roku to at the moment), but has anyone else experienced this? Is there a technical term for this type of audio problem?
The Roku also rebooted itself again while loading a commercial on the VEVO channel. It hasn't done this on any other channel, so it might just be an issue with that app in particular.
Thanks for the help.
framewire13 is offline
post #2533 of 3252 Old 04-05-2015, 04:32 AM
80sGuy's Avatar
Quoted: 191 Post(s)
Liked: 36
Plug a pair of headphones into the remote and see if there's any audio problem.
80sGuy is offline
post #2534 of 3252 Old 04-05-2015, 04:16 PM
ggsantafe's Avatar
Quoted: 213 Post(s)
Liked: 171
Now that you mention it - While watching Netflix series "Bloodline" I did notice a few chirps along the way - didn't think much about it, until you mentioned it. I'll need to watch some more Roku content to see if it is a repeatable phenomena.
ggsantafe is offline
post #2535 of 3252 Old 04-05-2015, 09:05 PM
Liked: 0
I'll give that a try, thanks. How does that work exactly? Assuming it's a problem with the Roku's audio chip, would it still show up with headphone usage?
Yeah, I notice quite a few chirps and clicks when watching Netflix stuff. I know from checking on other devices that I can hear encoding hiccups in the same spots on videos, but they're only annoying on the TV + Roku combo.
Do you have a timestamp for any that you've heard? I could check them out as well.
post #2536 of 3252 Old 04-06-2015, 05:31 AM
frankhj's Avatar
Anyone no longer getting DD+ on Roku3? I have tried several that are DD on ATV2 & DD+ on my Panasonic BD player but only stereo on Roku3. One example is The Big Lebowski.
frankhj is offline
post #2537 of 3252 Old 04-06-2015, 05:43 AM
lujan's Avatar
Quoted: 2494 Post(s)
Liked: 1117
The last couple of Netflix movies I watched were DD+ so it seems to be fine...
lujan
191 Ultra HD
807 HD
19 HD DVD
4 SD
lujan is offline
post #2538 of 3252 Old 04-06-2015, 05:47 AM
80sGuy's Avatar
Quoted: 191 Post(s)
Liked: 36
Ever since Netflix and Roku did some minor updates, they have screwed some things up, and one of which is the audio settings. Go to Setting>Audio Mode>Select Auto (DD+,DTS)
Then scroll down to...
Digital Audio Out>Select DD+,DTS
80sGuy is offline
post #2539 of 3252 Old 04-06-2015, 07:08 AM
ggsantafe's Avatar
Quoted: 213 Post(s)
Liked: 171
Agreed - noticed the same issue when watching "Bloodline" AVR was not recognizing DD+ - when into settings and reset - didn't realize there had been an update. Good advice 80's Guy!
post #2540 of 3252 Old 04-06-2015, 07:18 AM
frankhj's Avatar
Suggested change did not help me. I also tried just Digital Audio Out >Select DD+. Tried also settings restart. Still no DD+ with Netflix.
frankhj is offline
post #2541 of 3252 Old 04-06-2015, 07:25 AM
80sGuy's Avatar
Quoted: 191 Post(s)
Liked: 36
^^Believe me it works! This happened to me when most films from my list went from 5.1 (because that's all I watch) to stereo. Then I realized Netflix screwed things up thats when I went and 'forced' selected audio instead of leaving it on auto. If you're getting 5.1 elsewhere and not Roku then there's a problem. Make sure you do exactly what I outlined, Try physically unplugging your device and try again.
80sGuy is offline
post #2542 of 3252 Old 04-06-2015, 07:47 AM
80sGuy's Avatar
Quoted: 191 Post(s)
Liked: 36
Just tried playing 'The Big Lebowski' and I'm getting HD 5.1 on my Roku 3.
I have also noticed the 'audio' information has been omitted when pressing the little asterisk button on the remote. It now only show the time, resolution, and subtitle (if enabled). Don't know if this is a Netflix or Roku problem and I'm not liking it one bit!
80sGuy is offline
post #2543 of 3252 Old 04-06-2015, 08:14 AM
gmanhdtv's Avatar
Quoted: 34 Post(s)
Liked: 26
So much for the hope of a Roku 4 (K) just some minor changes to product line:
http://www.engadget.com/2015/04/06/r...e-search-feed/
gmanhdtv is offline
post #2544 of 3252 Old 04-06-2015, 09:51 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
Not sure why you say that. The rumor is still a Roku 4 with 4k eventually. That was about Roku 2 and 3.
Gary J is offline
post #2545 of 3252 Old 04-06-2015, 11:18 AM
gmanhdtv's Avatar
Quoted: 34 Post(s)
Liked: 26
Pretty much doubt there will be a Roku 4 this year. Apple TV is not going to support 4K any time soon either. I think Roku is done for this year as far as product announcements.
reddice likes this.
gmanhdtv is offline
post #2546 of 3252 Old 04-06-2015, 11:22 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
I don't know your basis for that either but maybe next year. Either way not exactly "So much for the hope of a Roku 4".
Gary J is offline
post #2547 of 3252 Old 04-06-2015, 11:58 AM
reddice's Avatar
Quoted: 602 Post(s)
Liked: 117
That saves me some cash. I won't get the refreshed Roku 3. I was really hoping for a Roku 4.
If they actually announce a new Apple I might get it even thought it won't be 4K as long as the Netflix app does not have that stupid common UI. If it does it will perform the same with the same issues (start-up mud quality, limited navigation, 720p UI and postage stamp credit shrinkage) as the PS3,4, Roku 3, Fire TV etc. and it would be a waste since I have those devices.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is offline
post #2548 of 3252 Old 04-14-2015, 04:56 PM
80sGuy's Avatar
Quoted: 191 Post(s)
Liked: 36
Has anyone noticed the audio information on Netflix is no longer available when pressing the * button? It only shows the time, buffer rate/resolution, and subtitles (if on). Before it used to show audio info as either Stereo or 5.1 under the resolution.
80sGuy is offline
post #2549 of 3252 Old 04-14-2015, 05:09 PM
Liked: 1516
I still get audio information.
post #2550 of 3252 Old 04-14-2015, 05:46 PM
80sGuy's Avatar
Quoted: 191 Post(s)
Liked: 36
This is what I get when pressing * on the remote from Roku 3....
But not on other devices such as the Oppo BDP-103D
80sGuy is offline
