non-FiOS use of ECB2200 coax network adapter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-09-2013, 08:25 AM - Thread Starter
bobnbet's Avatar
can I install Actiontec coax network adapter ECB2200V on my non-FiOS cable to TV ?
bobnbet is offline
post #2 of 5 Old 03-11-2013, 11:26 AM
itznfb's Avatar
Liked: 58
It will work with any MoCA compliant router/modem. The ECB2200V isn't a device that will work on it's own though. If you don't have a router/modem with MoCA enabled you would need a ECB2500 or similar device to connect to the router/modem and bridge the coax network to the ethernet network.
The ECB2500 also comes in a two pack to connect one to the router/modem and one to a switch or device at the other end.
http://www.amazon.com/Actiontec-Ethernet-Adapter-Service-ECB2500C/dp/B008C1JC4O/ref=pd_sim_e_3
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #3 of 5 Old 03-15-2013, 01:55 PM
Mugenstylus1's Avatar
will the netgear moca device work with this?
Mugenstylus1 is offline
post #4 of 5 Old 03-16-2013, 06:31 PM
itznfb's Avatar
Liked: 58
Work with FiOS? Yes it will.
itznfb is offline
post #5 of 5 Old 04-28-2013, 12:02 AM
Mike Wolf's Avatar
If you are asking if the Netgear MoCA bridge will work in your setup, it will if the MoCA network is setup correctly.
Opinions expressed are my own and do not necessarily represent those of my employer or its associated companies.
Mike Wolf is offline
