MG-35 problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-26-2013, 12:39 AM - Thread Starter
amnher's Avatar
The status of my MG-35 has red led on but the blue panel does not light up, I am not able to use my MG-35 right now. But when I connect my MG-35 via USB, blue panel is blinking and I can access my files, but when I connect to my TV it is either no display or the menu will show but I cant do anything.
amnher is offline
post #2 of 4 Old 03-26-2013, 12:16 PM
TheKrell's Avatar
Worth checking the power brick to make sure it hasn't lost it's 5V supply...
TheKrell is offline
post #3 of 4 Old 04-02-2013, 12:27 AM - Thread Starter
amnher's Avatar
I dont quite got it how to do that
amnher is offline
post #4 of 4 Old 05-28-2013, 10:56 AM
Dominic Hagan's Avatar
use a multimeter on a dc setting and check the pins. I noticed that they still give the right voltage but not the flow or ampage.
you can split the brick and put some new capacitors in there which usually sorts most power supplies out cheaply
take the drive out and see what it does as the board wont be checking the drive at boot up.
Dominic Hagan is offline
