How Fast is Wireless N? What Is Real World Speed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 04-02-2013, 07:07 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
I have been on a Wireless G router for many years (Linksys WRT54GL) and I pretty much gave up on trying to stream media from my HTPC to the various laptops and desktops in the home.
I just replaced by wireless G devices with wireless N router and wireless N adapter on the HTPC, both are rated at 300mbps (megabits).
To test my new connection, I ripped a blu-ray (Black Hawk Down) on my desktop (wired) and try to transfer the file to my HTPC. I got a constant transfer rate of 5.3MBps (megabyte), which is about 42.4 mbps (megabits).
So, I am getting nowhere close to the transfer rate of 300mps, heck not even 1/4 of the rated speed.
What gives? Is my setup not right? Or is this the actual real world performance of Wireless N devices?
By the way, I am on the 2.4ghz band, although my router is dual band but my N adapter is only 2.4ghz and my wireless connection indicate that I am connected at 300mbps.
smokarz is offline
post #2 of 26 Old 04-02-2013, 07:45 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Update:
So, I downloaded a network bandwidth monitor app (DU Meter) and try to transfer the file again.
I let the transfer runs for about 10min. I get a max transfer rate of 84mbps, and an average rate of 64.9mbps. It improved a bit, I guess half of the neighborhood went to bed and got off their wifi conections.
But this is still a far cry from the 300mbps.
net1.JPG 34k .JPG file
smokarz is offline
post #3 of 26 Old 04-02-2013, 07:51 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I don't think you will ever attain the 300mbps rate. I am running a Netgear "N" wireless router and it works for me but I am not happy about the spotty range. I have a 2 story house and at no time am I more than 40' from the router and my signal is at best good. Our MB is directly over the room with the router and I can't watch movies via my XBox360 via wireless when the distance is less than 8'.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #4 of 26 Old 04-02-2013, 08:09 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
I don't expect to get the full 300mbps, but I think I should expect at least 150mbps or half of the rated bandwidth?
smokarz is offline
post #5 of 26 Old 04-02-2013, 08:20 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I agree... I will stay tuned in to see if there is a solution to get it up where it should be.
ellisr63 is offline
post #6 of 26 Old 04-02-2013, 08:22 PM
Joeworkstoohard's Avatar
Those are decent real world numbers.
The only time I have heard of anywhere near advertised speed was in a benchmark test
Joeworkstoohard is offline
post #7 of 26 Old 04-03-2013, 03:02 AM
Sileem's Avatar
If you using 1 MIMO stream and 20 MHz bandwidth channel then theoretical N maximum is 72.2 Mbit/s.
If using 4 MIMO streams and 40 MHz bandwidth channels then theoretical N maximum is 4x150 Mbit/s
Ref: http://en.wikipedia.org/wiki/IEEE_802.11n-2009
http://en.wikipedia.org/wiki/MIMO
N300 advertised dual band device has usually 2 MIMO streams, one in 2.4 other in 5 GHz band but bandwidth can be adjustable.
Sileem is offline
post #8 of 26 Old 04-03-2013, 08:39 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
I have an N750 router.
smokarz is offline
post #9 of 26 Old 04-03-2013, 08:52 AM
Sileem's Avatar
300 Mbps on 2.4 GHz and 450 Mbps on 5 GHz?
But adapter on HTPC?
Sileem is offline
post #10 of 26 Old 04-03-2013, 08:54 AM
Colton's Avatar
How fast? FAST!
Colton is offline
post #11 of 26 Old 04-03-2013, 09:19 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Adapter on HTPC is 300mbps 2.4ghz.
smokarz is offline
post #12 of 26 Old 04-03-2013, 11:10 AM
halfelite's Avatar
Quoted: 421 Post(s)
Liked: 222
if you hit anything over 60Mbit you are doing good. Throw in a wall or two and you are lucky to get 20Mbit.
halfelite is offline
post #13 of 26 Old 04-03-2013, 11:46 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
The HTPC is down in the basement and the desktop is on the first floor.
So the signal has to travel through 1 floor.
smokarz is offline
post #14 of 26 Old 04-03-2013, 11:47 AM
Kelson's Avatar
Quoted: 1950 Post(s)
Liked: 1146
Wireless bandwidths are sensitive to distance and obstacles. The further the distance the lower the bandwidth and it is not a linear decline. Higher frequency can yield higher bandwidth but is more sensitive to distance and obstacles. That is why wireless home phones have gone to lower frequencies (Dect 6.0 = 1.9GHz) to increase handset range.
Most people who have tried to stream BluRay over wireless have repeatedly hit their heads against a wall and eventually agree that wireless is not suitable for BluRay. BluRay has a max transmission bitrate of 54Mbps. So as has been noted, anything over 60Mbps is good -- I would go further and say exceptional.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #15 of 26 Old 04-03-2013, 12:23 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I guess if you want wireless... The way to go would to have wireless routers or repeaters all over your house if you want to stream HD.
ellisr63 is offline
post #16 of 26 Old 04-03-2013, 12:34 PM
halfelite's Avatar
Quoted: 421 Post(s)
Liked: 222
still most likely wont work. Its not the speed issue that gets you. its the integrity of the connection. Because wireless never takes the same path twice in a row. You never get a constant stream there is ups and downs which video streaming does not take to kindly.
post #17 of 26 Old 04-03-2013, 01:39 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Well I guess when we do the HT conversion in the garage I will be running more cat 6 cable.
ellisr63 is offline
post #18 of 26 Old 04-03-2013, 02:02 PM
Kelson's Avatar
Liked: 1146
Hard wire is always the best.
- kelson h
Kelson is offline
post #19 of 26 Old 04-03-2013, 03:37 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Yup, I will use the wireless for my home automation control and cell phone and use the gigabit switch for everything else.
ellisr63 is offline
post #20 of 26 Old 04-04-2013, 01:06 AM
Sileem's Avatar
Can you adjust router to 40 MHz bandwidth?
Sileem is offline
post #21 of 26 Old 04-04-2013, 06:44 AM
UHD Addict
aaronwt's Avatar
Quoted: 5185 Post(s)
Liked: 3097
I use a couple of Asus RT-N56U routers. Running the custom Padavan firmware. I have them set for 40Mhz and I can get 150Mb/s throughput to/from my laptop. Now I did have to go through all the 5Ghz channels to get one(channel 40) that would give me those speeds. But all the 2.4Ghz and the other 5Ghz channels gave me 100Mb/s+ throughput with transfers. But only channel 40 allowed me to hit 150Mb/s. Of course I not too far away from the router when I'm getting those speeds either.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #22 of 26 Old 08-21-2013, 11:50 AM
RoyalEF's Avatar
Using an Aruba 135 AP and a MacBookPro I sustained 105mbps in real world transfer while the wireless speed was 450. This seems to be the best possible. Note that you need Gig backends on the AP as well as to any wired source. I also own the Netgear WNDR4300 (apparently identical to TP). I believe I achieved the same rate there. However this is on the 5Ghz a spectrum. I've lent it out to a office so I can't do a quick test.
If you want wireless performance, you have to leave the b/g spectrum behind. b/g based wireless and performance aren't very practical in a lot of real world situations. There are only 3 clear channels on b/g, more than a dozen on a. When you use channel 6 on b/g you're transmitting on 4 through 8. 40hz banding require two channels per AP, and b/g is exhausted already. b/g is disturbed by bluetooth, wireless phones, hotspots, your microwave, even motion detectors are using 2.4ghz. I had an office in Denver where half the APs on two floors detected high interference when people used the microwave. 802.11a is cleaner, less populated and focused. B/G travels further distances, lowering speed and consuming more airtime as distance increases. Did you really want your router trying to associate with a device 300 feet from your router? In commercial APs you get to eliminate the slowest speeds 1mhz, 2mhz, 5mhz that service devices far away or ancient 802.11 b only. This focuses performance and coverage. With consumer products you can't be that specific.
In Manhattan offices, it is common to see 30-80 SSIDs sitting at a desk. Most of those are historically B/G signals because people didn't pay extra to buy into A and B/G travels further. B/G is a crowded world. And more devices are joining in all the time. Standing outside a dormitory building I saw well over 100 routers. And wireless constantly changes throughout the day, so spot check may not show your the whole picture.
I used a netgear 802.11a/n ethernet bridge on my Boxee to play HD videos. I believe it even played the massive 11GB bluray encodes.
RoyalEF is offline
post #23 of 26 Old 08-21-2013, 11:39 PM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
See http://www.smallnetbuilder.com/lanwan/router-charts/
You can see some actual measured numbers with option to select the measurement you are interested in
Edit: You may also find this interesting 'It Takes A Neighborhood To Fix Bad Wireless'
http://www.smallnetbuilder.com/wireless/wireless-howto/31656-it-takes-a-neighborhood-to-fix-bad-wireless
undecided is offline
post #24 of 26 Old 08-22-2013, 05:38 PM
Avdad's Avatar
I could totally be in left field but I think your connection speed will not achieve it's fastest possible speed if slower connections are present I have an N downstairs and a G access point in my garage. Slow stuff connects to the G fast to the N. I can do Vudu with my wifi tv upstairs in 1080p on the N network.
Hope this helps, just a shot that worked for me.
Avdad
I'd rather die while I'm living then live while I'm dead!
Jimmy Buffett
Avdad is offline
post #25 of 26 Old 08-23-2013, 04:55 PM
MrMcCrackin's Avatar
Quoted: 20 Post(s)
i tried to stream a bluray via N last night and it was choppy - the alarm motion sensors and B/G interference makes perfect sense.
however - i fear i am still left with running cat5 - i will have to wait till the wife is out of town so she doesnt see me cutting holes in the drywall.
MrMcCrackin is offline
post #26 of 26 Old 08-24-2013, 09:14 AM
herushan's Avatar
One way to test your speeds is using iperf which you can test each way direction between two devices very accurately. You just need iperf on the two devices you want to test throughput with and let it run to see what your real throughput is.
I run a pfsense firewall/DHCP/etc. and just upgraded to a UniFi UAP-AC and the UniFi controller software version 2.4.5 that I am running shows link rate speeds and connection percentage, which is cool. I run N only in the 2.4 Ghz spectrum and put devices that I want less interference with on the 5 Ghz N/AC side. All 2.4 Ghz spectrum is crowded these days and the best way to keep speeds is to limit your access point (AP) to N only and upgrade any of your old devices to the N standard so you do not lose speed. That is from when a B/G device joins your AP your N device speed drops as well , and I believe "A" does the same on the 5 Ghz side.
The smallnetbuilder links are great resources and setting up a good wireless network can be difficult.
Panasonic 60ZT60
Onkyo TX-NR818
OPPO BDP-103
KEF Fivetwo Series Model 11
SVS PC12 Plus
Xbox One
herushan is offline
