stream home server movies with directv deca device - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-05-2013, 04:52 PM - Thread Starter
dzirkelb's Avatar
Quoted: 45 Post(s)
I had directv and ties into their deca units to get Internet at each TV. I was able to stream my 1080p mkv with be audio flawlessly to an htpc per each TV.
I recently cut the cable chord, so I started using power over Ethernet devices instead. this works, hub now my movies buffer using xbmc, assuming due to network lack of speed.
so, can I use directv deca devices without any receivers? I have all the hardware, just not the receivers.
dzirkelb is offline
post #2 of 7 Old 04-06-2013, 12:38 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
You could try using a UPnP/DLNA server (Serviio, Mezzmo) instead on the PC holding the media, you wont get XBMC media library* but for playing files it would give a speed boost to the powerline adapters.
* It is possible to sort of get XBMC media library if using XBMC as a UPnP server to other XBMC instances as clients.
Alx330 is offline
post #3 of 7 Old 04-06-2013, 07:55 AM - Thread Starter
dzirkelb's Avatar
Quoted: 45 Post(s)
I have about 4 Tb of movies, so they will need to stay where they are on the home server.
it's strange. Apple TV, wireless, never fails. built in Hulu app hard wired on same tv through power line adapter buffers on occasion. Apple TV makes a good product for sure, just no xbmc on the latest model.
might do plex on my roku, but it is a little flaky.
dzirkelb is offline
post #4 of 7 Old 04-06-2013, 08:37 AM
Ponziani's Avatar
Quoted: 17 Post(s)
I've never tried a setup without any DTV receivers at all, but in two rooms I have a DECA with an external power adapter to provide network access to the room, and that works fine. However, you probably wouldn't be able to have an antenna or regular cable TV signal on the coax at the same time, since DECA differs from MoCA adapters in the frequency range that it uses (geared specifically to avoid the range DTV uses).
Ponziani is offline
post #5 of 7 Old 04-06-2013, 11:21 AM - Thread Starter
dzirkelb's Avatar
Quoted: 45 Post(s)
that would be fine about the antenna signals.
how do I power them at each TV? one has a power adapter, rest used to get power from the receiver it seemed, but so t now I don't thi I without it
dzirkelb is offline
post #6 of 7 Old 04-06-2013, 03:37 PM
Ponziani's Avatar
Quoted: 17 Post(s)
Satellite online vendors like Solid Signal have power adapters (or at least they used to). I have the white DECA adapters, can't speak to the newer ones.
Ponziani is offline
post #7 of 7 Old 04-06-2013, 04:59 PM - Thread Starter
dzirkelb's Avatar
Quoted: 45 Post(s)
dzirkelb is offline
