How do I link multiple NICs in the same machine so that all connected devices can be seen from the network? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-09-2013, 01:52 AM - Thread Starter
ddg69's Avatar
Hello Everyone,
We have a terminal srever running Windows Server 2008 with multiple NICs. Equipment being monitored feed 2 switches that run their aggregates into two of 5 NIC cards (well call then NIC 2 and 3), then I have set up a 3rd NIC (nicknamed NIC 1) for our local network access. Our local network is on our own VLAN, so all firewalls are turned off. I can ping from other terminals on the network to NIC #1 but not to the other NICs. Of course I can ping everything from the server. We are using static IPs. I have tried setting everything up on the same subnet / subnet mask, different subnet / same subnet mask but neither worked. I tried to bridge the devices, but had other issues that prevented me from getting an accurate result. I am using IPs of 10.1.1.X for the network and 10.1.93.X for the equipment (although, like I said, I tried making everything the same subnet to no avail), and a subnet mask of 255.0.0.0. My question is, am I on the right track with bridging, or do I need to team them? Honestly, a step-by-step guide would be very helpful.
Thank you
ddg69 is offline
post #2 of 4 Old 05-09-2013, 06:16 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
This is something I would be interested in knowing as well! Can you post your server specs / model as well as the NIC?
GusGus748s is offline
post #3 of 4 Old 05-09-2013, 07:54 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I have WS2012E with Dual NICs. You just need to set them up for teaming (which I have done). Just do a search for Teaming NICs
http://blogs.technet.com/b/josebda/archive/2010/09/03/using-the-multiple-nics-of-your-file-server-running-windows-server-2008-and-2008-r2.aspx
This is what I did for 2012E:
http://blogs.technet.com/b/privatecloud/archive/2012/06/19/nic-teaming-in-windows-server-2012-brings-simple-affordable-traffic-reliability-and-load-balancing-to-your-cloud-workloads.aspx
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #4 of 4 Old 05-11-2013, 12:23 PM - Thread Starter
ddg69's Avatar
Thanks guys, but I found the solution on Thursday. All I had to do is go into the Change Adapter Settings menu, highlight the NICs I wanted to put together, then right click on one of them and select bridge. That created a new entry with the bridged title. Then it was simply changing that new bridge entry's IP and subnet mask to the main network's and Walah!!! Now I can see all the attached equipment on all that server's NICs from across the main network. I had just locked one of the switch's ports, so had lost connectivity to the network.
ddg69 is offline
