Need advice for best whole-house strategy. Using Cablecard / HTPC. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-16-2013, 04:26 PM - Thread Starter
RandyL712's Avatar
So I've been using a PC-based setup for a few years and love it. Win7 Media Center, Cablecard with Ceton tuner. Works great. But I've just moved to a new house and now want to get the signal into a few more rooms. (Up to now it's just been in my family room).
In addition to the main TV in the family room, I've got a little theater room in the basement, plus a TV over the bar, and one in the bedroom.
What's the best way to accomplish this? I've considered using a Ceton Echo, but much of what I watch other than recorded TV is MKV and ripped DVD's in VIDEO_TS folders, and apparently the Echo is terrible at handling these. I've got an Xbox 360 that I could also use as a media extender but it likely will have the same limitations as the Echo.
Should I get a 2nd PC for the theater, running WMC, that will just access the files on the main HTPC over the (wired) network? I'm assuming/hoping that a wired network would provide enough bandwidth that the video will be smooth.
Any advice would be great.
RandyL712 is offline
post #2 of 2 Old 05-16-2013, 04:39 PM
Nethawk's Avatar
Liked: 118
Try the Xbox out. While a few disks have required some audio conversion and re-muxing, I'm very pleased with the results. I have ripped everything to MKV though. If you follow Assassin's guide and software/codec setup everything should work without a great deal of effort.
You should have no problems with a wired ethernet network. If you are setting up for the first time you may as well run Cat6 cable. Depending on simultaneous streams from the media server you can saturate a 100 Mbps network relatively quickly. I also have a Wireless-N network and one Xbox where I did not extend wire and have experienced no dropouts.
Nethawk is offline
