Streaming video with DTS-MA? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 06-06-2013, 03:53 AM - Thread Starter
mirrorman's Avatar
Hi, I've tried and tried to to stream a video file with DTS-MA audio but i can only get it to output
DTS 5.1.
I' ve tried to stream it via ps3 media server to ps3 and Samsung share all to blu-ray player,but
nothing will play it back as DTS-MA.
I've used ripbot,dvdfab,and handbrake to encode video but the end result is the same no DTS-MA.
Could someone tell me it's because it's impossible,so i can stop pulling my hair out trying to do it,
or a solution.Here's the media info from my last rip with handbrake.
Thanks in advance for any help.
General
Complete name : C:\Users\Neil\Videos\Handbrake\00485-1.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 4.99 GiB
Duration : 2h 25mn
Overall bit rate mode : Variable
Overall bit rate : 4 918 Kbps
Encoded date : UTC 2013-06-05 19:29:19
Tagged date : UTC 2013-06-05 22:13:55
Writing application : HandBrake 0.9.9 2013052900
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 25mn
Bit rate mode : Variable
Bit rate : 1 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 2.667
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 23.974 fps
Maximum frame rate : 23.981 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.045
Stream size : 1.01 GiB (20%)
Writing library : x264 core 130 r2273 b3065e6
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A9
Duration : 2h 25mn
Bit rate : Unknown / 1 509 Kbps
Nominal bit rate : 3 912 Kbps
Maximum bit rate : 5 598 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Delay relative to video : 83ms
Stream size : 3.97 GiB (80%)
Tagged date : UTC 2013-06-05 22:13:54
mirrorman is offline
post #2 of 19 Old 06-06-2013, 04:36 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
PS3 and Samsung dont do DTS-MA pass-through over DLNA, only Dobly/DTS 5.1.
Alx330 is offline
post #3 of 19 Old 06-06-2013, 05:04 AM - Thread Starter
mirrorman's Avatar
Thanks for your reply.Do you know of any device's that will stream DTS-MA pass-through over DLNA,
post #4 of 19 Old 06-06-2013, 05:26 AM
Bond 007's Avatar
Quoted: 2370 Post(s)
Liked: 1906
I dont think its possible yet to stream lossless audio. Or atleast its not available to the consumer.
Licence to Kill
Bond 007 is online now
post #5 of 19 Old 06-06-2013, 06:41 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
+1
I think that DLNA is unable to stream HD Audio. It as to go through a DLNA server like plex, serviio or PSM (the one you use) and be downconverted so your DLNA product can play it.
Anyway, DLNA is bad for many reasons. You should investigate about a real media player able to stream anhthing through a normal network connection using SMB or NFS.
Mr Eric is offline
post #6 of 19 Old 06-06-2013, 08:34 AM - Thread Starter
mirrorman's Avatar
Can anyone guide me to a media player that will stream DTS-MA? Can't seem to find one.
post #7 of 19 Old 06-06-2013, 08:46 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
The ability to pass-through DTS-MA is not a limitation of DLNA but an intentional choice by the product manufacturer. On top of that I would imagine there are very few players that support any type of DTS audio in the MP4 container.
If you want DTS-MA pass-through for network media you need to look at something like a Popcornhour A400 or Dune player (use MKV container too).
Alx330 is offline
post #8 of 19 Old 06-06-2013, 12:40 PM - Thread Starter
mirrorman's Avatar
Was thinking of buying the Dune HD Smart H1 http://dune-hd.com/eng/products/full_hd_media_players/16 i think it might be the
answer to my streaming problem with DTS-MA.
post #9 of 19 Old 06-06-2013, 01:58 PM
itznfb's Avatar
Liked: 58
Aren't you better off building an HTPC? I looked into PCH and Dune players for a while before I decided it was cheaper, easier and would play anything if I just stuck with HTPCs.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #10 of 19 Old 06-06-2013, 03:50 PM
L33TX43RT's Avatar
http://www.mediaconceptusa.com/mede8er_med1000x3d.html
L33TX43RT is offline
post #11 of 19 Old 06-06-2013, 04:31 PM - Thread Starter
mirrorman's Avatar
You must have been reading my thoughts,i just changed my mind about getting the Dune HD Smart H1
and sent off for the Mede8er MED1000X3D limited black edition from Amazon (could'nt live with anything silver)
http://www.amazon.co.uk/Mede8er-MED1000X3D-Black-Media-player/dp/B00CE8YKG6/ref=sr_1_1?ie=UTF8&qid=1370558275&sr=8-1&keywords=Mede8er-MED1000X3D-Black
post #12 of 19 Old 06-06-2013, 05:15 PM
L33TX43RT's Avatar
Congrats! Get back to us here, after you've tried it out.
post #13 of 19 Old 06-07-2013, 04:46 PM
TiSLine's Avatar
I streamed movies with DTS-MA to my BoxeeBox from my PC no problems whatsoever
TiSLine is offline
post #14 of 19 Old 06-10-2013, 06:59 AM
Charles R's Avatar
Liked: 536
I use the WD TV Play.. it's often a whopping $65.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815140004
Very limited featured set (support) but so far MKV HD audio/video bitstream wonderfully.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #15 of 19 Old 06-10-2013, 08:21 AM
myoda's Avatar
Liked: 57
The WD TV Live does not pass DTS-MA, just the core DTS track. I have no problem playing back movies with DTS-MA over my network via a pc connected to my receiver via HDMI. The WD TV Live Hubs have the same issue with DTS-MA.
myoda is offline
post #16 of 19 Old 06-10-2013, 01:52 PM
Charles R's Avatar
Liked: 536
But the WD TV Play does via DLNA... it doesn't do a whole lot more however. smile.gif
post #17 of 19 Old 06-10-2013, 02:18 PM
myoda's Avatar
Liked: 57
True, to a point. It does have a wide selection of streaming options:
http://www.wdc.com/en/products/products.aspx?id=330
I think it will also stream 3D content from VUDU, if connected to a 3D TV. I know both my WDTV Live Hubs have that capability. Will check that later this afternoon. I also found that the network connection is much better with a wired connection. The wireless for me was pretty weak - and the box was right next to the access point in my living room.
myoda is offline
post #18 of 19 Old 07-17-2013, 10:30 AM
Osirus23's Avatar
Quoted: 102 Post(s)
Liked: 256
So the WD TV Play will bitstream DTS-MA, but the WD TV Live will not?
Osirus23 is offline
post #19 of 19 Old 07-17-2013, 02:55 PM
comicguy's Avatar
correct..
comicguy is offline
Med1000x3d Hd 3d Multimedia Player
