Makemkv Question - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 07-14-2013, 06:18 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2715 Post(s)
Liked: 1947
Originally Posted by stefuel View Post
Can you re-open a MKV? For whatever reason the BD "Transformers 2" is working from the flat screen. If I could re-open it to see what audio selections I made with that one, perhaps my problem will be solved.
The free "mkvmerge" package will allow you to inspect the file attributes and has a header editor to alter them.
Another utility, "mediainfo" will show the attributes but not alter them.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #32 of 45 Old 07-14-2013, 02:22 PM
stefuel's Avatar
Quoted: 27 Post(s)
Liked: 24
Well I have made a discovery. For whatever reason the LG flat screen or the older WD media player has a brain fart when TrueHD is in da room. Kinda like me and breasts.
Anyway, I re-ripped a few without trueHD and all is well. I'm only doing 5.1 in the theater anyway so I can do without the TrueHD for now.
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #33 of 45 Old 07-26-2013, 06:02 PM
stefuel's Avatar
Quoted: 27 Post(s)
Liked: 24
I just had to renew the key on my beta version of MakeMKV. Is there any functional difference between the beta version and the paid version other then getting a forever key?
stefuel is offline
post #34 of 45 Old 07-26-2013, 10:35 PM - Thread Starter
mijotter's Avatar
Liked: 59
Can you place where subtitles go with this software so that they actually appear on the screen rather than below it? I'll have a CIH scope screen.
mijotter is offline
post #35 of 45 Old 07-27-2013, 03:01 PM
lockdown571's Avatar
Quoted: 37 Post(s)
Liked: 87
No
Subtitle positioning depends on your playback software.
lockdown571 is offline
post #36 of 45 Old 07-27-2013, 06:25 PM - Thread Starter
mijotter's Avatar
Liked: 59
oh ok. What playback software would you recommend then?
mijotter is offline
post #37 of 45 Old 07-28-2013, 04:09 PM
mjt5282's Avatar
Quoted: 16 Post(s)
I have a 2.35 (CIH) screen, too and use DunePlayer to playback my MKV's (which can vertically shift subtitles), see this thread : http://www.avsforum.com/t/1264144/hdi-dune-will-soon-vertically-shift-subtitles
mjt5282 is offline
post #38 of 45 Old 07-28-2013, 04:23 PM
stefuel's Avatar
Quoted: 27 Post(s)
Liked: 24
Originally Posted by lockdown571 View Post
No
I think the latest beta key is only good till the end of this month. Is there a new key available?
stefuel is offline
post #39 of 45 Old 07-28-2013, 10:13 PM - Thread Starter
mijotter's Avatar
Liked: 59
So there is no way from a HTPC to shift the subtitles?
mijotter is offline
post #40 of 45 Old 07-29-2013, 03:58 AM
elario's Avatar
Quoted: 42 Post(s)
Liked: 65
There is lots of ways. It depends on the software you are using.
VLC, MPC-HC, XBMC etc can all do it in their own ways. You just need to play around with the options. There is no point in me telling you exactly how to do it because I don't know what res and AR you want to output to your projector.
elario is offline
post #41 of 45 Old 07-29-2013, 04:07 PM
Quoted: 37 Post(s)
Liked: 87
Makemkv is free while in beta. He supplies a new key each month. Who knows when the beta will end, but it's been in beta for years now.
I can see an option right now in mpc-hc. You will just have to play around with whatever software you want to use. It sounds like you can change vertical position in XBMC. I'm sure you can change position in JRiver too.
post #42 of 45 Old 04-10-2015, 10:46 PM
Archaea's Avatar
Quoted: 2873 Post(s)
Liked: 2452
I'm trying to collect some demo clips for my theater from my bluray collection. I ultimately wanted to make my own bluray demo disc, but I've never found affordable, reasonably simple software to author a bluray, so I'll be content to play the short demo clips from my HTPC.
I ripped my Brave bluray using makemkv to make a demo clip of the Brave intro where the big bear is introduced, but even when I select 7.1 audio during the makemkv ripping selection, and it seems to rip without error --- then can't seem to get my cyberpower dvd 10 software, nor JRiver to recognize more than 5.1 sound on the this particular rip. My playback software works with other clips I've made and demo discs like the ones that scubasteve, @Jindrak, and @superleo made.
I use tsmuxer to shorten the full rip to a couple minute clip and when I try to load this Brave rip into tsmuxer to make the demo clip I get this error message. I assume this is a problem with the audio track somehow.
Then it appears I'm missing the HD 7.1 track in the list of available audio streams in tsmuxer. I've tried ripping the bluray twice with makemkv -- same problem both times.
Anyone have any suggestions?
Name:	TSMuxer Error.jpg
ID:	660169   Click image for larger version
ID:	660177   Click image for larger version
Name:	missing 7.1 track.jpg
Archaea is online now
post #43 of 45 Old 04-10-2015, 11:01 PM
Archaea's Avatar
Liked: 2452
hmmm
interesting
I found that I do have the stream for 7.1 that shows up in JRiver in the original rip, but not in Cyberpower DVD.
When tsmuxer is used to make the actual demo clip I no longer have the option in JRiver for 7.1, just regular 5.1. So it appears the problem is two fold.
One - tsmuxer can't utilize the rip, and
Two - PowerDVD can't see the 7.1 stream in the original rip.
post #44 of 45 Old 04-11-2015, 07:50 PM
Jindrak's Avatar
Quoted: 51 Post(s)
Liked: 122
Are you using a HTPC for streaming? If so, you will need to configure you base computer's speaker configuration for 7.1 in the system audio settings, then it should allow you to actually use 7.1 I use a HTPC myself and have noticed this. Unfortunately, I can't comment on MakeMKV, I use DvDFab HD. But if you select the 7.1 audio track, it should correctly pull that audio (as long as that is the only track you select) and display it as such.
If one is going to make a simplistic assessment of the value of different alignments, it would be that sealed/IB goes the lowest, at the highest cost per dB; horns have the lowest cost per dB at the expense of size, and vented box characteristics lie in between the other two. None is inherently superior across the board, neither is any inherently inferior across the board. The one to use is the one that fits your response and output needs, available space and bank account. -BFM
Jindrak is offline
post #45 of 45 Old 04-12-2015, 09:20 AM
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Same here Johny, can't comment on Makemkv, I use Anydvd hd. I have a suggestion for testing purposes, and that is what I do for demos too -- when I cut the clip with TsMuxer I only select the audio track that I want to be the default, in this case the 7.1 audio track. The playing source should be smart enoug to convert it to regular DTS or Dolby or AC3 if the audio stream, for whatever reason, is not supported. By doing this, it also helps to keep the size of the demo clip smaller.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
Dune Hd Smart B1 1080p Media Player
