Not seeing the drive and folder where my MKV rips are. - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2013, 10:11 AM - Thread Starter
stefuel's Avatar
Quoted: 31 Post(s)
Liked: 24
Didn't want to further hyjack someone elses thread so I'm starting this one that will probably be short lived because I think it's a simple problem that someone with Win7 experiance can solve in a heartbeat. I have two drives on this PC. The C: drive has the OS and other applications on it. I believe I have set permissions correctly for Windows Media center as the two sample videos provided in it play from a WD media player. However, my MKV files are on drive M: in a folder named "MKV". I think I need to set additional permissions for that drive and folder for those files to stream. I have no Win 7 experiance and don't see how to set the additional permissions for the second drive.
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is online now
Old 07-08-2013, 10:40 AM
Nethawk's Avatar
Liked: 118
Nethawk is offline
Old 07-08-2013, 03:31 PM - Thread Starter
stefuel's Avatar
Quoted: 31 Post(s)
Liked: 24
Thanks, tried it. Still no go. I'm writing to the drive (M:) and folder (MKV) OK. I can go to the PC and see that the 6 BD's and 2 DVD's I ripped are actually there. I just can't see them from the WD player.
Old 07-09-2013, 03:18 AM - Thread Starter
stefuel's Avatar
Quoted: 31 Post(s)
Liked: 24
This must be a "permissions/security" issue. I switched gears and looked through all the settings options on the WD. In file management I do see my folder "MKV" but when I select it I get a message "no media present" or something to that effect. Should have wrote it down.
BUT it does at least see the folder and I know there is 8 movies contained in that folder.
When I right click that folder, it does say that it is shared, In a earlier post I was told to make sure that "everyone is enabled in sharing AND in security". I did not see that option in security.
Might this older WD require movie files in their own folder?
Do I have a path issue?
Do I have a permissions or security issue?
Old 07-09-2013, 04:22 AM
DanPackMan's Avatar
Quoted: 254 Post(s)
Liked: 407
Your folder is shared with Homegroup, but that is not good for the WD, it requires open sharing (i.e. everyone). Right click on the folder you want to share, select properties, then share folder, then add "everyone" to the sharing list.
DanPackMan is offline
Western Digital Wd Tv Live Streaming Media Player
