Confused about best streaming option, mediaplayer or Samsung Blueray with wifi - AVS Forum | Home Theater Discussions And Reviews
Old 07-09-2013, 10:42 AM - Thread Starter
Heyjohn's Avatar
Hi everyone. I am new with all the streaming and networking options available . I have a Samsung BD-D5700 blueray attached to my Samsung tv and networked with my home computer. I do not use internet streaming since I have a wireless internet and is very expensive. (The blueray does have a Netflix app if i want to stream a movie but only once in a while.) For the best picture quality steaming from my computer ( or an ext usb hardrive) is a separate mediaplayer better than the internal streamer on the bluray? I cannot see for the price of a blueray player (with its extra hardware, drives, etc.) comparing to a separate mediaplayer in terms of performance or quality . Since I dont really want internet streaming maybe what I only need is an ext usb hardrive connected to a mediaplayer or the blueray, but I am not sure. Any suggestions or tips? Thank you.
Heyjohn is offline
Old 07-09-2013, 02:03 PM
Selden Ball's Avatar
Quoted: 3095 Post(s)
Liked: 1512
If your computer has an HDMI, DVI or DisplayPort output, you might consider connecting it directly to your TV or receiver instead of going over the network through a Blu-ray player or media streamer. (Adapters from DVI or DisplayPort to HDMI are readily available.)
DLNA streaming support tends to be fragile. Too often a video or audio format which plays OK on a computer can't be played through a Blu-ray player. Also, connect your systems together using ethernet cable if you can. Wireless networking is prone to problems, especially dropouts. Wired connections are much more reliable.
Selden
Selden Ball is offline
Old 07-10-2013, 08:05 AM
rdb4133's Avatar
rdb4133 is offline
Samsung Bd D5700 Blu Ray Disc Player Black
