Apple TV handshake issues with Dennon AVT 2112ci - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 07-20-2013, 06:03 AM - Thread Starter
harleysilo's Avatar
Plug Apple TV directly to LG 55" 3d TV it works. Use any of the ports on receiver and I get nothing. Is there a troubleshooting guide for handshake issues, or a step by step procedure? Why can't all this stuff be plug and play as advertised?!?!
harleysilo is offline
post #2 of 25 Old 07-20-2013, 07:15 AM
bluechunks's Avatar
Quoted: 154 Post(s)
Liked: 198
I'm sure you have tried this---but have you tried shutting down both the ATV and AVR and then physically unplugging the ATV power cord prior to connecting it to the AVR and then booting it up once it's connected and the AVR is on?
If this is a handshake issue it should play nice afterward since the ATV is "always on" and might be expecting to see the LG instead of the AVR.
Also, is your 2112ci connected to your home network?? (There have been a few firmware updates since the unit was released and while they are not listed on the support webiste they can be download directly by the AVR via the internet.)
__________
Visio P65-C1 / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ / Speakercraft (Ceiling) / Hsu sub / Celerity 50' Fiber HDMI
bluechunks is offline
post #3 of 25 Old 07-20-2013, 08:22 AM - Thread Starter
harleysilo's Avatar
So i tried that, hasn't worked. AVR is not connected but I could connect it later and get firmware updates, I've never done that is it easy or difficult? Do I have to navigate to a website or does it just do it on its own?
post #4 of 25 Old 07-20-2013, 08:44 AM
bluechunks's Avatar
Quoted: 154 Post(s)
Liked: 198
I don't currently have a Denon but it's a pretty easy procedure on the AVRs that I have owned. Just follow the instructions in the User Manual.
__________
post #5 of 25 Old 07-20-2013, 09:14 AM
creativeoutleh's Avatar
I have the same problem between my Apple TV 3 and Denon 4311. The video from the ATV just doesn't appear or it flickers a lot every once in a while. All firmware is up to date. I don't feel like I've solved the problem but I've changed my HDMI cable and it seems to have reduced the occurrence of this. You can reset it by pulling the hdmi cord or power on the atv, buts its a hassle.
creativeoutleh is offline
post #6 of 25 Old 07-20-2013, 09:53 AM - Thread Starter
harleysilo's Avatar
I guess I can try a new cable, just bought this one with the ATV, but it could be bad.
post #7 of 25 Old 07-20-2013, 10:33 AM
bluechunks's Avatar
Quoted: 154 Post(s)
Liked: 198
Seems like a reasonable idea to double-check. Also remember that HDMI is an end-to-end protocol so the cable between the AVR and the TV is also a consideration.
If you need replacement cables look for "high speed" HDMI cables, and FWIW, I've always had great performance from the low-priced but high quality cables from Monoprice as well as Amazon "basics."
__________
post #8 of 25 Old 07-20-2013, 10:39 AM - Thread Starter
harleysilo's Avatar
The cable from AVR to TV, is working for cable, DVD player, does that rule it out? It goes through a wall so I'm only changing it if necessary.
Can try a different cable soon getting ready for a party.
Figuring out how to flash the AVR will have to wait till tonight or tomorrow, thank you all for the help!
post #9 of 25 Old 07-20-2013, 11:02 AM
bluechunks's Avatar
Quoted: 154 Post(s)
Liked: 198
A qualified maybe.
If the cable box or DVD player is not sending a high-bandwith 1080p/60 signal like the ATV (i.e. 1080p/24, 1080i/30, 720p/60, or 480i/30 instead) it's possible for for the existing cable to work with the lower bandwidth signals and then choke on the 1080p/60 from the AppleTV. This is where the concept of the "high speed" HDMI cable is potentially an issue. You can test this by setting the ATV output resolution to a fixed setting like 720p/60 or 480p/60 that uses less bandwidth and see if that works if this is still an issue after the AVR update.
__________
post #10 of 25 Old 07-20-2013, 12:58 PM - Thread Starter
harleysilo's Avatar
So I got Ethernet run, and it connected to the Internet and Internet radio works. Couldn't figure put how to update firmware, but read it can take 1 hour so it will have to wait until tonight.
post #11 of 25 Old 07-20-2013, 03:30 PM
bluechunks's Avatar
Quoted: 154 Post(s)
Liked: 198
FWIW, "Firmware Update" is in the Option Setup menu (starting on p.95) and specially p. 96 of the User Manual that I linked in the earlier post.
Since you have the ethernet run for the moment it would probably also be an opportunity to verify the firmware of the TV if the TV can update itself (otherwise download the TV firmware from the LG support site onto a USB stick). Although I seriously doubt there is a problem with the TV since it worked when directly connected to the ATV, it could also remove a potential variable in its interaction with the AVR---however unlikely.
__________
post #12 of 25 Old 07-21-2013, 05:42 AM - Thread Starter
harleysilo's Avatar
Okay so far I have .....
Updated the firmware for the AVR
Tried a different HDMI cable
Set ATV to 720/60
Still doesn't work
Still does work on either cable and at any ATV setting hooked directly to TV.
Will now see about TV updates but don't think that is the issue.
Thanks again for all suggestions.
post #13 of 25 Old 07-21-2013, 06:03 AM
bluechunks's Avatar
Quoted: 154 Post(s)
Liked: 198
Wow. Its sounds like most of the variables have been eliminated.
Two other long-shot ideas:
1) In addition to setting a lower resolution on the ATV, have you tried setting a specific colorspace instead of "Auto" on the HDMI Output setting of the ATV? (example: YCbCr)
2) Have you tried plugging the ATV into a working HDMI port on the AVR used by the cable box or DVD player in the event there is a bad port on the AVR?
__________
post #14 of 25 Old 07-21-2013, 06:25 AM - Thread Starter
harleysilo's Avatar
I tired setting the color thing independent of resolution, not at the same time.
I will try using an existing known good port.
LG said its clearly not the TV
Apple said they never heard of a problem like this LOL
and that I could bring in my AVR and ATV to a store and use known good high speed HDMI cables and if still an issue report it to engineers....
post #15 of 25 Old 07-21-2013, 06:27 AM - Thread Starter
harleysilo's Avatar
Oh and can't call denon till tomorrow, never dealt with them so don't know if it will help.
post #16 of 25 Old 07-21-2013, 06:41 AM
comicguy's Avatar
the only suggestion i have was listed above. Trying a different known working port on the Denon. I had a Denon 4311, a100, 891 and a few others and never had a problem with my apple tv 3rd gen..
also try different cables when you try a different port..
comicguy is offline
post #17 of 25 Old 07-21-2013, 06:50 AM - Thread Starter
harleysilo's Avatar
Okay. So I plugged it into the DVD port (where I had the BLue Ray player) and it works. However I can't get the blue ray to play on the BD port (the one I've been trying to use) nor V Aux. so either two ports are dead or its a configuration issue, right?
post #18 of 25 Old 07-21-2013, 07:14 AM
bluechunks's Avatar
Quoted: 154 Post(s)
Liked: 198
And yes, it sounds like a dead port or a config issue. At least now you can focus your efforts on the Denon.
__________
post #19 of 25 Old 07-21-2013, 07:48 AM - Thread Starter
harleysilo's Avatar
It's got to be a port assigning issue or something, I tried the four ports I have that aren't currently used.
Page 101 of the linked manual appears to be what I need to investigate.
Although the would appear to be set up how I need them from the factory...
post #20 of 25 Old 07-21-2013, 08:23 AM
comicguy's Avatar
First things first. Go do a complete factory reset on the Denon, THEN continue troubleshooting...
comicguy is offline
post #21 of 25 Old 07-21-2013, 08:57 AM - Thread Starter
harleysilo's Avatar
Okay so I was able to assign DVD to Hdmi 3 and get all three to work.
Unfortunately my zone 2 only runs off of RCA's, are the optical to RCA adapters any good? So as of right now no ATV on zone 2.
post #22 of 25 Old 07-21-2013, 06:17 PM
comicguy's Avatar
monoprice one i used was quite good..
comicguy is offline
post #23 of 25 Old 07-22-2013, 07:02 AM - Thread Starter
harleysilo's Avatar
Okay so reflecting back on the weekend I am an idiot. That should have taken all of 5 mins. to get operational if I knew what I was doing. I think this new receiver is the first electronic thing I’ve had I actually had to read the majority of the manual for. I still don’t understand several things, like for instance how the heck do I get the menu to just open up? I press menu button and nothing. If I change the audio format and then hit menu up it comes. Not only that I have two different menus. It’s really quite ridiculous.
This whole analog only for Zone 2 is such BS, but whatever.
Anything wrong with this deal off of Amazon, I‘ve got to order something else from them adding this I get free shipping? http://www.amazon.com/D3-Digital-Converter-Optical-Toslink/dp/B005K2TXMO/ref=sr_1_2?ie=UTF8&qid=1374500279&sr=8-2&keywords=optical+audio+cable+converter
post #24 of 25 Old 07-22-2013, 07:55 AM
comicguy's Avatar
I don't know about that one, but I used this one with n adverse effects for my mom:
http://www.amazon.com/SANOXY%C2%AE-AGPtek-Digital-Optical-Converter/dp/B005DIRI6I/ref=sr_1_3?s=electronics&ie=UTF8&qid=1374504843&sr=1-3&keywords=optical+audio+cable+converter
comicguy is offline
post #25 of 25 Old 07-22-2013, 04:00 PM - Thread Starter
harleysilo's Avatar
Wow, Denon help line chick was actually super helpful, and knew her stuff!
She explained everything to me!
Denon remote APP is sweet!
Just need to see if my denon can read my external hard drive, if it can problem solved, if not ill get the converter.
Thanks again!!!!
Denon Avr 2112ci Receiver , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a
