PoE Access Point? - AVS Forum
post #1 of 5 Old 07-23-2013, 09:51 PM - Thread Starter
killswitch1968's Avatar
I'm looking for a WAP for the main floor of my house, the modem + router is in the basement. This just needs to cover a main floor of about 1800 sqft. I have a PoE switch and I'm trying to find a PoE WAP but I'm a bit overwhelmed at the wide variation in price and not sure what I should be looking for. I'd like something fairly discrete that could even sit on a wall somewhere, but I'm open to anything. Budget of about $200.
killswitch1968 is offline
post #2 of 5 Old 07-24-2013, 07:12 AM
BlacMagik's Avatar
Check out Ubiquiti's UniFi line @ http://www.ubnt.com
killswitch1968 likes this.
BlacMagik is offline
post #3 of 5 Old 07-24-2013, 08:38 AM
watchy's Avatar
I would suggest checking out ubiquitis like the last post said. they are about $99 for 802.11/b/g/n. Get a POE adapter from Ubiquiti to take normal POE power to Ubiquitis dumb POE standard.
watchy is offline
post #4 of 5 Old 07-24-2013, 09:33 AM - Thread Starter
Thanks for the advice! The more basic and inexpensive models do use a different PoE standard, so I would have to use an adapter. I was hoping to use my existing 803.3af switch but the Ubiquiti WAPs are still the way to go even if I already have a PoE switch?
post #5 of 5 Old 07-24-2013, 03:01 PM
watchy's Avatar
Yes. They make a little Adapter you put between the switch and he Ubiquiti AP. It will change the 802.3af to Ubiquitis standard inline and power it. You don't need extra power supplys / cables etc. I just put 20 of them at my office.
http://store.wisp-router.com/POE-INS8023AF-I
get that for each AP. they are way smaller then you would think. smaller then the head of a standard screw driver.
watchy is offline
Ubiquiti Networks Unifi Ap Enterprise Wifi System
User Tag List
