*Official* Google Chromecast owners thread - Page 24 - AVS | Home Theater Discussions And Reviews
 8Likes
post #691 of 703 Old 02-18-2015, 03:16 PM
HopefulFred's Avatar
Quoted: 264 Post(s)
Liked: 248
Originally Posted by Boothbay View Post
Doesn't one have to have a browser in order to continue? If so, how does one get a browser on my Smart tv? Thanks...you can see i am confused. LOL
It depends on what else you have going on in your house or WiFi network. Most of my use for my Chromecast comes through casting tabs from the Chrome browser on my PC. I can watch Hulu or just show my wife something (like a funny image or nonsense from Facebook) by casting the tab. This requires the Chrome browser and the free Google Cast extension.
The other simple thing to do is use a tablet or smartphone with one of the supported apps, like YouTube (or WatchESPN, or Vudu). When I connect my phone to my WiFi network and launch the YouTube app, an extra icon appears to control casting. Once I select a video to watch, I tap the cast button and tell the app to play the video on the Chromecast. It's magic.
HopefulFred is online now
post #692 of 703 Old 02-18-2015, 04:15 PM
Boothbay's Avatar
I don't understand the first part of the Quote///"It depends what else i have going on in my home".? On my bedroom setup tv/Monitor I was able to go to chromecast website, but although i have wi-fi with my new smart tv, I do not know how I can get Chromecast there? There is what they call a browser, but it does not make any sense in part, cause a keyboard or the option to use my keyboard ( that I am aware of ) to be used to go and download Chrome. Also, what puzzle's me is once you have it setup on one TV, does it have to be re-setup for any other TV? I now recall after doing the bedroom setup, I did go to the internet and and downloaded something, I forgot what it was...this was done almost 2 months ago when i just did it once and forgot about it till now...Thanx
Boothbay is offline
post #693 of 703 Old 02-18-2015, 04:28 PM
Geezer's Avatar
You can only cast to the device it is plugged into.
Geezer is offline
post #694 of 703 Old 02-18-2015, 04:44 PM
Quoted: 264 Post(s)
Liked: 248
I'm confused. Did you purchase a Chromecast and plug it into the TV's HDMI input? After that, download and run the setup app from a computer or tablet/smartphone connected to the WiFi: https://cast.google.com/chromecast/setup/ (you won't be able to use the TV's browser for this, I think, because you'll need the TV set to the Chramecast's HDMI input during the setup process, and I don't think the setup app will install and run on your TV - it's designed for either PCs or smartphones/tablets) When you run the setup app, the Chromecast device gets connected to your WiFi network. Once that is done, you can direct video streams to the Chromecast using one of the techniques I described. Does that make sense?
The Chromecast is designed to work in a passive, behind-the-scenes sort of way. It requires a third device (TV, Chomecast, plus one other device) to work as a remote and interface to select content.
post #695 of 703 Old 02-19-2015, 09:12 AM
Liked: 0
I think I may have gotten ethernet working on the Chromecast. Can anyone suggest a way to test the speed? My DHCP router is a WNDR3700v3 and I also have a WNR3500L and a WRT310N. I turned off my radios on all the SSIDs I ever told my Chromecast to connect to. I have an E2500 on the other end of the house, but I never told Chromecast to connect to it, so it shouldn't be using that.
The steps I used were:
Plug Powered USB Hub into Power Adapter via AC
Plug USB Hub into OTG Cable
Plug OTG Cable into Chromecast
(At this point the Chromecast LED lit up and booted)
Plug USB Ethernet Adapter into USB Hub
Plug Ethernet line into USB Ethernet Adapter
(At this point the USB Ethernet Adapter's RJ45 jack started blinking)
When I checked my DHCP enabled router for "Attached Devices", the Chromecast showed up under "Wired".
To "make sure", I disabled my wireless radios on both of my routers supplying WiFi.
It seemed not to work for a bit, but after waiting(and realising I could not push a YouTube video from my Android when my WiFi radios were off), and pushing a video from my Laptop, it seemed to start working.
So, at this point I'm wondering what the speed and ping is that I am getting and I am also pondering the possibility as using it as a "wireless" display for a laptop hooked up to Ethernet.
xnamkcor is offline
post #696 of 703 Old 02-20-2015, 01:34 PM
catnap1972's Avatar
Seems I'm having the same issue someone else did awhile back where having the Chromecast connected to ANY HDMI port would cause the picture to break up every couple of seconds. Panasonic TC-L32X1, connect Chromecast and even signal from the tuner would go haywire from time to time even with a good reception. Either unplug the device from the TV altogether or just pull the power cable from it (but leave it attached to the TV) and the problem stops. I've tried the extender, using different HDMI ports and substituted the power adapter but makes no difference.
catnap1972 is offline
post #697 of 703 Old 02-20-2015, 01:55 PM
Liked: 0
<br />
<br />
My best guess is that it might be drawing or producing too much power. If you have &quot;MHL&quot; HDMI ports, try using the type you aren't using. My stupid advice us to block the pins that have to do with voltage on the hdmi port.
PS: Is there a reason the instructions for routing or flashing(I forget which) require some kind of Teensy?
xnamkcor is offline
post #698 of 703 Old 02-20-2015, 02:16 PM
catnap1972's Avatar
And I've disabled Vieralink but doesn't help, in case anyone suggests that.
post #699 of 703 Old 02-22-2015, 04:59 AM
Hunter67's Avatar
Not sure when this started but I noticed last night that HBOGO now streams in Dolby Digital Plus from Chromecast, can anyone else confirm?
Hunter67 is offline
post #700 of 703 Old 02-22-2015, 07:38 AM
Liked: 0
So far, my best guess is that the Teensy sends commands, like reboot recovery, and some exploit commands that need to be used to complete the process.
I'm wondering if now that I can use a USB Hub to use a USB flash drive and a USB Ethernet Adapter, is there any other method to send the commands other than owning a device that costs more than half what I paid for my Chromecast? Maybe a program on the computer(or even an android) to act as a console and a cable? And run a script or manually type commands over the USB?
xnamkcor is offline
post #701 of 703 Old 02-23-2015, 10:37 AM
Neil S. Bulk's Avatar
Yes indeed! Great find!
Neil
Neil S. Bulk is online now
post #702 of 703 Unread 02-24-2015, 09:04 PM
Liked: 0
Thanks I'll use it to stream GoT from now on.
Trey To is online now
post #703 of 703 Unread Today, 02:48 PM
the_abbot's Avatar
Quoted: 108 Post(s)
I guess this is a better place to post this question
Does anyone know if the roomie remote can be used with a chromebox?
Edit: Or maybe the better question is if Roomie is compatible with Kodi.
the_abbot is online now
Google Chromecast Hdmi Streaming Media Player , Logitech Harmony 650 Remote Silver
