Enjoy your music on a Dune with Dune Music Manager (DMM) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #181 of 309 Old 03-08-2014, 06:21 AM - Thread Starter
otreblaelasac's Avatar
Liked: 36
Hi there,
I uploaded the DMM2.0 beta on : https://www.dropbox.com/sh/r7g8evhq3cztd20/5gCluKlLGM
You'll find the installation zip and user manual.
WebApp is not yet available and the old one won't work
Keep your current DMM separate and work possibly on a smaller menu first.
If you test the CUE SHEETS you might notice that the when you play a song for the first time you'll get a "format not supported" msg. Just wait few secs and the song should play.
Be indulgent as for sure there are still many bugs.
I suggest you to report your feedbacks/issues/etc directly to me by email (albertocasale@yahoo.com)
Thanks for helping me with the tests
Alberto
tightrope likes this.
otreblaelasac is offline
post #182 of 309 Old 03-09-2014, 11:16 AM - Thread Starter
Liked: 36
1st Note for the beta testers
  • DMC won't work correctly with the same settings as before. You need to tell DMC to point to your_Menu_Folder/000_Home
  • I forgot to mention in the user manual how to add/edit playlists and collections. You need to show the library pane (button to the far right of the toolbar). Then you pick from the dropdown list Playlists or Collections and finally click on the button to the right showing a musical note or an album. You'll then see the tool to create playlists/collections. Click [+] to create a new item
post #183 of 309 Old 03-12-2014, 06:06 PM
mu7e's Avatar
otreblaelasac hi
I start using your new DMM 2.0!
I'm changing some fields in the template, it is possible to hide the blue line field boxes like in previous versions?
thanks for your exceptional work!
mu7e is offline
post #184 of 309 Old 03-12-2014, 11:14 PM - Thread Starter
Liked: 36
To hide the blue rectangles of the template you can simply hide the template controls by clicking again the corresponding botton on the toolbar on the top right.
If you'd prefer to have the template controls open and be able to hide the zones, I can add a button/checkbox in the Options tab.
cheers
post #185 of 309 Old 03-17-2014, 10:38 PM
mu7e's Avatar
No need to do that, tks.
mu7e is offline
post #186 of 309 Old 03-26-2014, 04:23 PM - Thread Starter
Liked: 36
Hi
after few iterations and great help from you, here is a new (hopefully) stable beta release, v2.0.9
This version is complete for a TV/remote or DMC usage. It DOES NOT work with the old DMM Web App and there is not yet the DMM Web App 2.0.
What's new since the initial 2.0.0 beta:
  • Updated user manual
  • Menu configuration: added the parameter "Dune Music Folder" (as in 1.2.8 ). This is useful (ONLY) when you have an exact copy of your library on your PC while the Dune access the content stored, e.G. on a NAS. To speed up the analysis you can tell DMM to analyse the files on your PC but you also need to tell it where the Dune will find the content.
  • Performance improvements: UI refresh, Startup, Export, ... are now much faster; is it noticeable in particular on big database
  • Added an option to "Export only for the DMM WebApp" (DMC still needs the standard export, full or incremental). This feature will make the export much much faster but you won't be able to have a usable TV menu
  • Browsing by Folders: now DMM uses any valid image it finds in a folder and it composites it with the folder icon
  • Valid image names: now customisable in the xml option menu
  • Templates: added the option on the album page to add below the song title, the artist and composer names
  • Support for png images for album and genre covers
  • Great new version of the DuneScope template from THXjay. A big thank !
Talking about templates, DMM has many options to choose from, each template it comes out of the box with its own selection of options. You can change them all
and adapt any template to your tastes
Hope you'll enjoy the new DMM
Alberto
post #187 of 309 Old 03-27-2014, 05:42 AM
maxout's Avatar
Hello,
when I try top open the exported library on my dune I get the error "empty". After removing the empty line at the beginning of the file
dune_folder.txt it works. However, all the created dune_folder.txt files have an empty line at the beginning....
Why is that?
maxout
maxout is offline
post #188 of 309 Old 03-27-2014, 06:11 AM - Thread Starter
Liked: 36
that's weird as it has always been like that since quite a while (the empty line).
If you exported your menu in a folder called, e.g; DMM, you'll have a dune_folder.txt there that is just a jump to the folder 000_Home the menu actually starts there.
when you remove the empty line in DMM/dune_folder.txt what does it happen ?
To follow up on this more effectively, could you send me an email (albertocasale@yahoo.com) ?
post #189 of 309 Old 03-27-2014, 07:03 AM
maxout's Avatar
I'm currently at work so I have to reply here...
I have tested version 1.2.8 which shows the same error.
Whenever there's an empty line in the root folder of the library in dune_folder.txt I'll get the error "empty" when I open that directory on my dune.
When I remove the empty line the library opens as expected.
I have also tested yadis with my dune and it works. Yadis always has the following first line in the dune_folders.txt files:
*** NE PAS SUPPRIMER OU MODIFIER CETTE LIGNE - DO NOT DELETE OR MODIFY THIS LINE ***
When I replace that line with a blank line I get the same error with the yadis library.
My player is a Dune HD Base 3D
maxout
maxout is offline
post #190 of 309 Old 03-27-2014, 04:52 PM - Thread Starter
Liked: 36
Ok, let see.
I uploaded at https://www.dropbox.com/sh/r7g8evhq3cztd20/5gCluKlLGM
a new version of the program DuneMusicManager 2.0.9a_beta.exe which puts the same line as Yadis at the beginning. Simply drop the file in your DMM folder and run it instead of the older one.
I'm not home, so I couldn't test it on TV. If some of you had this problem of empty screens let me know if this fixes the issues. Let me of course also know if by any chances this change creates an issue smile.gif
Alberto
post #191 of 309 Old 03-29-2014, 10:44 AM - Thread Starter
Liked: 36
Hi
I uploaded an updated version of DMM 2.0.x beta. It fixes few bugs (UI, export, rescan, etc.)
You can either install the full pack or, if you did already install 2.0.9, simply drop the new exe file in your existing DMM 2.0.9 installation folder (in this you might need to slightly adjust some template, if you don't want to do that install the full pack).
post #192 of 309 Old 03-31-2014, 02:09 AM
maxout's Avatar
Hello,
I just wanted to give you some feedback:
Thanx a lot for the fix and keep up the great work !
maxout
maxout is offline
post #193 of 309 Old 04-04-2014, 10:58 PM - Thread Starter
Liked: 36
Hi there
I uploaded a new beta that fixes few bugs.
Any remaining problem let me know.
If you already have installed the 2.0.9g you could download just the new exe
Alberto
post #194 of 309 Old 04-06-2014, 09:56 PM - Thread Starter
Liked: 36
My apologies for the (too) many versions I'm posting (a new one just now).
If you are trying a beta of DMM 2.0 and having errors/issues, please check first the dropbox location to see if there is a newer version
One comment. If your db is BIG then you might see that DMM is taking time at start up. I'm looking into making this step faster even for big databases.
post #195 of 309 Old 04-10-2014, 07:38 AM
maxout's Avatar
Hi,
after playing around a little, it seems in the album view the artist picture is always the picture of the artist of the first track.
This doesn't give the desired result with "Various Artists" albums. For those albums the picture of the artist "Various Artists"
should be shown and not the picture of the 1st track's artist.
Any way to fix this?
maxout
maxout is offline
post #196 of 309 Old 04-10-2014, 07:55 AM - Thread Starter
Liked: 36
Hi
if you just rely on what DMM does at scan then you'll have as an artist picture
- a local picture in the artist folder. That'll only work if your library is organised in Artist\Album\Songs and will only work for single artist for an album
- the cover of the first album belonging to that artist (what you experienced)
Of course you can change artist pictures. How ?
1) using "Scrape Images" action. This way DMM will go out on the internet and automatically search for various type of images
2) using "Change Images" action. This way you'll have an image search tool which you can use to search and set covers, pictures, backgrounds for albums, artists, genres
So to have a dedicated "Various Artists" picture you can use method 1) or 2)
Alberto
BTW, I should be able to post 2.0.11 beta tomorrow the latest. This iteration brings
- DuneScope templates French version
- Bug Fixes
- Add a small Remote Control window to manage navigation with the mouse (home, back, pg up/down)
- faster start up, significant in particular for big databases
post #197 of 309 Old 04-10-2014, 08:14 AM
maxout's Avatar
I'm sorry but I think you misunderstood.
I already have a dedicated "Various Artists" picture.
My problem is, that for compilations (Album Artist: Various Artists) this picture will not show in the album view.
Instead the picture of the first track artist will show, which is incorrect.
maxout
maxout is offline
post #198 of 309 Old 04-10-2014, 08:44 AM - Thread Starter
Liked: 36
Are talking about Album page in the "DJ_01" or "MusicScope (CD Cover and Artist)" templates ?
I checked and Indeed this is what happens and ... it is a bug. I've now corrected it and it will present in tomorrow 2.0.11 beta version
post #199 of 309 Old 04-10-2014, 10:55 AM
maxout's Avatar
Yes exactly. I'm using the Tribute2Music template though...
maxout
maxout is offline
post #200 of 309 Old 04-10-2014, 03:13 PM - Thread Starter
Liked: 36
As said previously a new beta (2.0.11) is available at https://www.dropbox.com/sh/r7g8evhq3cztd20/5gCluKlLGM
You can do a fresh install and recreate your menu or simply take the new exe and put it in your DMM folder
Changes
  • Bug Fixes
  • Revised User Manual
  • DuneScope templates French version. Under the Templates folder. Download the zip and unzip in your DMM MyMusic\Templates folder
  • Added a small Remote Control window to manage navigation with the mouse (home, back, pg up/down)
  • Faster start up, significant in particular for big databases
This version is certainly not bug-free but seems quite stable to me. For those who will try it, in case of errors proceed as follow
  • edit the file DuneMusicManager_Options.xml
  • put True
  • run again DMM
  • send me (albertocasale@yahoo.com) the file log.txt (DMM root folder)
Did anyone tested CUE-based albums ? I could do only limited tests on my side. Does it work as expected, any remark, suggestions ?
Alberto
post #201 of 309 Old 04-26-2014, 03:09 AM - Thread Starter
Liked: 36
Just wanted to check how it goes with the latest beta version, any problems, crashes ?
To be honest I don't have a clue about how many people around there are using DMM (1.2.8 or 2.0 beta).
If you haven't used DMM yet and want to give it a try, I'd suggest you to use the latest 2.0 beta from Dropbox and start with a small database of few albums only.
BTW, stay tuned as the DMM 2.0 webapp will arrive in May bringing playlist management on the fly and more ...
Alberto
post #202 of 309 Old 04-26-2014, 04:33 AM
Calahan's Avatar
Hi,i not use DMM,but maybe you can help me with a dune folder structure.
I have a folder for each Album,in this folder i create a dune folder.txt and a icon.aai( the album cover)
the dune folder txt.looks like this
icon_path=ABBA.aai
icon_sel_path =ABBA.aai
So,it works,but how can i manage,when i open the folder,all files have the cover icon to instead that marked icon in the picture?
Many thanks for Advices
greets Calahan
Calahan is offline
post #203 of 309 Old 04-26-2014, 08:25 AM - Thread Starter
Liked: 36
Not sure exactly to understand what you want to accomplish.
You can try adding
direct_children.icon_path=ABBA.aai
direct_children.icon_sel_path=ABBA.aai
post #204 of 309 Old 04-26-2014, 09:15 AM
Calahan's Avatar
thanks for reply,i try it,but dont work.
I want all titles in the Folder have the same icon like the Folder himself.Is that possible?
Calahan is offline
post #205 of 309 Old 04-27-2014, 02:05 AM - Thread Starter
Liked: 36
Sorry, never did that. You might want to check
http://dune-hd.com/support/misc/dune_folder_howto.txt
post #206 of 309 Old 04-27-2014, 02:50 AM
Calahan's Avatar
how to dune_folder.txt (Click to show)
2) The look/behavior of "SomeFolder" itself and all items inside this
      folder.
Thats a part of description from your link,but i cant found the right command line specially for  "and all items inside this folder"
Calahan is offline
post #207 of 309 Old 04-29-2014, 05:41 AM
Calahan's Avatar
Can you help me to fit my cover images in to the icons,see below funny screen
I create a dune_folder.txt and a cover.aai (size=600x600 pixel) for each album folder and it works well in list view mode with right panel.( see second image),but not in icon view mode (see first image).
dune_folder.txt ( icon_path=cover.aai)
I think i need a dune_folder.txt for the parent folder ( in my way its called "CD")
maybe you have a sample dune_folder.txt for me
many thanks fo help
greets Calahan
Calahan is offline
post #208 of 309 Old 04-29-2014, 05:53 AM - Thread Starter
Liked: 36
Hi
you would need to either resize your images or add a scale factor (check dune_folder link I've sent).
May I kindly ask you to open a dedicated thread for your problem as this is not related to my DMM program which is the objective of this thread smile.gif
Thx in advance,
Alberto
post #209 of 309 Old 04-29-2014, 11:51 AM
Calahan's Avatar
Ok,forgot it:rolleyes:.
To find the "dune_folder_howto.txt" site i don't need a Forum.
BTW: Scale factor influence only the size of the selected icon and not the image inside the folder with the dune_folder.txt
Anyway,thanks for trying to help.
Calahan is offline
post #210 of 309 Old 04-29-2014, 05:24 PM - Thread Starter
Liked: 36
You might want to check this (http://www.mpcclub.com/forum/showthread.php?t=27700). I think it could be of help
Alberto
Netgear Ntv550
