Dune - Blu-Ray - HDMI - TV Sound Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-12-2013, 12:18 PM - Thread Starter
wcndave's Avatar
When playing a blu-ray rip with DTS sound straight to TV with HDMI, the speech element is silent. I get music and sound effects, however no speech.
I have tried setting the Dune to both PCM downmix and original bitstream output, no joy.
It's odd because other media that is in 5.1 surround is fine.
If I turn on the AV receiver which is connected with digital coax, then it plays fine whether the AVR is set to dolby pro-logic or dts input.
However I don't always want to turn on the Stereo to watch TV...
I am also not sure if it's a problem with the Dune (given it works to stero, seems unlikely), the TV (Brand new samsung 6500 so should manage anything), or the cable...
Any ideas would be very helpful!
wcndave is offline
post #2 of 10 Old 09-15-2013, 08:03 AM - Thread Starter
wcndave's Avatar
Any ideas, it's really annoying the wife that she can't watch any movies that have DTS only, and can't watch any that have DTS + other audio tracks without calling me up so I can explain how to select audio track that will work...
wcndave is offline
post #3 of 10 Old 09-15-2013, 09:24 AM - Thread Starter
wcndave's Avatar
Actually not only DTS, it's also on "Dolby EN Multichannel" on a number of discs... basically the choices seem to be:
1. always use amp and surround sound for films
2. go into the dune settings and change between PCM downmix and original bitstream as I need.
Neither are really acceptable - I would have thought a modern "smart TV" would downmix multi-channel sound?
wcndave is offline
post #4 of 10 Old 09-15-2013, 09:30 AM
L33TX43RT's Avatar
A modern Smart TV will decode Dolby Surround SRS at best, not 5.1 or DTS. You will need the AVR to decode multi-channel / HD sound.
L33TX43RT is offline
post #5 of 10 Old 09-15-2013, 09:49 AM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1330
Does the Dune have a setting to make it send audio based on handshake? It should, I know they do for video output.
rdgrimes is offline
post #6 of 10 Old 09-15-2013, 10:15 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
What Model Dune do you have? The Dune Smart Series will downmix HD sound tracks so the TV can play them correctly. The new 3D capable media player will not do that.
GusGus748s is offline
post #7 of 10 Old 09-15-2013, 10:32 AM - Thread Starter
wcndave's Avatar
I have the Dune Max.
In Audio, you can select PCM downmix, or original bitstream.
My Digital Coax out is going to my AVR, which is fine when I am in "cinema" feeling.
However for just switching on and watching something, it's the HDMI to the TV that is carrying the signal direct.
I really don't want to swtich on the amp to watch TV... It would be better if the Dune downmixed the HDMI output and left the coax in original bitstream...
I am not sure where I would find a handshake type setting.
wcndave is offline
post #8 of 10 Old 09-15-2013, 01:30 PM - Thread Starter
wcndave's Avatar
I tried setting the output back to PCM to check, and I see that on my AVR the digital now comes through as stereo only.
There is one setting for audio over HDMI which is set to "on"
one setting for digital out, which is "on"
I don't see anyway to set hdmi to downmix and digital coax to original bitstream.
wcndave is offline
post #9 of 10 Old 09-15-2013, 02:31 PM
rdgrimes's Avatar
Liked: 1330
Any time you're mixing outputs, there's bound to be issues. There's certainly no way to have one digital output doing one thing and another digital output something else.
Best advice is to update to an HDMI processor with pass-through options, so when you shut it off the TV takes over and handshakes for stereo PCM. That's by far the most common approach these days.
Some TVs offer the option of combining one HDMI input for video and a different analog or digital input for audio. If the player outputs stereo analog, that would be a possible option.
rdgrimes is offline
post #10 of 10 Old 09-17-2013, 05:34 AM - Thread Starter
wcndave's Avatar
Thanks for your response. Few questions.
Update what to an HDMI processor? Do you mean the AVR?
The TV would handshake with the Media player? As far as I know the Dune has no handshaking ability, you have to select one thing or another. Maybe that is the crux, that you have to select what you want when you want it, in which case perhaps a shortcut is in order...
Also the TV is advertised thusly, so not sure how it can do 5.1 anyway... but it is certainly confusing...
wcndave is offline
