Building first media server - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2013, 08:47 PM - Thread Starter
02saleen346's Avatar
Starting my research of a couple of projects and need some help. I want to store movies, pictures, music and be albe to stream audio/video to 4 rooms. Would i be able to upload pictures from phone or tablet to server? By budget for starting out is $500. I will also be building a mini htpc for the main living room or maybe all 4 rooms if its best. Can some one share there build list and what I would need to get started? I will be running cable from each location to my master closet, what kind of switches or other products would I need to connect to server? My router is in the living room if that makes a difference. I have a 7 year old single story house and Im a big fan of XBMC. My project after this will be a whole home audio system in 8 zones (living room, garage, patio, 3 bedrooms and 2 bathrooms. Looking at sonos amps.
02saleen346 is offline
Old 09-29-2013, 08:53 PM
bluechunks's Avatar
Quoted: 78 Post(s)
Liked: 115
You have lots of options for a NAS (server) but if you are going to build a mini-PC for each room and want XBMC take a very serious look at OpenELEC and select your components from there.
__________
4K madness: Visio P65-C1 (4K HDR10 & DV) / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ & Speakercraft (Ceiling) - Celerity 50' Fiber Optic HDMI between AVR and TV
bluechunks is offline
Old 09-30-2013, 12:46 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Intel NUCs are a pretty good option. I am actually thinking about buying one...I'm not sure if the wife will be too happy about it though.
GusGus748s is online now
Old 09-30-2013, 07:19 AM
bluechunks's Avatar
Quoted: 78 Post(s)
Liked: 115
She will, I suspect---mine is thrilled with our NUC with OpenELEC.
Since it uses XBMC and is controlled by our Harmony remote it simply acts as another device in the rack....except is has fast great looking menus (Aeon Nux skin add-on) so it actually behaves better, and is more user friendly, than any of our other devices.
A couple hints:
1) The new "Haswel" 5th generation CPU NUCs arriving soon have an IR sensor built-in so no need for an external one like the current NUCs. They also have revised GPUs with improved 1080i de-interlacing if that is a factor.
2) Set the Shutdown option within XBMC to "sleep" so the remote simply wakes the NUC from sleep. The NUC draws 1W in standby and wakes virtually instantaneously since OpenELEC runs from RAM once booted.
__________
Old 09-30-2013, 08:42 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
A couple hints:
Good to know. I might wait.
Old 10-01-2013, 08:15 AM
ZzBloopzZ's Avatar
Quoted: 79 Post(s)
Liked: 103
Thanks for the info bluechunks! Do you have a link to the NUC that you own?
I wish XBMC supported 3D ISO's, then I would purchase the NUC in a heart beat! I love XBMC, I used to use it back in the day with a modified Xbox 1. But then went to a WDTV. Time to get something better than the WDTV.
Debating between building my own HTPC or just purchasing a Mede8er 600X3D.
Basement | Horrorfest 2015
Samsung 51" PN51D7000 | Mede8er 600X3D | Roku 3 | Pana. BDT110 | 30TB+ ZFS
Denon AVR-2113CI | Ascend Sierra-1 LCR | Ascend CBM-170 SE | PSA XV15
Living Room
Sony 65" KDL65W850A | Mede8er 600X3D | Wii
Denon AVR-X1000 | JBL Studio 530 | JBL Studio 520C | Outlaw LFM-1 EX
ZzBloopzZ is offline
Old 10-01-2013, 09:24 AM
bluechunks's Avatar
Quoted: 78 Post(s)
Liked: 115
I have the Celeron 847 NUC with 2x2GB RAM and a micro Sandisk Cruizer USB drive with OpenELEC installed. The NUCs also come in i3 and i5 versions and the new (Hawsell) units should be out soon. This spring could also herald a very low cost unit that could be a perfect low-cost XBMC machine if Intel uses a current GPU. Alternatively, there are lots of folks using ION based units (example) with OpenELEC for XBMC.
FWIW, the NUC does almost everything---1080p in all the common codecs, HD audio bit streaming, cool Aeon Nux skin, but it does not do 3D. It is also weak, IMHO, with 1080i de-interlacing but since all my media is film based it doesn't matter to me. There is also a reported 24p "problem" that the new Haswell units are reported to solve but I also have to admit than in real world viewing I have yet to notice the problem.
__________
Old 10-09-2013, 08:05 AM
kyle76092's Avatar
Is this the Broadwell chip?
kyle76092 is offline
