Media Player (Netflix & DTS-HD MA) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 10-01-2013, 09:17 AM - Thread Starter
donaldsonjune's Avatar
Quoted: 41 Post(s)
hello all,
i'm looking for a media player that has nexflix & HD audio (dolby true hd & dts-ha ma).
June
"IF YOU FAIL TO PLAN, YOU PLAN TO FAIL"
donaldsonjune is offline
post #2 of 23 Old 10-01-2013, 01:11 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Originally Posted by donaldsonjune View Post
hello all,
Doesn't exist. You can build a mini HTPC with Intel NUC and possibly be able to do that.
GusGus748s is offline
post #3 of 23 Old 10-01-2013, 11:22 PM
techflaws's Avatar
Quoted: 147 Post(s)
Liked: 79
The WDTV Play has Netflix, supports DolbyTrueHD and bitstreams DTS-MA to your AVR. So if you don't need MPEG2 playback and network shares (it's DLNA only), this might be the player for you.
Tech Flaws
Things can only get better
techflaws is offline
post #4 of 23 Old 10-02-2013, 12:59 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
WDTV Play supports the following:
MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, AIF/AIFF, OGG, Dolby TrueHD
There is no support for bitstreaming DTS-MA.
WDTV Live and WDTV Live Hub supports the following:
Audio - MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, AIF/AIFF, OGG, Dolby Digital, DTS
No mention of supporting True HD nor DTS-MA.
So, I am not sure where techflaws gets his information about WDTV supporting both True HD and DTS-MA.
post #5 of 23 Old 10-02-2013, 01:08 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Also DLNA does not support and HD audio formats. DLNA supports the following LPCM 2 channel, MP3, WMA9, AC-3, AAC, ATRAC3Plus.
The WDTV media player do have Netflix, Hulu, Vudu, Pandora and other apps. If HD audio is a must for you, the WDTV isn't the choice.
post #6 of 23 Old 10-02-2013, 04:53 AM
Alx330's Avatar
Quoted: 17 Post(s)
Liked: 47
Well DTS-MA can work over DLNA as it's pretty flexible/loose on codecs but as you say the WDTV Play supporting DTS-MA in the first place is news to me also but apparently it does indeed support DTS-MA bit-streaming. Turns out not having a DTS license works in it's favour so it can bit-stream away.
Alx330 is offline
post #7 of 23 Old 10-02-2013, 05:53 AM
bluechunks's Avatar
Quoted: 161 Post(s)
Liked: 206
Not totally correct. HD Audio might not have been part of the original DLNA spec but its been working for several years as long as both the server and player support it.
As an example, prior to using XBMC (OpenELEC on an Intel NUC) I used a Synology DS212j (Synology Media Server) to stream MKVs (with DTS-MA and TrueHD) to an Oppo BDP-103 via DLNA and prior to that setup I used a Netgear ReadyNAS Duo (Twonky Media Server) and an Oppo BDP-93 with success.
__________
Visio P65-C1 / Oppo UDP-203 / Apple TV 4K / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ / Speakercraft (Ceiling) / Hsu sub / Celerity 50' Fiber HDMI
bluechunks is offline
post #8 of 23 Old 10-02-2013, 08:27 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
So then that would mean that the WDTV Play won't be able to downmix if need be.
post #9 of 23 Old 10-02-2013, 09:48 AM
mrfattbill's Avatar
Quoted: 109 Post(s)
Liked: 94
Techflaws is correct with his statement as it's written but it is a little misleading for the uninitiated.
The "Play" will bitstream DTS-MA but not TrueHD
The "Live" will bitstream TrueHD but not DTS-MA
Both units will use the lossy core of the non bitsreamed HD audio which is what make his statement correct. Technically they do SUPPORT both audio formats but I doubt it's the support (bitstream) the OP is looking for.
Gus is right, if you aren't going through a AVR you will lose the audio from one of the formats...I have this issue in my bedroom with a Live Plus and TrueHD mad.gif If you aren't going into an AVR I would go with the Live, the lesser of two evils, a lot less movies with TrueHD than DTS-MA.
Bill
mrfattbill is offline
post #10 of 23 Old 10-02-2013, 10:36 AM
Otter0911's Avatar
Quoted: 72 Post(s)
Bill
Not with the SMP Live I have it in my bedroom and it will play TrueHD without a AVR with no probs.
Otter0911 is offline
post #11 of 23 Old 10-02-2013, 10:46 AM
mrfattbill's Avatar
Quoted: 109 Post(s)
Liked: 94
Seriously? I will have to try it out, I have an older Live Plus hooked to a Panasonic plasma and I get no audio from my TrueHD movies. I will test it with the SMP I have in my living room.
Edit: Well I'll be....both my SMP Live AND my Live Plus running newer firmware downmix TrueHD to 2 channel now. You learn something new everyday smile.gif
Bill
post #12 of 23 Old 10-02-2013, 10:49 PM
techflaws's Avatar
Quoted: 147 Post(s)
Liked: 79
Unlike the WDTV Live, the Play DOES bitstream DTS. Can't find the official statement ATM but here's an explanation.
Tech Flaws
post #13 of 23 Old 10-04-2013, 07:19 PM
crbaldwin's Avatar
Quoted: 80 Post(s)
Liked: 25
The Sony BDP-S590 (and probably newer Sony players) supports all HD Audio via DLNA in an M2TS container.
crbaldwin is offline
post #14 of 23 Old 10-06-2013, 03:56 PM
candyman85's Avatar
I own the Xtreamer Prodigy http://www.xtreamer.net/xtreamer-prodigy-upgraded/
It successfully bitstreams both Dolby TrueHD and DTS-HD-MA 5.1/7.1 to my AVR. I have Blu-ray movie files on an external HDD, and it plays them perfectly with the corresponding audio signal.
candyman85 is offline
post #15 of 23 Old 10-09-2013, 11:46 AM - Thread Starter
Quoted: 41 Post(s)
thanks all,
I guess I need to choose my pain. my WD Live does everything except dts-hd ma.
June
post #16 of 23 Old 10-12-2013, 07:18 PM
WynsWrld98's Avatar
Quoted: 353 Post(s)
Liked: 122
I have my eye on the KDLINKS HD720 tons of very positive reviews on Amazon and does DTS-HD MA and Dolby TrueHD
WynsWrld98 is online now
post #17 of 23 Old 10-12-2013, 07:35 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
post #18 of 23 Old 10-13-2013, 01:19 PM
Kelson's Avatar
Quoted: 2030 Post(s)
Liked: 1209
thanks all,
And you need to be honest with yourself. Do you really have the audio setup and acoustics to hear the difference between DTS and DTS-HD. I know I don't. I have a pretty nice 5.1 audio setup with Polk speakers but when I compared the DTS sound from the Live-SMP to the DTS-HD sound from a Panasonic BD player for Avatar and a few others, I couldn't tell the difference.
DTS is already high quality at 1.5 Mbps. I think it's more important that the Live-SMP supports True-HD bitstreaming vs AC3 which is 640Kbps max.
Don't get me wrong. I would love to have DTS-HD support -- just because. But I'm not willing to move away from the Live-SMP and spend a lot more just because it doesn't do it. The firmware support for the WD Live players has been exemplary.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #19 of 23 Old 10-14-2013, 10:11 AM - Thread Starter
Quoted: 41 Post(s)
thanks keelson,
I really needed to hear what you just said. I was looking at an oppo bdp-103 blue ray player. it does all my needs but no dolby true hd. there are more dts-hd ma titles out.
after hearing star trek into darkness, the dolby true hd blew me away. dts hs ma sounds much better than dts. i'm kinda anal about my sound. the Netflix super hd 5.1 dolbly digital + even sounds awesome. I just want what I want. but thanks for your comments!!
June
post #20 of 23 Old 10-14-2013, 10:47 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
I don't know about you, but I can. Even when I had only a 5.1 set up I was able to hear a difference. However, I know of many people who do not hear any difference as well since they are more in tune with watching the movie rather than hearing whats going on around it biggrin.gif
post #21 of 23 Old 10-14-2013, 11:51 AM - Thread Starter
Quoted: 41 Post(s)
it's a big difference to me!!!
dts-hd ma rocks!!!
June
post #22 of 23 Old 10-15-2013, 01:58 PM
ezrangel's Avatar
Quoted: 25 Post(s)
Is there any player that downmixes HDaudio to stereo when connected to a TV?
Sorry for bad english...
ezrangel is online now
post #23 of 23 Old 10-15-2013, 10:09 PM
techflaws's Avatar
Quoted: 147 Post(s)
Liked: 79
WDTV Live Streaming.
Tech Flaws
