Tv Signage - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-03-2013, 07:40 AM - Thread Starter
Jasharp's Avatar
I'm hoping you guys can help me out with a project. I need to setup a tv as a digital sign that gets updated on a regular basis. The people updating this are not the most techie so it needs to be simple. My fist thought was just to hook it up to a computer and run power point on it but I'm not thrilled about adding the cost of a computer to this setup plus having it run 24/7. My second idea was to get a smart tv and convert the power point to a video file. Then send it to the tv via DLNA but this is an involved process that takes time whenever the information needs updating.
Do you guys know of a better solution?
Thanks for you time in advance.
Jason
Jasharp is offline
post #2 of 10 Old 10-03-2013, 12:41 PM
BlacMagik's Avatar
Look into MediaSignage.com. They have some free options. Although there is a learning curve to their software, it's pretty easy.
A SmartTV + DLNA isn't the best solution.
BlacMagik is offline
post #3 of 10 Old 10-04-2013, 06:09 AM - Thread Starter
Jasharp's Avatar
Thanks for the tips. That software is really awesome but it would still require me to have a computer hooked up to the tv.
Unless someone else has another solution i will probably end up giving this a shot. thanks again.
Jasharp is offline
post #4 of 10 Old 10-04-2013, 06:22 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
Many smart TV's play media off a usb flash drive. You can do a slideshow or loop a video file. Most have repeat settings to keep it going. My office complex has one set up just that way (I think its an LG) with a looping video. Just swap out the USB drive when you want to update. Sometimes simplest is smartest.
DanPackMan is offline
post #5 of 10 Old 10-04-2013, 06:31 AM - Thread Starter
Jasharp's Avatar
that's a very good idea but unfortunately the tv is about 8ft high on a wall.
Jasharp is offline
post #6 of 10 Old 10-04-2013, 06:45 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
You could consider getting a usb extension if there is a sufficient place to hide it.
BTW, I checked and it was a Samsung TV
post #7 of 10 Old 10-04-2013, 06:50 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
Another option is a raspberry pi mounted on the back of the TV. Can run 24/7 with little power draw and lots of software options, linux and/or XBMC. Hardwired ethernet would be best but wireless would work as well if you add an adapter.
OR one of the many HDMI Sticks that are now on the market.
post #8 of 10 Old 10-04-2013, 08:51 AM
BlacMagik's Avatar
If you're gonna do Digital Signage, might as well do it right!
post #9 of 10 Old 10-04-2013, 03:02 PM
eq_shadimar's Avatar
Quoted: 26 Post(s)
Liked: 49
Popcorn Hour/Cloud Media makes a streamer just for this purpose:
http://www.cloudmedia.com/products/digital-signage
LG also has a line of TV's that you create the message etc using their software, store on a USB stick, plug that into the TV and it runs:
http://www.lg.com/us/commercial/lg-ezsign-tv
Laters,
Jeff
...wake up to find out that you are the eyes of the world...
My HT Construction Thread - Updated Pictures 3/15/07
My 2.35:1 Discussion Thread - Updated Pictures 3/15/07
XBL = eqshadimar
eq_shadimar is offline
post #10 of 10 Old 10-04-2013, 11:16 PM
techflaws's Avatar
Quoted: 144 Post(s)
Liked: 77
The WDTV Live (Streaming) has an option for this, never tried it myself though.
Tech Flaws
Things can only get better
techflaws is online now
