Dune Player Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-06-2013, 04:38 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
My Dune player feels the need to disconnect video after every single movie trailer and prior to putting on the main menu. Also prior to playing the main move. It slows things down considerably as my AVR/Projector are always searching for a source, then detecting the source.
My video settings are 1080p60 with auto frame rate 24/50/60 selected.
Is there any setting that will stop the box from doing this?
pdxrealtor is offline
post #2 of 4 Old 10-08-2013, 12:42 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
post #3 of 4 Old 10-10-2013, 04:23 AM
bluewhale1's Avatar
Quoted: 401 Post(s)
Liked: 146
Are you trying to stream wired/wireless(can you do a read speed test to see what your read speeds are)? Have you tried to hook it up to another tv to see if it is some strange compatibility issue with the projector? Which movies, what format, is the firmware updated? (All i can think of off the top of my head)
bluewhale1 is online now
post #4 of 4 Old 10-10-2013, 11:31 AM
sensui's Avatar
I have the same issue with one of my setups. This behavior happens on my Marantz 8801 + Panasonic ZT60 setup.....I am guessing it's the processor/pre-pro as I don't have an issue with another Dune unit with a NAD T785 receiver + Pioneer 151FD. It just seems to do an extra handshake when it flips resolutions. Same settings on both of my Dunes (locked to 1080p 24hz)
sensui is offline
