TMT 6 Help - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2013, 10:26 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
TMT 6 will not, no matter what setting I change, quit starting every time I insert a disc into my bluray drive. I'm sure I'm missing something simple, but for the life of me can't figure it out.
I would prefer to not have the program start automatically. Add to that it starts in full screen mode which just adds to the annoyance.
pdxrealtor is offline
Old 10-08-2013, 12:42 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Old 10-08-2013, 04:00 PM
bluewhale1's Avatar
Quoted: 406 Post(s)
Liked: 148
What Os are you using? So if you go to the auto play options and change the settings it reverts back?
bluewhale1 is offline
Old 10-08-2013, 04:15 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Windows 8, 64 bit. The setting doesnt revert back. It stays unchecked. Thats the odd thing.
However every time I enter a disc it opens in full screen and has to load the disc before I can close it. Very annoying. Id like to not have to buy another program if at all possible.
Old 10-08-2013, 05:01 PM
bluewhale1's Avatar
Quoted: 406 Post(s)
Liked: 148
There should be a drop down tab which you should be able to pick ask me everytime.
Old 10-08-2013, 07:08 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Is this the drop down you're talking about? I tried this configuration and the program still opens up when I insert a disc.
Old 10-09-2013, 01:31 AM
bluewhale1's Avatar
Quoted: 406 Post(s)
Liked: 148
Old 10-09-2013, 08:12 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
In older versions of Windows, if you held the shift key down while the disk is inserted it would disable any auto play functions and simply load the disk. Give that a try.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Old 10-09-2013, 05:53 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Gosh the little things... thank you. Problem solved.
