WIFI Camcorder streaming IP address - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2013, 12:20 PM - Thread Starter
Sakara's Avatar
HI I have a JVC GZ-VX700 HD Everio camcorder and I need the streaming Ip address. I need to use the feed using  VLC. The soft that comes with the camcorder doesn't give me the IP address. I also have a GoPro camera that lets me stream to VLC but the lens on the GoPro doesn't lets me zoom and would work for my application. Does any one know how to find the IP adress I tried looking in the ipconfig but that didn't work.
Or does any one know of a HD camcorder that can stream into VLC using WIFI.
Sakara is offline
post #2 of 3 Old 10-12-2013, 10:06 PM
Avengerki's Avatar
Have you looked in your router's software. While most but not all show all devices connected it is a good place to start for finding the IP address. It may take pulling the MAC address it gives you and doing a web search to figure out if you have multiple wireless devices and can't readily identify it.
Avengerki is offline
post #3 of 3 Old 10-14-2013, 06:05 AM
DanPackMan's Avatar
Quoted: 230 Post(s)
Liked: 380
Also, since you didn't assign it an IP address yet, the router will via DCHP. You will want to assign a static address to the camera via the router or via the device itself if you intend to use it a lot, as the IP address may change from time to time otherwise.
DanPackMan is offline
