Question on "Downstream Bonded Channels" - AVS Forum | Home Theater Discussions And Reviews
Old 10-18-2013, 11:10 AM - Thread Starter
jeep05's Avatar
Quoted: 98 Post(s)
Liked: 147
I have a Motorola SBG6580 through TWC and it has the capability to utilize 8 bonded downstream channels. Only 4 are showing as being "Locked" and in use, so i call TWC to inquire about this and was told by rep. that they used the default, which he said was 4. Does this sound right?
If i decide to purchase my own modem to save the "lease fee" and it will also handle 8 channels, is TWC gonna set it to only 4 instead of 8? If in fact they only utilize 4 then purchasing a modem with an 8 channel capability is presently worthless other than looking at future expansion?
jeep05 is offline
Old 10-21-2013, 11:05 AM - Thread Starter
jeep05's Avatar
Quoted: 98 Post(s)
Liked: 147
Nevermind. Found out the answer when i activated the new modem with TWC. Only 4 downstream channels are being used. rolleyes.gif
jeep05 is offline
Old 10-21-2013, 11:13 AM
rdgrimes's Avatar
Quoted: 1995 Post(s)
Liked: 1326
They need to update their local hardware to support the newer 8 channel bonding scheme. FWIW, it won't make any difference in your download speeds unless you are at the top speed level. I get the same speeds on 8 ch that I used to get on 4, I'm on a 20/5 plan.
rdgrimes is online now
