Intel Nuc DCP847SKE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-31-2013, 08:02 PM - Thread Starter
beaujewel's Avatar
Hi Folks,
Bit of a noob with regards to HTPC's so bare with me.
Looking at doing a wife/child friendly htpc based on the Intel Nuc DCP847SKE running something like XBMC.
Main questions being is it capable of ripping Bluray/ and second is there an easier to use interface than XBMC?
Thanks All.
beaujewel is offline
post #2 of 8 Old 11-01-2013, 01:48 PM
MagicMan3's Avatar
The NUC is a full pc, just in a smaller case. If you have a USB drive it would be capable of ripping.
As far as interfaces go, you really can't get much simpler than XBMC.
MagicMan3 is offline
post #3 of 8 Old 11-01-2013, 02:16 PM
Charles R's Avatar
Liked: 536
If you wish to use only XBMC I'd take a look at OpenELEC. I run it via a flash drive (no hard drive) with the above NUC. It runs great and accesses movies stored on my NAS. I also use WMC as a backend for live and recorded TV. Powerful enough for HD audio and video and with a Harmony remote a pretty good interface.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #4 of 8 Old 11-01-2013, 02:26 PM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Didn't know you could use WMC for PVR in XBMC w/o Windows installed... or do you run OpenELEC and Windows on your NUC? I have an i3 NUC w/Windows 7, but thinking about getting a Celeron NUC and using OpenELEC. The PVR issue is what was giving me second thoughts as I could never get NextPVR and other solutions besides WMC to work via XBMC. Thanks.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #5 of 8 Old 11-01-2013, 03:00 PM
Charles R's Avatar
Liked: 536
I use following...
  • Windows Pro 8.1 with Media Center (PC) - recordings are stored directly to the NAS via iSCSI
  • NAS (recordings and movies)
  • OpenELEC (pretty much a PC :))
The WMC PC acts as a backend server for XBMC using the following...
https://googledrive.com/host/0ByNnAMYBoWvfTk8tRWJXYko1T2c/index.html
The XBMC WMC Add-on works very well and takes only a few minutes to setup. The interface isn't quite as nice as WMC such as not having folders for TV series and the remote behaving differently for live and recorded shows. Overall it's a solid solution if you don't want Windows running on the client and not that much more than a native WMC extender.
post #6 of 8 Old 11-01-2013, 03:00 PM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
Sorry to hijack
Charles Can you play WMC recordings (without trancoding) in Open ELEC. I'm looking to put inexpensive player in master bed so wife can watch stuff recorded on main WMC in family room.
mark_anderson_u is offline
post #7 of 8 Old 11-01-2013, 03:10 PM
Charles R's Avatar
Liked: 536
I believe the answer is Yes and Sort of. :) Recorded files are played back natively and you don't need the WMC Add-on to view those. When viewing live and or currently being recorded shows the server creates its own copy (on the server) it can properly stream (WMC active recording files are rather difficult to handle). With four recordings and various playbacks going on my i3 has never broken a sweat.
Endless details are located here... the client/server software is very impressive...
http://forum.xbmc.org/showthread.php?tid=171216
mark_anderson_u likes this.
post #8 of 8 Old 11-01-2013, 06:25 PM - Thread Starter
beaujewel's Avatar
Ok, thanks for those thoughts.
I was thinking of the following setup
PCI e 32gb SSD Hard drive
Pcie wireless
usb 1 tb Storage
If I do go with linux is there any advantage in using the ssd to run off? Would I be better going to a tiny (4GB) SSD or will it run just as fast on a usb stick?
Thanks again.
