Asking for help in how to setup local movie rips accessed from a Media Management Device - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 11-13-2013, 12:55 PM
bluechunks's Avatar
Quoted: 159 Post(s)
Liked: 206
Originally Posted by xb1032 View Post
A NUC running XBMC seems like the most flexible option.
Having said that I have a couple questions:
1. My HTPC seems as if it's not powerful enough to run XBMC smoothly because it locks up fairly easily I can't play an Blu-Ray MKV at all but the same movie can be played using the VLC player. Is this simply because of the overhead it takes to run Windows 7? For the record I have an Intel I3 with 16GB of RAM.
2. What should I specifically be looking for when it comes to audio on the NUC? In my HPTV my video card supports both A/V out over HDMI which I assume I'll have to look for the same in the NUC. It will have to support the latest HD audio formats.
3. In installed OpenElec on a flash drive but when I boot from it I have the option to install (which I can't test this since I presently don't have a spare HD) or boot to test but when I choose this option it appears it either locks or is booting very slow (waited 10 minutes). Not sure if a file needs edited on the flash drive or not when booting directly from the flash drive.
Any ideas is appreciated. Making this change is definitely something that takes a bit of research!
1) The CPU is only a very small part of the equation. More important perhaps is the GPU (i.e. the "graphics card") that can off load the hardware decoding of the video. All the NUCs have this "hardware acceleration" built into the system. Even my low-end NUC with a Celeron sits around 15% CPU utilization while playing 1080p video...and it only has 4GB of ram with 2.5GB unused while running OpenELEC.
Also, in XBMC you may have to specifically adjust the method used for video decoding for optimum performance on your specific HTPC.
2) No need to look---bit streaming of all HD audio formats is standard via HDMI with current Intel graphics, and thus all NUCs. Or you can let the NUC do the unpacking to LPCM.
3) It should boot within 30 seconds. Try a faster USB flash drive and/or a different version of OpenELEC that is better suited for your hardware.
__________
Visio P65-C1 / Oppo UDP-203 / Apple TV 4K / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ / Speakercraft (Ceiling) / Hsu sub / Celerity 50' Fiber HDMI
bluechunks is offline
post #32 of 34 Old 11-27-2013, 08:41 PM - Thread Starter
xb1032's Avatar
Liked: 26
Looking at a NUC now. Not sure if there will be any BF deals but is there any issues with this NUC?
http://www.amazon.com/Intel-Next-Computing-Thunderbolt-i3-3217UDC3217BY/dp/B0093LINT2/ref=sr_1_2?ie=UTF8&qid=1385609226&sr=8-2&keywords=intel+3217
I also may look at a NAS now since I'd probably want about 16TB of storage. Was thinking about a WD 4bay:
http://www.amazon.com/Cloud-EX4-Diskless-High-Performance-WDBWWD0000NBK-NESN/dp/B00G4JZ2T0/ref=sr_1_10?ie=UTF8&qid=1385613622&sr=8-10&keywords=wd+nas
Haven't looked on the supported drives yet but Seagate HDs are cheaper than the WD drives. Hope those work.
xb1032 is offline
post #33 of 34 Old 11-27-2013, 09:33 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
The red NUCs do not have Ethernet ports only wireless.
GusGus748s is offline
post #34 of 34 Old 11-28-2013, 02:07 PM - Thread Starter
xb1032's Avatar
Liked: 26
Good catch and thanks for pointing that out. I missed that one!
xb1032 is offline
