Powerline Ethernet Streaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-03-2013, 06:40 PM - Thread Starter
Sittler27's Avatar
Quoted: 693 Post(s)
Liked: 62
I have powerline Ethernet setup to two TVs in my house (basement and man floor)
In the basement I have a Popcorn Hour A-200, and 1080p streaming from my NAS works very well, with minimal stuttering on badly encoded mkv files.
On the main floor I have a Popcorn Hour A-110, and it can hardly play anything without stuttering, losing audio sync, or just freezing up.
I had also tried reversing the two boxes' locations, and I get the same results in their new locations leading me to believe its a problem with the A-110's processing power and not the powerline.
However, when I try the a-110 over regular Ethernet it plays those same files without a problem.
Is the a-110 that lacking in processing power, and also what should I replace it with?
Sittler27 is offline
post #2 of 11 Old 11-03-2013, 09:05 PM
BlacMagik's Avatar
Your issue is more related to the bitrate of your movies and the available bandwidth your power lines give you. Don't use the power line utility to determine throughput on the network as this will not give you the correct/accurate results; if possible connect a computer at the unit your experiencing an issue with and another computer at your router or switch that the other power line adapter is connected to....run either iperf/jperf to get an accurate representation of actual throughput/bandwidth between your adapters.
StratmanX likes this.
BlacMagik is offline
post #3 of 11 Old 11-03-2013, 09:32 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Agreed, it is the powerline adapters bandwidth that is at issue. I have 4 PLA's around my house. The biggest impact on throughput is whether the circuit between the two PLA's goes across the poles of the breaker box or not. Throughput goes down dramatically across the poles.
I cannot stream high bitrate BD.m2ts rips between my server and my main viewing room using SMB because of lacking PLA throughput. I use DLNA instead of SMB because it is a lower overhead protocol (not much error checking) and can stream the highest bitrate BD titles perfectly.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #4 of 11 Old 11-04-2013, 09:20 AM - Thread Starter
Sittler27's Avatar
Quoted: 693 Post(s)
Liked: 62
Hmmm, not good.
Couple questions:
1. Do you think I'm better off using wireless N instead of powerline?
2. About DLNA, currenlty on my NAS I'm using unRAID. Anyone know how I would get it to run DLNA?
BlacMagik likes this.
post #5 of 11 Old 11-04-2013, 09:57 AM
Kelson's Avatar
Liked: 1147
PLA is always preferred over wireless. Wireless is never good for streaming full bitrate BD unless your player and wireless router are sitting in the same room.
I don't know anything about unRAID. I use Mezzmo on my server.
- kelson h
Kelson is offline
post #6 of 11 Old 11-04-2013, 10:29 AM - Thread Starter
Sittler27's Avatar
Quoted: 693 Post(s)
Liked: 62
I can't run ethernet cable to those TV locations, so I guess I'm pooched regarding streaming to where my A110 is. I'm wondering if a Roku 3 would fix it using it's dual-band wireless....or maybe it's ethernet is better than the A110 for powerline adapter.
Right now, I cant stream at all to my main floor TV.
post #7 of 11 Old 11-04-2013, 11:21 AM
StratmanX's Avatar
Quoted: 32 Post(s)
The problem with Powerline throughput drops is specific AFCI circuit breakers, not any/all circuit breakers. There may also be other issues uncounted for with throughput drops such as interference. There are fixes to try but they may be impractical or too expensive for some.
http://www.smallnetbuilder.com/lanwan/lanwan-basics/31238-slow-homeplug-five-ways-to-boost-powerline-network-speed?showall=&start=1
http://www.smallnetbuilder.com/lanwan/lanwan-howto/31316-slow-homeplug-try-a-powerline-filter
StratmanX is offline
post #8 of 11 Old 11-04-2013, 11:37 AM
StratmanX's Avatar
Quoted: 32 Post(s)
If you cannot run cable and Powerline is not a satisfactory solution then you may want to try the latest and greatest in WiFi -- the AC routers. WiFi Bridges/Repeaters may also be a lower cost solution.
post #9 of 11 Old 11-04-2013, 11:47 AM
elario's Avatar
Quoted: 42 Post(s)
Liked: 65
What model powerline are you using?
elario is offline
post #10 of 11 Old 11-04-2013, 12:21 PM
Kelson's Avatar
Liked: 1147
Netgear AV500's
- kelson h
Kelson is offline
post #11 of 11 Old 11-04-2013, 12:35 PM - Thread Starter
Sittler27's Avatar
Quoted: 693 Post(s)
Liked: 62
I'm using Actiontec powerline, from an Apple Extreme base station as the router.
