iMac vs Rio Central - AVS Forum | Home Theater Discussions And Reviews
Old 06-25-2002, 05:31 PM - Thread Starter
rtl_94087's Avatar
I have looked at the Rio Central and thought that this unit is really cool.
A component that I can add to my stereo rack and it will play and make MP3 files. Probably would have bought one on an impulse if not for the $1500 price tag.
Then, looking at what it actually does, why not just get an iMac to do the same thing.
What both do:
1) Rip CDs and encode to MP3 files
2) Stores MP3 files and plays them with playlists and other fancy stuff
Cons:
1) iMac does not fit with other stereo components and unit is larger than RioCentral
Pros:
1) Much cheaper, can pick up a used iMac for easily <$500
2) Screen is much larger
3) SW is obviously upgradely and better
My vision is to get rid of my stereo system as it exists now (receiver, CD player, cassette player, old turntable) and just get an MP3 player of some sort and hook the player up to powered speakers or to a simple amp and speakers. Nothing fancy. Am I missing something.
Is the sound quality from the RioCentral or the iMac dependent on the sound card inside these units and can I tell the difference, meaning should I care.
Any thoughts or comments appreciated.
rtl_94087 is offline
Old 06-26-2002, 11:08 PM
jleavens's Avatar
Believe me, thought about it many many times. The iMac solution offers a lot of benefits. I don't know about the sound quality question though. That might make a difference.
Remember that with the iMac solution, you'll have the keyboard and mouse to deal with... It was the lack of space that caused me to go a different way.
Remember, it's just television...
Planet Replay: http://www.planetreplay.com
Do you VUDU? http://www.planetvudu.com
jleavens is offline
