Popcorn Hour C-300 or Dune Smart - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-09-2013, 05:51 PM - Thread Starter
photocrazy's Avatar
I have narrowed down my streamer choice to Popcorn hour C-300 and Dune smart D1.
I am looking for a player which can play the higest bit rate bluray and which has stable playback of blu ray ISOs with full menu
Thanks in advance.
photocrazy is offline
post #2 of 10 Old 12-09-2013, 07:56 PM
halfelite's Avatar
Quoted: 423 Post(s)
Liked: 226
Will you be using any retail discs? Both are decent enough solutions The Dunes had a bit better menu support but if you use any retail discs the dune will not read fox discs.
halfelite is online now
post #3 of 10 Old 12-09-2013, 10:30 PM - Thread Starter
photocrazy's Avatar
I wont be using discs. I will be playing blu ray iso images from unraid server. So I am looking for a player which would play high bit rate files without stuttering with full menu support. I read through both forums but iam unable to find the max bit rate either would play.
post #4 of 10 Old 12-09-2013, 11:45 PM
halfelite's Avatar
Quoted: 423 Post(s)
Liked: 226
The max for both are way beyond that of bluray. Bluray caps out around 54mbit. people have played the BIRDS.mkv samples up to 110mbit so almost double of any bluray movie
post #5 of 10 Old 12-10-2013, 01:37 PM - Thread Starter
photocrazy's Avatar
Thanks. I was a bit worried coz Dune does not have gigabit.
Regarding blu ray iso playback, do both perform at the same level or one is better than other?
post #6 of 10 Old 12-10-2013, 01:39 PM
halfelite's Avatar
Quoted: 423 Post(s)
Liked: 226
They are pretty much identical in most playback, but since you want full menu's Dunes usually handled menus a bit better.
post #7 of 10 Old 12-19-2013, 09:58 AM - Thread Starter
photocrazy's Avatar
Thanks. I read in the review that Dune allows changing resolution using mode + numbers(1-5) in remote control, but it cannot be done during playback. Does it mean I can use this function in any other screen other than actual movie play back screen?
Or Is there any other way I can change resolution on the fly? coz I want my receiver to do the scaling for any resolution less than 1080 without going to setup--->video--> resolution etc. every time.
post #8 of 10 Old 12-19-2013, 10:01 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
you can only do it when on the dune UI, not while playing a movie.
Dune smart are the best 2D players with full BR menu support.
But you know that it's currently end of life and extremely difficult to find ? (even 2nd hand...).
Mr Eric is offline
post #9 of 10 Old 12-19-2013, 10:10 AM - Thread Starter
photocrazy's Avatar
Thanks, can I do it within Yadis movie selection screen before selecting the movie?
post #10 of 10 Old 12-20-2013, 01:31 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
good question, i never tried (my smart is doing the upscale for everything) so I don't know...
If i've got a bit of time today I will test it and will let you know.
Mr Eric is offline
Popcorn Hour C 300 Extreme Networked Media Jukebox
