Home media system - need advice on what will suit my needs - AVS Forum | Home Theater Discussions And Reviews
Old 12-12-2013, 12:36 AM - Thread Starter
Boooster's Avatar
I am very much lacking knowledge and after browsing around this forum I felt a tad overwhelmed at all the options so I thought I would make a post looking for advice.  I am looking to setting up a home media system that will allow me to do the following:
  • It will be located near the TV
  • Will have a remote and/or app (app preferable addition) that will allow me to select music via the TV.  I have no problem if it runs completely independent from the TV, keeping the next point in mind.
  • A way to store music on the device itself is preferable
    • I purchased a 3rd generation AppleTV and the WiFi in my apartment is lackluster at best.  Not sure if it is a problem with the AppleTV itself, but even with a repeater I can't get fast streams and there are constant errors with connecting to iTunes.  If this is a known issue with them I'd be open to trying a different streamer. that will let me add music/video without the hassle of iTunes or converting to .mp4
  • This could be as simple as buying a mp3 player and hooking it up to a good audio/speaker system, but I would preferably that this be a single unit.
So basically one of two options would be good for me:
  1. A confirmation that the AppleTV3 is not suited for my needs and I happened to pick a bad streamer.  A recommendation for a good streamer would be great.  If the streamer allows me to hook up an external HD directly (without need for a PC middleman) and automatically detect audio/video (even if I have to predefine it or put it in a specific folder so it knows where to look) that would be sublime, as it would eliminate any potential wifi issues.
  2. A home media system that will store music that is not too costly
For me #1 would be preferable (hence why I chose this sub-forum) so I can listen to music and watch videos on the streamer.  ANy recommendation/advice would be greatly appreciated.
Boooster is offline
Old 12-12-2013, 03:41 AM - Thread Starter
Boooster's Avatar
Looking around I see the WD TV looks like a good fit for my needs as I can just plug in my external HDD and go - can any of the more knowledgeable people confirm that this fits my needs?  Wouldn't want to waste more money on something that won't fit the bill
Boooster is offline
Western Digital Wd Tv Hd Media Player
