Storing Blu-ray Rips - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-01-2014, 05:45 PM - Thread Starter
Robsta's Avatar
How does everyone store their Blu-ray rips? What do people find is the cheapest storage solution?
I am currently looking at ways to store my 400-500 Blu-ray rips (approx 16TB). I have looked at using a NAS and then buying the individual hard drives but they seem extremely expensive. The cheapest option I have found is buying 4 x 4TB USB 3.0 External HD's priced at £130 each. The USB 3.0 interface (though I could use 2.0) would be more than fast enough to handle the bitstream of the rips.
Robsta is offline
post #2 of 12 Old 01-01-2014, 06:01 PM
watchy's Avatar
What do you mean by rips? Re-encodes to make them smaller or just remuxed to MKV keeping same quality? How knowledeable are you in computers / operating systems and how comfortable are you with do it yourself projects?
watchy is offline
post #3 of 12 Old 01-01-2014, 06:18 PM - Thread Starter
Robsta's Avatar
Hi watchy. Only the main title video, HD audio and necessary forced subtitles are remuxed to MKV. Files are about 25GB each. I am fairly knowledgeable on computers (Macs mostly) and would be comfortable with a DIY project.
Robsta is offline
post #4 of 12 Old 01-01-2014, 06:30 PM
ash_man's Avatar
Quoted: 57 Post(s)
Liked: 31
Those are huge files for rips, you should look at downsizing them to rips where the bit rate is about 10,000Mbps anything more then that and you won't notice the difference. Are these rips from movies you own? Do you care if you lose the files?
You can certainly go with the USB drive solution, however unless you have these rips backed up, you will lose whatever is on each USB drive when it dies. Also, depending on what media streaming device you are using, you'll only have access to what is on each drive when it is attached to a computer or streaming device via USB.
A NAS, while expensive, offers several advantages, firstly you get redundant storage, this is not to be confused as a 'backup' but simply storage with protection from at least one drive failure. A four bay Synology NAS with 4x4TB drives would give you just over 10TB of useable space when configured in RAID 5, you can plug it into a network and access the files over the network. This is what I do for the movies and tv shows in my collection, I have several NAS's actually of varying sizes and capacities. A NAS can also double as a network backup for other data, a time machine backup repository and the list goes on. As you have found out, a NAS solution is not cheap, but the advantages it offers make the investment worthwhile IMO and protect your data to a degree.
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Paradigm Home Speaker set 5.1 Cinema 100
Harmony 650
Asus Chromebox
ash_man is offline
post #5 of 12 Old 01-02-2014, 03:31 AM - Thread Starter
Robsta's Avatar
Thanks for the reply ash_man. Even though I do own discs of all of the Blu-rays I would prefer to keep the video quality as it is. The plan was to plug the USB external hard drives into a Time Capsule attached to my home network so files would be readily accessibly and then use older external hard drives to back these up. Your suggestion to use RAID 5 sounds very attractive and I have managed to find a relatively cheap RAID kit http://eshop.macsales.com/item/OWC/M3QX2KIT0GB/ which would work out approximately £210 with shipping (no drives). 4TB hard drives seem to be available at around £130 each. With RAID 5, am I correct in thinking that I won't lose any data if one of the drive fails and that if one does I can simply insert a new one and it will restore itself?
Robsta is offline
post #6 of 12 Old 01-02-2014, 07:56 AM
ash_man's Avatar
Quoted: 57 Post(s)
Liked: 31
Yes you are correct, if one drive fails nothing would happen, you would not lose any data, however should a second drive fail before you replace the first failed drive, you would lose everything which is why backups are important, RAID is no substitute for backups. With one failed drive, you would simply replace it with the same capacity drive, preferably same make/model and it will rebuild the array automatically although it could take a day or two to do so, you should still be able to access your data during the rebuild.
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Harmony 650
Asus Chromebox
ash_man is offline
post #7 of 12 Old 01-02-2014, 09:28 AM
mjt5282's Avatar
Quoted: 16 Post(s)
I have used a six disk RAID6 implementation that gave me nearly 11Tb free space for flac files and MKV Blu Ray rips. I have run out of disk space so I am building a home-brew ZFS file server using FreeNAS (freeBSD ZFS server) to replace it. I will be buying a Supermicro 24 bay server chassis with Xeon processor and 32 Gb of RAM. It will not be cheap, but I will be reusing the 3Tb disks from my 2 backup ZFS partitions. raid3z and FreeNAS seems a great way to go if you are familiar with ZFS and unix command line.
mjt5282 is offline
post #8 of 12 Old 01-02-2014, 10:41 AM
Inexistence's Avatar
Check out http://lime-technology.com/
You can build your own system if you like.
Inexistence is offline
post #9 of 12 Old 03-08-2015, 03:03 PM
latreche34's Avatar
Quoted: 115 Post(s)
Liked: 57
I know this is over a year old thread but anyone considered tape storage, 6TB LTO6 tapes seem to be cheap but drives are way too expensive usually $1,500
latreche34 is offline
post #10 of 12 Old 03-08-2015, 03:23 PM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 95
It's quite easy, too.
smitbret is offline
post #11 of 12 Old 03-08-2015, 03:32 PM
rockyht's Avatar
Liked: 3
Tape isn't really meant for live storage like spinning disks are.
rockyht is offline
post #12 of 12 Old 03-08-2015, 11:47 PM
funhouse69's Avatar
Quoted: 483 Post(s)
Liked: 152
Keep in mind that The LTO 6 Standard is 2.5TB Native and 6TB Compressed, Video files won't compress down that much so you will be lucky to get 3 - 4TB per Tape.
Denon AVR-X7200 - Klipsch RF-82 II Fronts, RC-62 II Center, RS-52 II Surrounds & R-112SW & Four CDT-5800-C II Ceilings for an Atmos 5.1.4 Setup.
funhouse69 is offline
