What's the Current Best Streaming Media Center Option? - AVS Forum | Home Theater Discussions And Reviews
Old 01-02-2014, 12:46 PM - Thread Starter
explosivebeer's Avatar
We're looking to get away from cable and go to a streaming setup that incorporates Netflix, Hulu, etc. with our own library of music and videos. Ideally we could access it from two TVs and possibly our phones via Plex. Is XBMC the way to go? Or can the Roku 3 somehow do it all? It's been awhile since I've built a PC but can go down that path if doing a dedicated HTPC is the only real solution. Thanks in advance for any input you have. I've found a lot of advice from various sites but much of it is outdated and I'm wondering if I'm missing an obvious option.
explosivebeer is offline
Old 01-02-2014, 01:15 PM
Greg Lafayette's Avatar
XBMC is AWESOME! give it a try, been using it for 6 months now, came from WDTV Live setups. everything is just about automated in XBMC after you set it up initially
Greg Lafayette is offline
Old 01-02-2014, 07:34 PM
chomps82's Avatar
Roku 3 will get your Netflix and Hulu. You can play both music and video through Plex on the Roku 3 but might not be able to play all the files depending what type they are.
I'm looking to do both. I have a Roku already but thinking of getting my HTPC going so I can use XMBC for videos and music.
chomps82 is offline
Old 01-02-2014, 09:57 PM
mayhem13's Avatar
Quoted: 43 Post(s)
I'd consider the Apple TV3. Hulu and Netflix interface are excellent as well as they're adding apps with every update. Very reliable unit as well.....just plain works all the time. You will have to encode your library to MP4 using Handbrake or the like. I currently have 5 un jailbroken ATVs in my home without a hitch. Once you start encoding to one container, everything else is gravy. ITunes has a great selection of PPV movies competitively priced.
mayhem13 is offline
Old 01-03-2014, 12:07 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
If you're going to run a Plex server you're going to either
a) convert all your media beforehand to a universally supported format (Roku has extremely limited file support)
b) need a moderately powerful PC to handle on the fly transcoding
you won't need an i7 thats overclocked or anything, but something based on the newer cpu architecture.
I use Plex to transcode some things on my Google TV box (as well as stream music to my phone). I have an AMD A10, which is more powerful than that task requires.
If you wanted to create a somewhat unified look among your devices you could try their Plex Home Theater htpc front end. It looks very much like their other clients (Samsung smart tv, Google TV, etc).
SandstormGT likes this.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Old 01-03-2014, 02:37 PM
SandstormGT's Avatar
Quoted: 203 Post(s)
Liked: 128
This guy knows what he is talking about, your only other option would be to use a full-blown PC as your client at every TV. I just got done building my own mini-itx file server with a Intel Core i5-4570 processor because the thought of re-encoding thousands of movies/tv shows into a useable format(regardless of whether for Apple or anything else) seemed like a nightmare. I also didn't want to have full blown pc's/laptop's(which can play any file format) attached to every TV in my house either.
The Intel processor I chose was, in hind-sight, way overkill. I have had 7 different blu-ray MKV's, ranging in file size from 13GB to 29GB, streaming to 3 phones, 2 tablets, a chromecast, and one PC. That means that my Plex server was actively transcoding 6 different streams, and the processor never showed it going over 25% and only about 2GB RAM out of 4GB was used.
So, to sum up what I have said and to re-iterate what pittsoccor33 said, althought not the cheapest, BUILDING your own media server that can handle the transcoding on the fly, regardless of container, video format or audio format is the best solution because it pretty much gives you the freedom of choosing ANY client you choose. The $25 Google Chromecast actually gives a image worthy of being watched once Plex transcodes the stream down to something that can be used by the Chromecast. Big investment up front but it should last you a very long time.
SandstormGT is offline
Old 01-03-2014, 02:59 PM
caseyparsons's Avatar
Quoted: 41 Post(s)
I use a $35 Raspberry Pi running XBMC ($free) for all local content. Plays 20GB 1080p rips flawlessly. Local content is saved on NAS and streams through gigabit wired network.
I also have a $35 Chromecast which streams Netflix, Hulu+, Youtube, and much more through my 802.11n wifi connection and the Internet. Works pretty flawlessly for me as well.
With those two small investments, I'm set for my media needs.
n00b
Theater Under Construction
Childhood Home Theater Build
caseyparsons is offline
Old 01-03-2014, 03:58 PM
SeldomSeen31's Avatar
Quoted: 23 Post(s)
Liked: 35
Seconded on these options. Not quite as elegant as a single box solution but for less than $100 out of pocket it is hard to beat. The RPi won't do HD audio codecs (as far as I know) but everything else it handles like a champ. I use a Dune player in my 7.1 set up specifically for the HD audio ability, my RPi serves the stereo only TVs.
Hi Casey, Andy Z from Alliance here, nice to see your post.
PSN ID: Seldom_Seen
SeldomSeen31 is offline
Old 01-03-2014, 03:59 PM
ash_man's Avatar
Quoted: 57 Post(s)
Liked: 31
How do you navigate the content on your Pi, do you use a remote?
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Paradigm Home Speaker set 5.1 Cinema 100
Harmony 650
Asus Chromebox
ash_man is offline
Old 01-03-2014, 11:17 PM
Quoted: 23 Post(s)
Liked: 35
XBMC has a free app for android, I think ios has a version too. I use irule on my android devices as well and the IP commands work nicely within that app too.
There are standard IR remotes available that use a dongle plugged into the Pi's USB port, I don't have experience with those though.
PSN ID: Seldom_Seen
Old 01-04-2014, 12:06 AM
ronnbot's Avatar
I used to use Plex but moved to XBMC. I also suggest building a media server to run XBMC and share its library.
On our (Android) phones we can access and play media from the XBMC's library via BubbleUPnP and MX Player. We also have Windows, GoogleTV, Mac Mini accessing the same library. There are clients/apps for other devices like AppleTV, RasberryPi.
ronnbot is offline
Old 01-04-2014, 12:15 PM - Thread Starter
Lots of great info and advice. Thanks everyone. I guess finding some of this out makes me re-think my approach.
Up-front costs aren't a problem since I know it'll save me a lot long-term. Should I:
A) Use my current desktop (Pentium dual-core 2.8 GHz w/ 4 GB RAM) as a NAS and setup Raspberry Pi devices at the TVs to run XBMC and then just use the phones/Surfaces as remote streamers with Plex.
B) Build a new dedicated media center (or get a nettop of some sort) that I can either have attached to the main livingroom TV (or have hidden around the house somewhere if it's just a file server) and use another device like a RPi box for our bedroom TV.
And I guess one thing I'm confused on is if I have a central media server and a RPi unit or two, would I need Chromecast also or would XBMC integrate that functionality? I thought XBMC integrated Netflix, Hulu+, Youtube, etc. but I've never played with it so maybe I just have misconceptions about it doing everything.
Thinking one more step ahead and wanting to integrate surround sound on the main livingroom setup, which option is going to give the best feed to a receiver? And what should I be on the lookout for in a new receiver?
Old 01-05-2014, 10:01 PM
gemballars's Avatar
You could try using "Serviio" its a free DLNA server program. I'm currently using this program to stream movies over my network using a wireless-n router to my TV. I mostly stream 8-15Gb BDRiP and BDRiP3D movies with DTS and I have one high bitrate BDRiP that is 25.7Gb streaming at 38451kbps with full DTS-HD. Hope that helps or atleast gives you some sort of idea.
gemballars is offline
Old 01-06-2014, 01:02 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
PLEX!
GusGus748s is offline
Old 01-06-2014, 07:51 PM
Quoted: 41 Post(s)
Well, if we're voting, I vote for option A. That's pretty much what I do and it works great for me. I use unRaid for my NAS, but there are many options and they all work.
I use the official XBMC app for my android phone. It's not beautiful, but it works solid.
n00b
Roku 3 Streaming Player With Motion Remote , Western Digital Wd Tv Live Streaming Media Player Wifi
