Network music player with Web GUI - AVS Forum
post #1 of 6 Old 01-04-2014, 05:35 PM - Thread Starter
eagleknight's Avatar
I am trying to find something similar to a Squeezebox I guess, but those can get pricey even older models on ebay. http://www.raspyfi.com looks like a possible solution, but is there anything else out there that I maybe looked over. I have a home audio system that is very basic. Speakers in all rooms, but it all goes back to one amplifier with only volume controls in each room. So I need a music player that has the ability to control it from a web interface because it will be sitting by the amplifier in the basement.
eagleknight is offline
post #2 of 6 Old 01-05-2014, 07:54 AM
kneedragger's Avatar
I believe you can do this with XBMC. I know there are apps that can be used to control XBMC headless. I just tried one out not to long ago.
From what I've seen it looks like RaspyFi evolved into http://volumio.org/ also.
kneedragger is offline
post #3 of 6 Old 01-05-2014, 10:23 AM
djgallaw's Avatar
You can do this with Squeezebox Server and a software player such as Squeezelite. You don't need a hardware player.
djgallaw is online now
post #4 of 6 Old 01-05-2014, 11:37 AM - Thread Starter
I still need some kind of hardware solution to run the squeezelite on either rasberry pi or PC... Maybe I should add it needs to be low cost and low power usage. Thanks Kneedragger for that link.
post #5 of 6 Old 01-05-2014, 12:34 PM
djgallaw's Avatar
If you are leaning towards an Rpi there is Picoreplayer which works well.
Keep in mind there are myriad other software /devices to do playback via Logitech Media Server:
Community Squeeze Wandboard
Vortexbox VAMP (for plugs)
Vortexbox (headless Squeezebox server/player for a computer)
Daphile (headless server/player for a computer)
Squeezelite for osx/linux/windows
Also Android and ios devices can do playback
Squeezeplayer
All these players can be controlled via web gui of Logitech Media Server.
post #6 of 6 Old 01-05-2014, 04:54 PM - Thread Starter
The XBMC route looks promising. There are a number of mini PC Android devices that have an AV out built in and come loaded with XBMC already. Yes, there are some web interface add-ins and also apps for android devices as well to use as a remote. One of these would have plenty of power to just be used for music.
Logitech Squeezebox Wi Fi Internet Radio Receiver Store Display White Box
User Tag List
