What do I replace my Boxee Box with? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-05-2014, 11:43 AM - Thread Starter
rayf01's Avatar
I have a Boxee Box that seems to be on its last legs. The remote has went wonky and then completely died. I tried to re-pair it and replace the battery but it didn't work.
I stream video from my PC mostly, usually HD MKV files and I also watch Netflix, that's about it.
I need:
- Netflix capable - Ideally SuperHD compatible (Boxee wasn't)
- Play video files over my network, needs to support HD MKV files that are big, 1080p DTS etc.
- Optical Audio Out port
- HDMI for video
- Network capable, ideally over Cat5e but Wireless would also be beneficial.
Would it be better to build a small PC for this, or can I get away with another streaming media player?
rayf01 is offline
post #2 of 11 Old 01-05-2014, 11:58 AM
wingzfan61's Avatar
Whats your budget?
An htpc with xbmc is my preferred setup. Netflix can be loaded up through windows media center using a simple script activated from a remote or just find a cheap blu ray player. I grabbed one for $46 last week from best buy to handle netflix and pandora but i also use an apple tv.
But as far as Im concerned nothing beats xbmc for mkv's, avi etc.
wingzfan61 is offline
post #3 of 11 Old 01-05-2014, 12:02 PM
ash_man's Avatar
Quoted: 57 Post(s)
Liked: 31
Look for a used Boxee on Craigslist or Kijiji, that's what I do when they die, nothing beats the Boxee for simplicity IMO, HTPC's are great but they are so under used IMO for streaming and things like netflix. You can get netflix from an xbox, WD media player or cheap BR player.
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Paradigm Home Speaker set 5.1 Cinema 100
Harmony 650
Asus Chromebox
ash_man is offline
post #4 of 11 Old 01-05-2014, 01:16 PM
wingzfan61's Avatar
Biggest issues with boxee is its 100mb connection. Large 1080 rips take forever to load and often buffer. Beyond that is they die way too fast. Ive got a 10 year old dell htpc running to this day as a bedroom setup. Bought it used for $50 and will play a 40 gig mkv within 2 seconds and never buffer.
I just built a new living room system that will run at least 10 years for $320.
post #5 of 11 Old 01-05-2014, 02:36 PM - Thread Starter
rayf01's Avatar
I'll have to look in to it then. My boxee runs 10-15 GB MKVs just fine. I don't play anything that is 40GB in size though.
rayf01 is offline
post #6 of 11 Old 01-05-2014, 07:03 PM
ash_man's Avatar
Quoted: 57 Post(s)
Liked: 31
You have a problem either with your network switch or your network, I play 20GB plus MKV files through my Boxee no issues at all, so the fact that its a 100MB interface on the Boxee is not an issue. Its true, their lifespan could be better, I've got one thats about 2yrs old and its still going strong. HTPC's are nice but they have so many components that can fail whereas the Boxee has none but itself that can fail. To each his own.
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Harmony 650
Asus Chromebox
ash_man is offline
post #7 of 11 Old 01-07-2014, 05:22 PM
DMSUCHY's Avatar
Same thing is going on with my Boxee, I'm considering a WD TV Live. But I'm also considering building a UnRAID PLEX server and stream to Roku 3s if I can figure it out.
DMSUCHY is offline
post #8 of 11 Old 01-16-2014, 04:32 AM
bsanf3's Avatar
Bummer Newegg is out of the refurb units, I should have bought more than one a couple of weeks ago.
NoBetterDeal has 1 left.
bsanf3 is offline
post #9 of 11 Old 01-16-2014, 06:12 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Since Netflix is a requirement, along with HD audio, etc., the only alternative to another Boxee would be a WD TV SMP.
Hi-deft Media Keen Videosaurus
Brajesh is online now
post #10 of 11 Old 05-19-2014, 06:02 PM
stirfr's Avatar
Yeah - my Boxee remote went wonkey too - replaced it with the 2032 lithium battery per the one that was in there - didn't work. Flipped the battery - Voila!
The marking "-" on the plastic of the tray is wrong! Just flip the battery so "+" is on the bottom. Brand new boxee controller!
stirfr is offline
post #11 of 11 Old 05-19-2014, 09:42 PM
UHD Addict
aaronwt's Avatar
Quoted: 5191 Post(s)
Liked: 3099
I always look at the orientation of the battery before I remove it. Then just put the new battery in the same way. I still have three Boxee Boxes and remotes working fine. Although they have not been turned on much during the last year.
Since getting my A400's I stopped using my Boxee Boxes for the most part. I do wish they would have come out with a successor with a faster processor and fixed some of the issues it had. That would have been an excellent box. Instead we got the Boxee TV. Which I still have somewhere but I would have never purchased it on my own. Boxee gave me one.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
The Boxee Box By D Link Hd Streaming Media Player
