802.11ac for streaming 1:1 Blu-ray ISO over Home Network - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-21-2014, 11:13 AM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
Just moved into a home here in Southern California; looking for some advice on Home Networking.
Essentially I'm looking for advice from actual users of 802.11ac to stream 1:1 BD ISO rips over wifi. I know it's possible and a lot of people are using it. I've read plenty of reviews with real world testing of streaming full BD ISO rips over ac wifi.
I have an HTPC that houses all my media, including full BD ISO rips, amongst other high bitrate MKV's, etc. This is in my Home Theater. In my bedroom I have the Dune Smart D1 network media player. The Home Theater and the Bedroom are separated by a Living Room in the middle, but are on the same level.
Previously I was in a little apartment where I was running an Ethernet Cable to stream the media; I've looked at all options for running the cable in this home and it's somewhat impossible. I'd like to use the 802.11ac wifi to do the same. I've used 5Ghz N band to stream in the past and all but my 1:1 BD ISO's were able to stream ... since 802.11ac can handle full BD ISO's, I'd like to use that.
What I primarily want advice on to begin with:
- What Router/Adapter should I get (Brand/Model). If someone has experience doing what I'm doing and successfully stream BD ISO's, I'd be interested to get the same brand/model as you have.
- Since I'm streaming from a Windows 8 PC to a Dune Smart D1, how do I get this networking to work ... do I need to 2 Routers?
Any advice would be helpful.
7.1: Polk RTi12 Fronts, RTi8 Surrounds, Monitor70 Surround Backs, CSi A6 Center + Outlaw LFM-1 EX Subwoofer.
Yamaha RX-A2000 AVR
Epson 5010 3D Projector
Intel Sandy Bridge 3D HTPC / Blu-ray Player
mickey79 is offline
post #2 of 14 Old 07-02-2014, 09:26 PM
Davidvan79's Avatar
Thumbs up Blu Ray on 802.11ac Works for me!
Hi Mate,
I also have a dune smart D1...actually I have 2 ( 1 hard wired to my router in my bedroom, and another connected via a bridged router in the living room.
I use 2 Netgear 802.11ac routers ( 1 x R7000 as the main router, 1 x R6300 as a bridge).
I also run a Logitech HD Skype camera off the R6300 to make Skype calls off the TV! its great!
I set up the R6300 in bridge mode in the living room. It is probably about 30 to 50 feet away from the main router in my bedroom, I get about 800MB/s connection speeds between the two which I easily enough to stream 1:1 Blu ray movies (main movie only) with the HD audio too. So far it works great.... I had a bit of stuttering with the R6300 originally so I got the new R7000 nighthawk which is much faster as the main router and now use the R6300 as the bridge.
If you want to stream blu rays without running cabling through your house this is the way to go.
Netgear have already got a new router coming out this month that is a tri-band 802.11ac router, which has 2 separate bands for 802.11ac 5ghz and another for the 2.4Ghz. This means you can have more wireless clients running together at faster speeds at the same time. link below
http://www.netgear.com.au/home/produ...ers/R8000.aspx. Maybe you could by this as your main router...and get the R7000 as the bridge. This is what I plan to do.....
I will probably sell the R6300 to my brother!.
Davidvan79 is offline
post #3 of 14 Old 07-03-2014, 04:32 AM
BobSalita's Avatar
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
I stream Blu-Ray ISOs 1-1. Works great. Took years of trying but finally have consistently great results.
Windows 8.1 running on a Gigabyte Brix N2807 (a barebones, fanless Celeron 1.5GHz non-turbo). Ethernet wired.
3 USB 3.0 storage units, all different brands, 4 drives each. All on a single USB 3.0 hub and then into the Brix.
Data stored on 12 USB drives using Windows Storage Spaces.
ASUS AC68U router. Latest firmware.
Intel 7260 802.11ac mini-pci cards in notebooks. 5GHz connection only. 2.4GHz isn't fast enough.
VLC player. Requires mounting of ISO on local notebook. Then selecting Blu-Ray mounted drive.
All my notebooks are Windows 8.1 and can receive Blu-Ray ISO flawlessly, no stutters, no dropped frames. My ultimate test is always Star Trek 2009. The opening scene is brutal on a marginal network. The router is located 3m away and through one thick plaster wall.
Former Top 1000 Amazon reviewer bemoaning the loss of objective user reviews. Amazon, stop your complacency!
BobSalita is offline
post #4 of 14 Old 07-06-2014, 10:11 AM
bobsilver's Avatar
Quoted: 107 Post(s)
Liked: 61
Originally Posted by Davidvan79 View Post
Hi Mate,
Excellent advice and this is the way to go. Regarding the Netgear R8000 see my thread in AVS introducing this router. In your case if you will want to be streaming BR while others in your home are actively using wireless and want to ensure best performance for all then the R8000 is the way to go plus either an R7000 or a R6300 Netgear as a bridge. Otherwise either 2 R7000 or 1R7000 and a R6300 will do the trick as stated above.
Bob Silver Netgear AV Consultant
bobsilver is offline
post #5 of 14 Old 07-08-2014, 12:10 AM
Davidvan79's Avatar
Blu Ray ISO over 802.11ac wifi
Here is my setup demonstrated on youtube...
https://www.youtube.com/watch?v=xFG7...ature=youtu.be
post #6 of 14 Old 07-08-2014, 06:50 AM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 95
To keep it simple, you'll want to get the best router which means you'll probably want:
NetGear R7000
or
Asus RT AC66U
or
Asus RT AC68U
Either way, your gonna be into the router about $200.
You can cheap out on the clients, though. There's not much out there in the way of AC adapters so I would just pick up a couple of these for locations to be bridged:
http://www.newegg.com/Product/Produc...-177-_-Product
Most of the reviews are negative because the Atheros chip it uses seems to really struggle with Apple devices as well as firmware glitches previous to the release of v2 and an updated firmware this spring.
They are easy to set up in bridge mode and I have measured wireless bitrates up to 450Mbps, typically running about 380Mbps, plenty for BR ISO. Of course, distance and obstructions will make a difference. You may need to play with the antenna and/or orientation of the devices at their respective locations. I know I was able to bump my bitrate 100Mbps+ by simply moving the bridge to the right 4 feet (farther away, actually) and hence, avoiding some metal ducting. 5Ghz is so stinking sensitive to obstructions.
smitbret is offline
post #7 of 14 Old 07-09-2014, 03:50 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
just ordered an Asus AC66U. i should receive it from Amazon this friday and will test and report here if you want
Currently I use wifi N but in an old house with huge walls so i don't get more than 30/50mbs (70mbs max when everything is perfect...) between actual router and my PC on first floor which is definitively not enough for streaming HD content.
If I see a huge bump in transfer speed I will be extremely happy I don't ask for the full 1Gbs, but 300mbs will be more than enough.
Mr Eric is offline
post #8 of 14 Old 07-09-2014, 05:53 AM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
Max bitrate for Blueray is 40Mbps, although most movies don't stream at that rate...it's important to setup QoS on the AP to give priority to video, that way other devices accessing the wi-fi don't interrupt the stream. The speeds you listed above should be fast enough for HD content, unless your listing radio rate speeds and not ethernet speeds (ethernet speeds are generally 1/2 what radio rate speeds are).
Also 802.11ac will be useless if you're end points don't support 802.11ac as well.
bac522 is offline
post #9 of 14 Old 07-09-2014, 06:25 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
my PC supports AC of course
bitrate is not everything as you say and my main problem is that it's currently absolutely not stable, ranging from 29mbs to 70mbs max with an average around 32/39mbs (those are radio rates). Which is not enough for me to stream any HD content...
Unfortunately I use my cable box as router and it's a very poor router without any minimum functionalities, maybe changing it for a proper N router would have been enough, but i wanted to go for the AC at least to be a bit future proof.
Mr Eric is offline
post #10 of 14 Old 07-09-2014, 05:28 PM
bac522's Avatar
Quoted: 177 Post(s)
Liked: 100
If 70Mbps is max radio rate, this tells me you've got the router setup using only a 20MHz channel, if you set up the AP to use a 20/40MHz use you will have twice the speeds you're getting now (barring the noise floor/interference is acceptable)...but in any case you should see much better speeds with the 802.11ac router.
That being said, 802.11n should have no problem streaming bluray video when setup correctly and interference is light.
bac522 is offline
post #11 of 14 Old 07-10-2014, 08:50 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
unfortunately my router is on 20/40Mhz. I made some tests, just going out of the room where the PC is (but still to the first floor, close to the stairs) bumps my rate to 130mbs. On the same floor as the router I can reach 170mbs. I already had 240mbs with other routers when traveling.
I think that my router is very bad (that's not a dedicated one as I use my cable STB for that). There's also the fact the I'm in a city center and a simple NetSurveyor test shows 43 Wifi networks in the neighborhood, with most 2.4Ghz channels full (and I guess that 5Ghz is the same...).
Mr Eric is offline
post #12 of 14 Old 07-10-2014, 12:33 PM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 95
I agree, I would never try to stream BR Rips over wireless N. I've never been able to have good, stable playback that let me FF/Rew, etc. with any kind of quality even when running 20/40MHz from my router and clients.
For BR, it's AC or wired.
smitbret is offline
post #13 of 14 Old 01-30-2015, 01:29 AM
blackcell's Avatar
Quoted: 13 Post(s)
I started streaming over .11g (many yrs ago) which quickly became an exercise in futility, then tried .11n for awhile but wasn't acceptable. Finally .11ac takes the crown.
Home theatre Downstairs/HTPC --> R6300 bridge mode --> Upstairs/R7000 --> clients
I force some client devices to use 5GHz only. From HTPC I can stream BD rips to my bedroom upstairs w/o issues. I setup QoS & load balancing since my son is often glued to Xbox One.
blackcell is offline
post #14 of 14 Old 01-30-2015, 02:29 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
I completely forgot about this topic
just a quick update after using the Asus AC66 for a few months : it's perfect. I'm now able to have a stable 468mbs rate using the exact same configuration as before where I only had 30/70mbs. Streaming BR rips 1:1 is perfect (I don't do 3D streaming but I guess it would good as well).
At first I "only" had 300mbs, but after reading some tweaks in various forums (the Asus is fully manageable and there's a lot of options to tweak) I finally reach the 468mbs which seems a maximum for me.
I would highly recommend AC if you can't have wired connection
Mr Eric is offline
Dune Hd
