*Official* Amazon Fire TV Discussion Thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #1261 of 1854 Old 10-31-2014, 06:53 AM
Otter0911's Avatar
Quoted: 69 Post(s)
I noticed the new Netflix app says HD and no longer Super HD... Is it still playing in 1080?
Otter0911 is offline
post #1262 of 1854 Old 10-31-2014, 09:05 AM
calculon68's Avatar
Quoted: 106 Post(s)
Liked: 56
Not all Netflix videos are available in SuperHD (1080) The test clips like El Fuente: 60 MP10 still play in 1080.
I'm noticing that the Amazon Instant videos are playing in 1080 quicker and more consistently after the update. I'm reaching 1080p after roughly 60 seconds now. I'm assuming it's still a 9 MB stream (compared to Netflix's 5 MB). I tested it against a random selection of entries from my Video Library last night- and it always reached 1080 shortly after the one minute mark after hitting play. Whereas before; 1080 was several minutes.
calculon68 is offline
post #1263 of 1854 Old 10-31-2014, 10:31 AM
UHD Addict
aaronwt's Avatar
Quoted: 5194 Post(s)
Liked: 3103
They really need to improve the speed that it ramps up to 1080P on the FireTV. The TiVo and Roamios ramp up to 1080P in under two seconds with Prime Streaming. The longest I've seen it take is 5 seconds. Unfortunately though the Amazon app is sluggish. But it will output in 1080P24.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #1264 of 1854 Old 10-31-2014, 10:59 AM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
Super HD was always a silly term and should be retired as really doesn't mean anything any more for Netflix. They only have 2 1080P streams now - 4300 and 5800 kpbs (both what they used to call Super HD).
Hence forth it would be better just to say 1080P for Netflix.
Interesting about the Amazon 1080P ramp - I'll have to try - for me it seemed to take about a minute to ramp before the update.
I have seen Amazon 1080P 10 minute averages of 12 - 13 Mbps but assume this includes some buffering filling etc. The only show where I took checked the the total data downloaded through the show and divided by the show running time came out at almost exactly 10 Mbps.
undecided is offline
post #1265 of 1854 Old 10-31-2014, 12:40 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
Are there any apps yet than you can do a bandwidth speed test?
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #1266 of 1854 Old 10-31-2014, 03:39 PM
apw2607's Avatar
Quoted: 111 Post(s)
Liked: 220
Yes, they just did away with the SuperHD term in the new UI. Its still HD ... which as already indicated can be 5800kbps @ 1080p
Otter0911 likes this.
apw2607 is offline
post #1267 of 1854 Old 10-31-2014, 03:41 PM
apw2607's Avatar
Quoted: 111 Post(s)
Liked: 220
There's away to trick it, by simply scrolling to 30s+ and hitting play and you will instantly see it switch to max bit rate/resolution. You can then scroll back to the beginning of the clip .... don't ask me why its like that .. but there you go.
reddice likes this.
apw2607 is offline
post #1268 of 1854 Old 10-31-2014, 06:48 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
That is exactly what I do as it gives me instant HD playback. On the FTV it is 30 seconds. On the Roku 3 it is 40 seconds and on the PS3 & PS4 it is 50 seconds.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is offline
post #1269 of 1854 Old 11-01-2014, 06:22 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
How can you tell on Amazon and Netflix what you are getting? My Sony player tells you, but I havent seen where the Fire does.
post #1270 of 1854 Old 11-01-2014, 09:10 AM
calculon68's Avatar
Quoted: 106 Post(s)
Liked: 56
For Amazon content, simply press/hold down the "down" on the ring. It'll identify the stream quality in the lower left hand corner.
Netflix doesn't tell you directly what quality you're receiving, that's what the test clips are for. Add the "El Fuente" test stream to your Netflix queue and play it. That will al least tell you if you're capable of getting 1080 content. (and again, 1080 isn't available on all Netflix videos)
post #1271 of 1854 Old 11-01-2014, 09:11 AM
UHD Addict
aaronwt's Avatar
Liked: 3103
In the Amazon streaming app, on the lower left corner. HD will be grayed out when getting SD. HD will be lit when getting 720P and then HD 1080P will be lit when streaming 1080P.
aaronwt is offline
post #1272 of 1854 Old 11-01-2014, 09:44 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
Thanks, I was aware of the "HD" logo on Amazon, just want sure on telling if it was 1080p or 720p. I'll add the Netflix video to my queue, one thing I like about the Sony blu-ray players telling you what you are getting.
post #1273 of 1854 Old 11-01-2014, 01:33 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
Are you sure that when it only shows HD that it is only 720p because it looks very close to 1080p to me unlike Netflix crappy 720p. However 1080p content on Amazon blows away Netflix at 720p and 1080p looks better. Netflix thinks that the eyeIO codec is so great but it really is just bitstarved HD. Still Netflix 1080p does look great but 720p looks just as bad as a Dish Network HD channel.
reddice is offline
post #1274 of 1854 Old 11-01-2014, 02:52 PM
dlflannery's Avatar
Looks like the keyboard shortcut to video parameters in Netflix (Ctrl-Shift-Alt-D) no longer works with the recent update. I wonder if it has a different one?
dlflannery is offline
post #1275 of 1854 Old 11-01-2014, 05:02 PM
UHD Addict
aaronwt's Avatar
Liked: 3103
It used to be 720P. And it could also be the player too. Otherwise I don't know what the difference would be between HD and HD 1080. I do know with my FireTV when only HD is lit the quality is noticeably lower than when HD 1080P is lit.
aaronwt is offline
post #1276 of 1854 Old 11-03-2014, 08:33 AM
dlflannery's Avatar
NavySeal where are you?
NavySeal had 55 posts on this thread thru 6/25/2014 in which he said he would be on the road for a while. If he really is a Seal I can understand how he might be completely incommunicado. But I wonder if there is some other reason he's not posting?
post #1277 of 1854 Old 11-03-2014, 08:36 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
He could tell you, but then he'd have to kill you.
post #1278 of 1854 Old 11-03-2014, 09:27 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Just got one. Anyone else notice about 1/8 of the bottom of videos played through plex tend to display wrong? Some sort of skipping or something where the bottom pixels are shifted (typically to the right). It's almost like the old days of VHS picture tearing (but obviously not the same thing).
wkearney99 is offline
post #1279 of 1854 Old 11-03-2014, 05:08 PM
laajr's Avatar
HD Bandwidth Requirements
Has Amazon changed the minimum bandwidth requirements to receive HD on the FTV?
I have a 6 Mbps dsl connection which is consistently showing 5.2 Mbps on speedtest. I had a first generation ROKU which showed a Amazon stream at 2.5 Mbps (out of 5.1 Mbps available) which at the time was a HD stream. On the FTV, movies show HD (highlighted) and then the HD logo is grayed out. Video doesn't look HD; poor detail, etc.
Are 2.5 Mbps HD streams still available on Amazon (and FTV) or is there a new minimum that is required to stream Amazon HD?
laajr is offline
post #1280 of 1854 Old 11-04-2014, 02:11 PM
poorhorse's Avatar
Is it possible to update Netflix app (new UI) without updating FireTV's software? My FireTV is rooted, so I have blocked software updates, but Netflix with new UI would be nice.
poorhorse is offline
post #1281 of 1854 Old 11-04-2014, 02:43 PM
dlflannery's Avatar
AFAIK, no. I tried it before my FTV got the latest software. See post #1243 in this thread.
post #1282 of 1854 Old 11-04-2014, 03:02 PM
bambam's Avatar
Quoted: 70 Post(s)
Liked: 38
I have downloaded the new Netflix app and can get into my account on FTV. However, when I try to play any show/movie, it says "currently not available" and doesn't play anything. Anyone else experiencing this?
bambam is offline
post #1283 of 1854 Old 11-04-2014, 04:56 PM
dlflannery's Avatar
Try this:
https://help.netflix.com/en/node/14486
Definitely a bug that needs to be fixed.
post #1284 of 1854 Old 11-05-2014, 06:28 AM
dlflannery's Avatar
YouTube app improved with update ?
After update to 51.1.4.0_user_514006420, the default YouTube app seems better. The search text no longer shrinks so small you have to stand 3 feet from the TV to read it. And I was able to get through one 45 minute Daily Tech News Show video without it locking up.
Still won't accept search text from my k400 keyboard though.
post #1285 of 1854 Old 11-05-2014, 07:43 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
My Fire TV just rebooted with a blue screen crash after I watched something on Netflix.
reddice is offline
post #1286 of 1854 Old 11-06-2014, 08:20 AM
dlflannery's Avatar
I've only had the one crash that I posted about a while back, but I've only had my FTV for about 3 months. I find it interesting that the Netflix help page linked in my post #1285 instructs to clear data and cache for the Amazon Video application. This suggests that there might be a bug in memory management by that app -- which apparently has an interaction with playing Netflix videos.
post #1287 of 1854 Old 11-06-2014, 09:14 AM
nephipower's Avatar
Does the new Netflix update include universal search that is part of the Fire TV OS?
I also have read on previous reviews that doing text search on Fire TV is awful because you have to scroll through a long list of alphabet to type each character. Is that still the same?
nephipower is offline
post #1288 of 1854 Old 11-06-2014, 10:36 AM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
Me too but since they updated the Netflix app I have been using the Fire TV much more and I have not rebooted it in a week before the crash but it was starting to get sluggish before. Video would freeze for a few seconds which a left click 5 second rollback would fix.
reddice is offline
post #1289 of 1854 Old 11-06-2014, 11:13 AM
dlflannery's Avatar
I hope the FTV doesn't need to be rebooted weekly just as preventative maintenance. Is this something related to Android? My Logitech Revue Google TV (also Android) has to be rebooted every couple of days or videos start hesitating -- not that I use it very much. I have a task manager ap sideloaded onto the Revue and it clearly shows the amount of free memory going down just sitting there for a day or two.
It would be interesting to track cache and data size on the Amazon Video app and see if there is a correlation between their growth and the video problems. I haven't seen those video problems but I probably don't use Netflix as much as you do.
post #1290 of 1854 Old 11-06-2014, 11:28 AM
dlflannery's Avatar
No the FTV search doesn't search Netflix. AFAIK, there are just four apps that FTV search will search within. They include Vudu, Crackle and two others I can't remember.
EDIT: Not Vudu. The four aps are Vevo, Crackle, Hulu Plus and Showtime Anytime.
The text search still has the long line of characters to select. I use voice search almost exclusively and find it very good. You could consider getting a wireless keyboard. The Logitech k400 works great, costs about $25, and it can enter text for the FTV search, Netflix search and every ap I've tried except the default YouTube ap. There is another free YouTube ap in the Amazon ap store called "uTube for YouTube" that does accept keyboard search text.
