*Official* Amazon Fire TV Discussion Thread - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 62Likes
post #1531 of 1879 Old 02-28-2015, 01:43 PM
iamloco724's Avatar
Quoted: 16 Post(s)
I got Kodi installed on my fire tv but a few questions
first the app seems to be off screen the time is cut off and the bottom as well etc.
2nd is i have no idea how to install the things i want, i got add on installer on
I see some of the add ons i want but not all of them, i was interested in putting SportsDevil on i dont see that anywhere and not sure how to install it my self, i want an add on for live ppv suchs ufc and wwe
so can anyone walk me through how to do that and install other add ons i dont exactly see, please play dumb with me because i have no clue about any of this as im just dipping my feet in
iamloco724 is offline
post #1532 of 1879 Old 03-01-2015, 06:22 AM
bigcat's Avatar
Quoted: 98 Post(s)
I received my FireTV couple of days ago. When playing a movie with 5.1 sound from Amazon Instant Video, I am only getting 2.0 sound. If I play the same movie with my PS3, it plays 5.1 sound.
Now, If I force Dolby Digital Plus in the FireTV settings (instead of auto), my receiver does see DD+ sound. So, the question is, why is it not doing it automatically, and also, is the DD+ an artificial thing that is doing, or is it really the actual 5.1 sound from the movie?
BenQ W1070/Silver Ticket 120"/Denon X4200W/Infinity Primus | Vizio 80" 3D LED M801D-A3 w/ Denon X3200W/Infinity Primus | Sony Bravia XBR-60LX900 w/ Sony HTCT550W 3D Sound Bar | Sony SXRD KDS-R70XBR2 w/ Onkyo HT-S770 | Sony PS3 (Slim) | DIRECTV Genie HR44-500, C41s | Harmony 700
bigcat is offline
post #1533 of 1879 Old 03-01-2015, 10:34 AM
RVD26's Avatar
Quoted: 55 Post(s)
Do a Google search for 'Super Repo'.
To get the really good add-ons, you'll have to add on repositories such as Super Repo.
Fusion is another good repository.
In terms of your first question, make sure the TV aspect is set right.
Change the TV aspect until everything fits on the screen.
RVD26 is offline
post #1534 of 1879 Old 03-05-2015, 03:26 PM
Blacklac's Avatar
Anyone notice there unit has micro lag/stutter on the home screen? It was butter smooth then suddenly it seems slightly bogged down. The last thing I did was link Kodi's download path to the units download folder, but I never actually downloaded any content. Knowingly...
I have nothing else sideloaded. I'm not rooted.
is there a way to reset the device without wiping it? Like a soft reset or something?
Blacklac is offline
post #1535 of 1879 Old 03-05-2015, 03:32 PM
cr671's Avatar
Quoted: 58 Post(s)
Liked: 32
Careful with root on this device and make sure it's on the correct OS version before proceeding. One of the latest updates made rooting extremely difficult and will actually blow a fuse leaving you with a nice paperweight.
S5 tap'n
cr671 is offline
post #1536 of 1879 Old 03-11-2015, 11:27 PM
Liked: 0
so do I need to make sure I get a FTV that is actually rootable so I can put Kodi on it or will anyone do? I have read some of the newer ones are harder to root. Where can I buy one that will let me put Kodi on it and be able to Sideload APKs? Does it matter where I buy it?
marsd is offline
post #1537 of 1879 Old 03-12-2015, 09:52 AM
bigcat's Avatar
Quoted: 98 Post(s)
You don't have to root the FTV to be able to put Kodi on it. I am running Kodi fine without rooting it. Take a look at the Kodi/FTV wiki.
bigcat is offline
post #1538 of 1879 Old 03-13-2015, 06:35 AM
PJ311's Avatar
I'm hoping somebody can help me here. I just recently got a fire tv and installed kodi and all is great except when playing videos from my server. I get a lot of studdering and dropped frames while using xbmc, when I streamed them using my wdtv they were nice and smooth with no studdering. I have been scouring the internet for a fix but have not had any luck thus far, hopefully someone will have some input on how to correct this.
Couple of other question;
How do I get on screen diagnostics to show using the fire tv?
How do I get to the audio settings on kodi? There isn't an option in the system settings for it.
Any help would be greatly appreciated guy, thanks.
PJ311 is offline
post #1539 of 1879 Old 03-13-2015, 06:38 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Are the files with the stuttering VC1 encoded files? I know the FireTV doesn't handle those well. Examples would be movies like Batman Begins, 300, etc.
dropzone7 is offline
post #1540 of 1879 Old 03-13-2015, 07:12 AM
PJ311's Avatar
No they are not its various files, seems to be related to my audio if that makes any sense.
PJ311 is offline
post #1541 of 1879 Old 03-13-2015, 07:24 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Make sure you have your settings level set to "Expert" in order to have access to all of the audio and video settings.
post #1542 of 1879 Old 03-13-2015, 07:34 AM
PJ311's Avatar
Yes I have done that as well and set it to enable pass through as I have it connected via hdmi to an Onkyo tx-sr705. From what I have read this is the best setting. When I turn this on or off and then go back to the show or movie I am watching I get major studder.
Now I managed to get the on screen diagnostics up and it is not showing that I am getting any dropped or skipped frames. I bought this was the reason for the flickering/ studdering but now I'm assuming it isn't. Why would it be that my wdtv plays these videos much smoother.
Also under the system audio settings the audio output device is greyed out and listed as android,audiotrack, is this normal?
PJ311 is offline
post #1543 of 1879 Old 03-13-2015, 07:43 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Are you using software or hardware acceleration under video playback settings?
Your receiver is capable of HD audio codecs but the FireTV is not. It will play the core DD and DTS only. I don't have mine in front of me to tell you what I have everything set to but I would check into those video playback settings for sure.
post #1544 of 1879 Old 03-13-2015, 07:52 AM
PJ311's Avatar
I have both libstagefright and mediacodec turned on for hardware acceleration. I get a smoother picture with both turned on then I do with just one of them such as libstagefrigh as most sites have recommended.
So I should enable the pass through of the audio if the fire tv cannot process it correct? From all the sites I've read this appears to be the proper setting for a connection to this receiver.
Curious as to why my audio out put device is set to android,audiotrack and will not let me change it to something like HDMI.
Appreciate the help.
PJ311 is offline
post #1545 of 1879 Old 03-13-2015, 09:29 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Maybe there is some sort of HDMI handshake issue going on. I have had weird issues crop up if I did not turn things on in a certain order. The way I currently do it is TV, Receiver, then FireTV or whatever source I'm using.
post #1546 of 1879 Old 03-13-2015, 01:57 PM
Blacklac's Avatar
Safe to say this is not common since no one replied?
the unit was smooth as butter for a good week, then suddenly it started to load even menu items slower.
Blacklac is offline
post #1547 of 1879 Old 03-14-2015, 09:07 AM
reddice's Avatar
Quoted: 600 Post(s)
Liked: 117
I find that I factory reset my Fire TV at least every 3 months when it starts to lag and when I am watching Prime content it suddenly kicks me out of what I am watching. Netflix starts to freeze frame then speed up. I notice this more when I start to sideload apps so now since I reset it last month I didn't sideload anything.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is offline
post #1548 of 1879 Old 03-14-2015, 12:25 PM
Blacklac's Avatar
I didn't want to have to setup Kodi again. :/. Lol. I've never used it before, i don't have the setup process (getting all the addons/repositories) down to memory. That's all I've sideloaded though. :S
Blacklac is offline
post #1549 of 1879 Old 03-20-2015, 08:04 AM
VW78Westy's Avatar
Fire TV shutters watching sports. I am on my second Fire TV because of this issue. Have the Fire TV hooked up to Panasonic plasma via Wifi ASUS dual band router 5hrz. Watching sports via SlingTV and watchESPN. This does not happen on my appleTv while watching watchESPN. Is this a known problem with Fire TV? Or is there a fix?
VW78Westy is offline
post #1550 of 1879 Old 03-20-2015, 08:52 AM
reddice's Avatar
Quoted: 600 Post(s)
Liked: 117
My Fire TV shutters well freezes for a few seconds more with Netflix. I already factory reset this thing 3 times already since owning it. I also deleted the app a bunch of times and reinstalled it and rebooted at least every day. I still use it though because most of the time Netflix starts out in HD and not mud like the PS4 which although does not shutters it is the most unreliable of the devices.
reddice is offline
post #1551 of 1879 Old 03-20-2015, 09:21 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
My brother-in-law discovered the FireTV a few months ago and quickly installed Kodi on it. He really likes it but is looking for something more like a pure Android experience. He described it as a "tablet in a box" experience. There are lots of "go" apps from different networks that stream their programming on demand such as USTVVOD. He tried installing Android X86 on a laptop but the performance was less than hoped for. Any suggestions on a purely Android replacement for the FireTV?
post #1552 of 1879 Old 03-20-2015, 12:08 PM
Blacklac's Avatar
Just wanted to report I notice the same thing watching ESPN via Sling TV or anything with a scrolling ticker.
The same content is butter smooth on my Roku.
Blacklac is offline
post #1553 of 1879 Old 03-24-2015, 02:03 PM
reddice's Avatar
Quoted: 600 Post(s)
Liked: 117
External storage is available with the latest update.
http://www.aftvnews.com/amazon-annou...menu-and-more/
I still did not get the update pushed to me though. When I do I can finally download many games I got for free but did not install due to lack of storage onto the flash drive which I had connected already for a while but is not being used.
reddice is offline
post #1554 of 1879 Old 03-25-2015, 10:41 AM
MikeAlletto's Avatar
Quoted: 38 Post(s)
Yeah looking forward to this. I'll wait for reviews to see what is the best external storage. I'm thinking of getting a large USB flash drive for the games and apps that I haven't been able to store locally.
MikeAlletto is offline
post #1555 of 1879 Old 03-27-2015, 06:44 AM
luisev's Avatar
Quoted: 184 Post(s)
Liked: 99
Wonder if the storage will be available to apps such as Kodi. I can't test as the updated isn't available to me yet, checked this morning, so if anyone has been updated and is running Kodi can you please chime in?
luisev is offline
post #1556 of 1879 Old 03-27-2015, 11:15 AM
Goldenager62's Avatar
Quoted: 12 Post(s)
http://www.aftvnews.com/kodi-fully-c...d-usb-storage/
luisev likes this.
Goldenager62 is offline
post #1557 of 1879 Old 03-27-2015, 11:47 AM
luisev's Avatar
Quoted: 184 Post(s)
Liked: 99
Great, thanks for that link!
luisev is offline
post #1558 of 1879 Old 03-27-2015, 01:01 PM
reddice's Avatar
Quoted: 600 Post(s)
Liked: 117
Anyone downloaded Kodi on the Fire TV without sideloading it. I downloaded it from the Amazon site which showed it not comparable but someone said to ignore that and it would show up? Well on both of my Fire TV's one with the newest update nothing showed up even after refreshed purchased content and rebooting both devices. If I have to still sideload it and go through a million menu's to get to it then I will forget about it.
reddice is offline
post #1559 of 1879 Old 03-27-2015, 01:52 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
It doesn't show up if you don't sideload it. You have to sideload it first, then "buy" it from Amazon on a web browser, then go to my account in your FTV, and Sync Amazon content. Then you reboot your FTV and it should show up in your recent apps.
It is showing up in my FTV stick.
lulimet is offline
post #1560 of 1879 Old 03-28-2015, 07:30 AM
Drenhead's Avatar
Tonight, my fire tv stick stopped outputting sounds when playing only Amazon Prime content. Netflix and other apps work fine. I have tried all Dolby digital options with no luck. What could be wrong?
Drenhead is offline
