*Official* Amazon Fire TV Discussion Thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #1831 of 1860 Old 12-12-2016, 10:22 AM
smitbret's Avatar
Quoted: 316 Post(s)
Liked: 97
Originally Posted by AMG_Roadster View Post
I have a number of movies and video files on a home server. I would prefer to use a simple menu structure. ES File explorer fits the bill in both file browsing and pulling from my home network. How does Amazon Fire TV handle 2, 4, 6, gig movie files? Will it handle playing movies through ES File Explorer or am I going to have to use something like Plex?
My FireTV has no trouble with multi-gig files but that all depends on your particular setup and the codecs/containers of your files. I also use Mezzmo to stream my library to my TVs so if there are any incompatibility issues it transcodes on the server side and I am blissfully unaware.
FireTV has some limitations on the audio support, mostly limited to decoding DD and DD+ so if you want some higher resolution audio then you should probably sideload Kodi, set Kodi to passthrough the audio and let an AVR do the decoding.
smitbret is offline
post #1832 of 1860 Old 12-12-2016, 11:19 AM
christoofar's Avatar
Quoted: 242 Post(s)
Liked: 149
Anyone having issues with either Kodi or SPMC after receiving the FireOS update on the FTV2? Ever since then, SPMC will no longer work . I've installed 4 different versions (all clean installs, wiping SD card each time).Either it installs, opens normally, then after I've scanned all my media back , it loses them the next time you open it, or , it mostly won't even boot (gets to a black screen & then that is it). Spent all this past weekend trying to figure a solution. Was finally able to install Kodi 17 beta 6 on it late yesterday, and so far it is still working normally. I've posted this on Kodi & SPMC forums, nothing...
Heart in SoCal - Soul from the Motor City
AFTV2+ KODI 17=>SR6010=>Integra DTA-70.1=>Chane A1.4 x 3 + DCM OW-1s x 2 + 1 x RSL Speedwoofer10 S+ 1 x Klipsch 12-HQ
christoofar is offline
post #1833 of 1860 Old 12-17-2016, 06:05 PM
slapshot's Avatar
Quoted: 29 Post(s)
What's with the Fire tv box and stick where they both seem to hijack inputs on a Denon receiver? I have an LG tv in one room with the Denon and the Fire box, and the stick on a Samsung tv (no receiver) in another room and many times when switching inputs from say a TiVo or Apple TV in either room the AFTV and stick force the receiver and tv to go to the inputs that the Fire box is on when choosing a different input. If that makes any sense? As far as I know amazon doesn't have a hdmi-Cec setting that automatically goes to that input. I see where it never really sleeps, perhaps this is why because its basically always on?
slapshot is offline
post #1834 of 1860 Old 12-17-2016, 06:34 PM
Bond 007's Avatar
Quoted: 2400 Post(s)
Liked: 1924
Doesnt happen to me. Must be CEC in other devices.
Bond 007 is offline
post #1835 of 1860 Old 12-17-2016, 07:49 PM
rdgrimes's Avatar
Quoted: 2096 Post(s)
Liked: 1422
Yes you need to disable CEC in the affected devices. If you depend on CEC for ARC or something else, you're stuck with it.
The FTV devices do have CEC, its just a "secret" feature.
rdgrimes is online now
post #1836 of 1860 Old 12-17-2016, 11:56 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi slapshot, did the Fire TV box or stick had a software update lately to 5.2.4.0? If so, a new HDMI CEC Device Control option was added to Display & Sound Menu (it is on by default after udpate).
JChin is offline
post #1837 of 1860 Old 12-18-2016, 05:37 AM
slapshot's Avatar
Quoted: 29 Post(s)
Thanks I'll have to check that.
slapshot is offline
post #1838 of 1860 Old 12-18-2016, 06:46 AM
rdgrimes's Avatar
Liked: 1422
Sneaky bastages!
Well at least now there's a switch to turn it off. But if its off in other devices it won't matter. But if they're officially supporting this now, maybe the FTV will work better at being controlled by other device's remotes.
post #1839 of 1860 Old 12-18-2016, 07:14 AM
fvbounty's Avatar
Quoted: 67 Post(s)
Liked: 32
I just got the latest update and now I can't find any 4K content on Amazon Prime, used to have to scroll down the Amazon app to find it, now for me it's nowhere to be found...any help would be great...thanks
LG 65EF9500
Samsung UN55B8500XF FALD
fvbounty is offline
post #1840 of 1860 Old 12-18-2016, 09:16 AM
rdgrimes's Avatar
Liked: 1422
There are UHD lists in each of the different programming categories up along the top of the home screen. Everything is moved around but its all still there. If not, make sure your FTV is enabling UHD in the display settings. Might need a reboot.
fvbounty likes this.
post #1841 of 1860 Old 12-18-2016, 09:29 AM
fvbounty's Avatar
Quoted: 67 Post(s)
Liked: 32
Thanks I did enable the 4K in the settings but I didn't reboot...that's next!
LG 65EF9500
fvbounty is offline
post #1842 of 1860 Old 12-18-2016, 11:51 AM
fvbounty's Avatar
Quoted: 67 Post(s)
Liked: 32
The reboot did it, now I have a UHD section that I didn't have before and Thanks again for the info!
LG 65EF9500
fvbounty is offline
post #1843 of 1860 Old 12-22-2016, 01:23 AM
Liked: 1
To find 4K content, do the following:
Through Voice
Ask the voice filter to give you 4K movies or videos only
On Netflix, there's a filtering option
On Hulu, you can filter what 4K movies are available
If you do not want to filter through voice, then there is a good guide on howtogeek.com here, on how to find only 4k videos.
For enabling Plex & Kodi, there's a good Amazon Fire TV Stick Guide & Resource log book here.
avsnewbie23 is offline
post #1844 of 1860 Old 12-29-2016, 08:47 PM
rckrz6's Avatar
Quoted: 111 Post(s)
Liked: 55
Are they are going to boost the volume output, youtube on my tv is loud at 20, youtube and other apps on the fire tv are loud at 50+. i have to turn on auto volume and amplify to get it down to a decent number
rckrz6 is online now
post #1845 of 1860 Old 12-30-2016, 10:25 AM
Quoted: 242 Post(s)
Liked: 149
Lately I'm having a strange issue where the TV goes dark after a time, even though I have all screensavers OFF (both on the AFTV2 & in Kodi Settings) It happens after sitting idle for a time, which would point to screensaver, but it happened once or twice while playing music via Kodi. Audio still worked, just no picture. Latest FW on FTV & Kodi 17 b7.
post #1846 of 1860 Old 12-30-2016, 11:25 AM
rdgrimes's Avatar
Liked: 1422
The black screen isn't actually related to the screensaver, its the unit going to "sleep". There's no control over that, but it really shouldn't be doing it while music is playing. I can see it happening if the app in use is not properly "keeping it alive", but if you're listening to Amazon's music app it shouldn't happen. Pressing any button should bring it right back.
post #1847 of 1860 Old 12-30-2016, 11:32 AM
Quoted: 242 Post(s)
Liked: 149
A button press does bring it back, just was curious why it was doing it in the first place, since as I described I have nothing enabled to tell the AFTV to sleep or shut screen off. <shrug>
post #1848 of 1860 Old 12-30-2016, 11:34 AM
Bond 007's Avatar
Liked: 1924
Does it always happen from the Home screen?
Bond 007 is offline
post #1849 of 1860 Old 12-30-2016, 12:15 PM
Quoted: 242 Post(s)
Liked: 149
It's happened on the FTV home screen, and also when Kodi is up & playing music. Mostly the former, box sitting at idle, screen goes off after a time, which sounds like sleep mode kicks in auto-magically. Will watch for it & see if I can figure out the elapsed time before it goes dark.
bilpiper likes this.
post #1850 of 1860 Old 12-30-2016, 01:58 PM
rdgrimes's Avatar
Liked: 1422
Should be at around 15-20 min.
post #1851 of 1860 Old 12-30-2016, 02:56 PM
Quoted: 242 Post(s)
Liked: 149
Do you have any idea what is causing this?
post #1852 of 1860 Old 12-30-2016, 03:51 PM
rdgrimes's Avatar
Liked: 1422
Its designed to do this, call it a feature. It shuts down video processing after a period of inactivity. Its meant to save energy and heat.
post #1853 of 1860 Old 12-30-2016, 05:10 PM
Quoted: 242 Post(s)
Liked: 149
Interesting. Wasn't like this until recently. Enabling it without end user ability to defeat kind of sucks too. I'd rather have the choice, especially if it's shutting off while playing media files...
reddice likes this.
post #1854 of 1860 Old 12-30-2016, 06:10 PM
rdgrimes's Avatar
Liked: 1422
Every FTV devise has done it since day one. I don't know if the timings have changed with the new software, maybe so.
post #1855 of 1860 Old Today, 07:36 AM
Liked: 0
connecting fire tv to Pre/pro via hdmi problems
Hello all
I am late to the party regarding the amazon fire tv system
I recently purchased a system and connected via HDMI to my marantz pre pro
In this case I connected to gaming input as I dont use it.
I then select that input with all things powered up.
I get a black screen with amazon logo via my Benq w7000 projector.
Thats has far as I have gotten. No on screen menus allowing me to go further
the tried mating the remote to the Fire TV and there is really no indication that the fire tv and remote are communicating.
I understand some devices are very finicky with regards to HDMI cables but if I have the amazon logo on the screen I am assuming that the connection is working.
It my understanding that HDMI cables work or do not really no in between so feel thats not the problem.
I sure would appreciate any advice.
regards
sb99acr is offline
post #1856 of 1860 Old Today, 07:55 AM
Quoted: 242 Post(s)
Liked: 149
Originally Posted by sb99acr View Post
Hello all
regards
Have you tried unplugging/replugging in the power cable to have it reboot?
Have you tried a different input? Have you tried a different HDMI cable?
You should be seeing the boot logo , then asking you to pair up the remote, then setting your internet connection. If you have tried all of these & no joy, you should contact Amazon about a replacement.
post #1857 of 1860 Old Today, 11:46 AM
tvforavs's Avatar
Has anyone able to install Plex ARM64v8a build on Fire TV 2?
tvforavs is offline
post #1858 of 1860 Old Today, 01:22 PM
Liked: 0
Thanks for your response
I have tried all of those except a different HDMI cable as I thought if the static amazon logo was showing that it was something other than the cable.
does the white light on the black box blink when it receives a signal from the remote or does it always blink.
I really have no way of knowing if the remote is communicating with the box.
sb99acr is offline
post #1859 of 1860 Old Today, 03:10 PM
Quoted: 242 Post(s)
Liked: 149
Seems it sticks at the boot logo. If you have restarted it several times & still only get that far, then it appears to be a defective box.
Contact Amazon to get a new one.
There are numerous YouTube clips showing what a normal start up/install process should be like. It should be asking to let it pair to the remote, and then guide you in connecting to your home network, to allow you control and internet access in order to be able to synch to content.
post #1860 of 1860 Old Today, 08:36 PM
Paul Arnette's Avatar
Quoted: 32 Post(s)
I take it there isn't an option similar to Netflix's Playback Setting = High for the Amazon Fire TV in general?
My wife and I watched Man in the High Castle Season Two in "4K", and the quality was pretty dodgy with lots of MPEG artifacting in dark scenes. I watched Netflix's Iron First tonight on the same device with Playback Setting = High, and it looked phenomenal. It's what I expected 4K streaming to look like all along. Has anyone else had a similar experience?
Paul Arnette is online now
